Home » Eclipse Projects » NatTable » RMB on a cell returning last selected cell position as null
RMB on a cell returning last selected cell position as null [message #1398161] Thu, 10 July 2014 14:16 Go to next message
Hi Dirk,
To enable RMB on my nattable I added a uibinding like this:
uiBindingRegistry.registerMouseDownBinding( new MouseEventMatcher( SWT.NONE, GridRegion.BODY,
MouseEventMatcher.RIGHT_BUTTON ), new IMouseAction()
public void run( NatTable natTable, MouseEvent event )
int colPosition = LayerUtil.convertColumnPosition( natTable,
natTable.getColumnPositionByX( event.x ), selectionLayer );
int rowPosition = LayerUtil.convertRowPosition( natTable,
natTable.getRowPositionByY( event.y ), selectionLayer );
if( !selectionLayer.isCellPositionSelected( colPosition, rowPosition ) )
selectCellAction.run( natTable, event );
But I found that sometimes the getLastSelectedCellPosition() on selectionLayer returns me null, which is causing some problems in my application.
Is that a correct way to implement RMB binding?
Thanks.
Re: RMB on a cell returning last selected cell position as null [message #1398236 is a reply to message #1398161] Thu, 10 July 2014 16:45 Go to previous messageGo to next message
It looks correct.
What do you need the getLastSelectedCellPosition() for? As far as I remember that method is mainly used internally for selection movement and selection anchor handling.
Also I suggest do execute commands rather than calling run() on another action, as the run() method will again perform the transformation code to determine the coordinates.
Re: RMB on a cell returning last selected cell position as null [message #1398666 is a reply to message #1398236] Fri, 11 July 2014 07:59 Go to previous messageGo to next message
If my table implements ISelectionProvider ( org.eclipse.jface.viewers.ISelectionProvider ) for I need to provide some selection through overridden getSelection().
I didn't see another way of providing selection other than selection layer's getLastSelectedCellPosition(). Is there a better way of getting selection from selection Layer , I mean is there another API to get selection?
Re: RMB on a cell returning last selected cell position as null [message #1398671 is a reply to message #1398666] Fri, 11 July 2014 08:07 Go to previous messageGo to next message
For such cases NatTable ships with the RowSelectionProvider.
Check the _5054_SelectionProviderExample under Tutorial Example - Layers - Selection -SelectionProviderExample
Re: RMB on a cell returning last selected cell position as null [message #1398723 is a reply to message #1398671] Fri, 11 July 2014 09:38 Go to previous message
Thanks. I will try this.
Previous Topic:Sorting and Indices
Next Topic:nattable drop bug with scrollbar
Current Time: Sun Jul 27 18:41:12 EDT 2025
Powered by FUDForum. Page generated in 0.24525 seconds
