Home » Eclipse Projects » GEF » RulerComposite
| RulerComposite [message #139868] |
Thu, 24 June 2004 12:59  |
i've been looking at the code for rulers. i'm wondering why the top level UI
object is a RulerComposite (inheriting from Composite), rather than a
RulerEditor (inheriting from EditPart).
i'm assuming this is because the rulers have to be added to an existing
editor. if, instead, i'm writing an editor that draws the rulers itself
(actually it's more like a graph axis than a ruler), would it make sense to
have the top level object be an EditPart (and simplifying some of the ruler
structure? i know i can probably figure this out by looking at the code, but
was hoping someone knew the answer off the top of their head.
also, any pointers on how to go about structuring an editor that had such
axes/rulers as part of it's model would be appreciated. starting from the
ruler code sample.
regards,
al
| Re: RulerComposite [message #139940 is a reply to message #139928] |
Thu, 24 June 2004 18:45   |
so you'd suggest using a similar structure even if the ruler/axes are an
integral part of the model? in my situation, the ruler/axis may have to be
drawn in the middle of the client area, not at an edge. so direct re-use of
the ruler code isn't actually possible.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cbfhnu$ij4$1@eclipse.org...
> It makes a lot of things easier to implement as a composite. For example,
> independant scrolling and also focus management and keyboard
accessibility.
> Maybe your graph axis doesn't need some of these functions.
> "Al Major" <almajor@boxspoon.com> wrote in message
> news:cbf1ca$l69$1@eclipse.org...
level
> UI
> to
> ruler
> but
such
the
> > ruler code sample.
> > regards,
> > al
| Re: RulerComposite [message #139962 is a reply to message #139928] |
Thu, 24 June 2004 23:26   |
hi randy,
i'm still having some trouble with this, so i'm going to try to summarize
the situation to see if i understand it correctly.
according to the documentation i've seen, the GraphicalViewer is an
EditPartViewer with it's own RootEditPart and EditPartFactory. i somehow
have the impression that GEF is designed to have a single EditPartViewer per
editor (workbench editpart). this is (apparently) a mistaken impression,
because......
in the RulerComposite, the top level composite contains (up to) 3
ScrollingGraphicalViewers, one of them being the "main" EditPartViewer, the
others being an EditPartViewer for each Ruler. so conceptually, there's 3
models (one for each viewer), apparently tied together with a RulerProvider
that exposes the ruler models to the "main" model.
the bulk of the ruler code is straightforward GEF/draw2d code as i expected.
just the glue code in the composite is being done SWT style instead of in
draw2d. this is what surprised me.
is this an accurate representation of the situation?
if so, and from what you're saying, certain features, such as independant
scrolling, focus management and keyboard accessibility are difficult to
implement purely with draw2d figures. as a newbie, i don't understand enough
about the architecture to see why this should be so. your word on it is
obviously good. however, i'd like to know if there are other situations
where one or the other (draw2d/SWT) is the obvious choice. has anything been
written up about this?
in my situation with the ruler/axis potentially in the middle of the client
area, the choice comes down to how the model is visualized. if the model can
be cleanly split so that each sub-model can be visualized in a
non-overlapping region of the screen, i can use the composite glue ala
ruler. however, if there are model elements that must visually appear on
both sides of the ruler/axis i have to use draw2d as the glue. in the second
case, can you say a little more about the functionality restrictions i'm
likely to run into, and point me at the right parts of the API / other
documentation.
thx/regards,
al
accessibility.
level
> UI
> to
> ruler
> but
such
the
> > ruler code sample.
> > regards,
> > al
| Re: RulerComposite [message #140075 is a reply to message #139962] |
Fri, 25 June 2004 10:17   |
Since GEF is the foundation for business tools, it must be Section 508
accessible. So we needed a way to traverse to the ruler with the keyboard.
There are tons of ways to do this and you could do it within a single
GraphicalViewer, but we chose to use native focus traversal within a single
Composite.
The other thing that was necessary was a separate notion of selection. If a
Guide on the ruler is selected, a part in the diagram cannot also be in the
same selection. Again, there are ways to implement the illusion of two
distinct viewers within a single viewer, but it is harder. Context menus
need to be separate, etc.
It really depends on what you are doing as to how you solve it. Do you need
selection, context menus, etc., or are you just painting an axis?
news:cbg64e$e4j$1@eclipse.org...
> hi randy,
per
> because......
the
RulerProvider
expected.
enough
been
client
can
second
> documentation.
> thx/regards,
> al
example,
> accessibility.
> level
> > UI
existing
itself
sense
> > to
> > ruler
code,
> > but
> such
> the
> > > ruler code sample.
> > > regards,
> > > al
| Re: RulerComposite [message #140272 is a reply to message #140075] |
Fri, 25 June 2004 16:10   |
thanks. that was useful detail.
i'm not quite sure as yet whether i'll need selection/context menus etc.
maybe i'll start off mimicking your implementation and see if more/less is
needed later.
regards,
al
news:cbhc53$irk$1@eclipse.org...
keyboard.
single
> Composite.
a
the
need
> > hi randy,
summarize
> per
> > because......
> the
3
> RulerProvider
> expected.
in
independant
> enough
> been
> client
> can
> second
> > documentation.
> > thx/regards,
> > al
> example,
> > accessibility.
> > level
> > > UI
a
> existing
> itself
> sense
> > > to
the
> > > ruler
> code,
> > > but
> > such
from
> > the
> > > > ruler code sample.
> > > > regards,
> > > > al
| Re: RulerComposite [message #141172 is a reply to message #140272] |
Thu, 01 July 2004 18:12   |
it appears that if i have multiple panes, each with it's own model, the top
level editor (corresponding to LogicEditor in the sample) will need to
contain a GraphicalEditor instance for each pane. so the current structure
of LogicEditor inheriting from a GraphicalEditor is not going to work as is.
or, am i missing something?
regards,
al
news:cbi0u6$r63$1@eclipse.org...
> needed later.
> regards,
> al
> keyboard.
> single
> > Composite.
If
> a
> the
menus
> need
> > > hi randy,
> summarize
somehow
EditPartViewer
> > per
impression,
> > > because......
EditPartViewer,
> > the
there's
> 3
> > RulerProvider
> > expected.
> in
> independant
to
> > enough
is
situations
anything
> > been
> > client
model
> > can
on
> > second
i'm
> > > documentation.
> > > thx/regards,
> > > al
> > example,
> > > accessibility.
top
> > > level
> > > > UI
than
> a
> > existing
> > itself
> > sense
> > > > to
> the
> > > > ruler
> > code,
> > > > but
had
> > > such
> from
> > > the
> > > > > ruler code sample.
> > > > > regards,
> > > > > al
| Re: RulerComposite [message #141250 is a reply to message #141172] |
Thu, 01 July 2004 20:01  |
I am not sure what you mean. What do you mean by a pane? And what are
these panes showing?
news:cc2270$is0$1@eclipse.org...
top
is.
> regards,
> al
is
> > needed later.
> > regards,
> > al
> > keyboard.
> > single
> > > Composite.
> If
> > a
in
> > the
two
> menus
you
> > need
> > > > hi randy,
> > summarize
> somehow
> EditPartViewer
> > > per
> impression,
> > > > because......
> EditPartViewer,
> > > the
> there's
> > 3
> > > RulerProvider
> > > expected.
of
> > in
> > independant
> to
understand
> > > enough
> is
> situations
> anything
> > > been
> > > client
> model
> > > can
ala
appear
> on
the
> > > second
> i'm
other
> > > > documentation.
> > > > thx/regards,
> > > > al
> > > example,
> > > > accessibility.
> top
> > > > level
> > > > > UI
> than
> > a
> > > existing
> > > itself
make
> > > sense
> > > > > to
of
> > the
> > > > > ruler
the
> > > code,
> > > > > but
> had
> > > > such
> > from
> > > > the
> > > > > > ruler code sample.
> > > > > > regards,
> > > > > > al
Current Time: Sat Nov 08 03:13:04 EST 2025
Powered by FUDForum. Page generated in 0.04641 seconds
