xpost: Error opening a schema (xsd) document in Eclipse's extension point editor! [message #139861] |
Thu, 23 February 2006 19:45 |
Originally posted by: amolvNO.SPAMnetscape.net
This is in eclipse-SDK-3.2M5-win32 and has also happened in previous stable
builds.
The xsd file is loaded in the editor (I have .xsd files associated with
extension point schema editor) but an error window pops up "An error has
occurred. See error log for more details.". The same error pops up when I
close this file from the File-> Close menu or when I exit eclipse.
I have been using eclipse for quite a while but can't seem to figure this
error out. Is this a known problem with these eclipse builds or the
extension point schema editor?
Thanks in advance for any help.
-Amol
The event details from the error log for file open and file close are:
..xsd file open
eclipse.buildId=I20051215-1506
java.version=1.5.0_04
Command-line arguments: -os win32 -ws win32 -arch x86 -data
E:\eclipsedev\workspace
This is a continuation of log file
E:\eclipsedev\workspace\.metadata\.bak_0.log
Created Time: 2006-01-04 13:04:40.524
Error
2006-02-20 23:35:05.566
Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
at
org.eclipse.pde.internal.ui.editor.schema.SchemaFormOutlineP age.getChildren(SchemaFormOutlinePage.java:31)
at
org.eclipse.pde.internal.ui.editor.FormOutlinePage$BasicCont entProvider.getChildren(FormOutlinePage.java:54)
at
org.eclipse.pde.internal.ui.editor.FormOutlinePage$BasicCont entProvider.hasChildren(FormOutlinePage.java:57)
at
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:1787)
at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer .java:807)
at
org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTreeViewer.java:1810)
at
org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTreeViewer.java:2379)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:724)
at
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:701)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:675)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:849)
at
org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewer.java:1211)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1261)
at
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTreeViewer.java:1201)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:249)
at
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:1477)
at
org.eclipse.pde.internal.ui.editor.FormOutlinePage.createCon trol(FormOutlinePage.java:116)
at
org.eclipse.pde.internal.ui.editor.PDEMultiPageContentOutlin e.setPageActive(PDEMultiPageContentOutline.java:140)
at
org.eclipse.pde.internal.ui.editor.PDEMultiPageContentOutlin e.setActionBars(PDEMultiPageContentOutline.java:107)
at org.eclipse.ui.part.PageBookView.preparePage(PageBookView.ja va:423)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:396)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:731)
at
org.eclipse.ui.views.contentoutline.ContentOutline.partBroug htToTop(ContentOutline.java:206)
at org.eclipse.ui.internal.PartListenerList$2.run(PartListenerL ist.java:86)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:816)
at
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:57)
at
org.eclipse.ui.internal.PartListenerList.firePartBroughtToTo p(PartListenerList.java:84)
at
org.eclipse.ui.internal.PartService.firePartBroughtToTop(Par tService.java:87)
at
org.eclipse.ui.internal.WorkbenchPagePartList.firePartBrough tToTop(WorkbenchPagePartList.java:75)
at
org.eclipse.ui.internal.WorkbenchPagePartList.fireActiveEdit orChanged(WorkbenchPagePartList.java:51)
at org.eclipse.ui.internal.PartList.setActiveEditor(PartList.ja va:143)
at
org.eclipse.ui.internal.WorkbenchPage.makeActiveEditor(Workb enchPage.java:1133)
at
org.eclipse.ui.internal.WorkbenchPage.updateActivePart(Workb enchPage.java:1078)
at org.eclipse.ui.internal.WorkbenchPage.partAdded(WorkbenchPag e.java:1425)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:805)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:705)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:666)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2390)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2325)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2317)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2303)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2298)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2283)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:384)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:347)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.jav a:214)
at
org.eclipse.ui.internal.navigator.CommonNavigatorManager$1.o pen(CommonNavigatorManager.java:111)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:780)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:778)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1009)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1108)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:244)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:239)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:278)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3287)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2907)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1899)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1863)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:417)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:99)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
..xsd file close
Error
2006-02-20 23:50:36.118
at org.eclipse.ui.part.PageBookView.removePage(PageBookView.jav a:814)
at org.eclipse.ui.part.PageBookView.partClosed(PageBookView.jav a:763)
at
org.eclipse.ui.internal.PartListenerList$3.run(PartListenerL ist.java:101)
at
at
org.eclipse.ui.internal.PartListenerList.firePartClosed(Part ListenerList.java:99)
at org.eclipse.ui.internal.PartService.firePartClosed(PartServi ce.java:100)
at
org.eclipse.ui.internal.WorkbenchPagePartList.firePartClosed (WorkbenchPagePartList.java:38)
at org.eclipse.ui.internal.PartList.partClosed(PartList.java:22 9)
at org.eclipse.ui.internal.PartList.removePart(PartList.java:16 4)
at
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1441)
at
org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1264)
at
org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1248)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1222)
at
org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1286)
at org.eclipse.ui.internal.CloseEditorAction.run(CloseEditorAct ion.java:40)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:492 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:530)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:480)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:392)
at
at
at
at
at
at
at
at
FUDForum. Page generated in 0.10760 seconds
