Home » Language IDEs » ServerTools (WTP) » JSDT: impossible to use in an middle Java/JavaScript project(JSDT/Eclipse freezes on edit of JavaScript Files)
JSDT: impossible to use in an middle Java/JavaScript project [message #1384900] |
Mon, 02 June 2014 17:38  |
Hi All.
Eclipse freezes reproducible if I'm trying to open/edit some JavaScript files. (e.g source code from angular.js) Please see screenshots.
The Heap fills with millions of jsdt.internal.compiler-Objects, that eats the entire Memory and GC is running non-stop. After few minutes its runs out of memory and crashes.
Please fix it, if possible. Same files opens without any problems in Brackets or IntelliJ, with auto completion and other useful stuff.
Nikolai
Here you can see my system properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.lwawt.macosx.LWCToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=4.3.0.M20130911-1000
eclipse.commands=-os
macosx
-ws
cocoa
-arch
x86_64
-showsplash
-launcher
/Users/nikolai/Downloads/eclipse/Eclipse.app/Contents/MacOS/eclipse
-name
Eclipse
--launcher.library
/Users/nikolai/Downloads/eclipse/Eclipse.app/Contents/MacOS//../../../plugins/org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.200.v20130807-1835/eclipse_1508.so
-startup
/Users/nikolai/Downloads/eclipse/Eclipse.app/Contents/MacOS//../../../plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
--launcher.appendVmargs
-product
org.eclipse.epp.package.standard.product
-keyring
/Users/nikolai/.eclipse_keyring
-showlocation
-vm
/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/bin/../jre/lib/server/libjvm.dylib
eclipse.home.location=file:/Users/nikolai/Downloads/eclipse/
eclipse.launcher=/Users/nikolai/Downloads/eclipse/Eclipse.app/Contents/MacOS/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.MD5Check=false
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.standard
eclipse.p2.unsignedPolicy=allow
eclipse.product=org.eclipse.epp.package.standard.product
eclipse.startTime=1401741953272
eclipse.vm=/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/bin/../jre/lib/server/libjvm.dylib
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.7
-XstartOnFirstThread
-Xincgc
-Xss1m
-Duser.name=Nikolai Raitsev
-Dfile.encoding=UTF-8
-Declipse.p2.unsignedPolicy=allow
-Declipse.p2.MD5Check=false
-Xms512m
-Xmx1024m
-XX:NewSize=128m
-XX:PermSize=128m
-XX:MaxPermSize=512m
-XX:MaxPermHeapExpansion=20m
-XX:+UseConcMarkSweepGC
-XX:CMSInitiatingOccupancyFraction=70
-XX:+UseCMSInitiatingOccupancyOnly
-XX:+UseParNewGC
-XX:+CMSConcurrentMTEnabled
-XX:ConcGCThreads=2
-XX:ParallelGCThreads=2
-XX:+CMSIncrementalPacing
-XX:CMSIncrementalDutyCycleMin=0
-XX:CMSIncrementalDutyCycle=5
-XX:GCTimeRatio=49
-XX:MaxGCPauseMillis=20
-XX:GCPauseIntervalMillis=1000
-XX:+UseCMSCompactAtFullCollection
-XX:+CMSClassUnloadingEnabled
-XX:+DoEscapeAnalysis
-XX:+UseCompressedOops
-XX:+AggressiveOpts
-XX:+ExplicitGCInvokesConcurrentAndUnloadsClasses
-Xdock:icon=../Resources/Eclipse.icns
-Dorg.eclipse.swt.internal.carbon.smallFonts
-Dorg.eclipse.swt.browser.IEVersion=10001
-Dgrails.console.enable.interactive=false
-Dgrails.console.enable.terminal=false
-Djline.terminal=jline.UnsupportedTerminal
-Dgrails.console.class=grails.build.logging.GrailsEclipseConsole
-Djava.class.path=/Users/nikolai/Downloads/eclipse/Eclipse.app/Contents/MacOS//../../../plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar
equinox.use.ds=true
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
ftp.nonProxyHosts=local|*.local|169.254/16|*.169.254/16
gopherProxySet=false
gosh.args=--nointeractive
guice.disable.misplaced.annotation.check=true
java.awt.graphicsenv=sun.awt.CGraphicsEnvironment
java.awt.printerjob=sun.lwawt.macosx.CPrinterJob
java.class.version=51.0
java.endorsed.dirs=/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/endorsed
java.ext.dirs=/Users/nikolai/Library/Java/Extensions:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/ext:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
java.home=/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre
java.io.tmpdir=/var/folders/hd/kf5_0qz563jbjzmjbhd232vr0000gn/T/
java.library.path=/Users/nikolai/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:.
java.rmi.server.randomIDs=true
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_45-b18
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0_45
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=24.45-b08
line.separator=\n
org.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
org.eclipse.equinox.launcher.splash.location=/Users/nikolai/Downloads/eclipse/plugins/org.eclipse.platform_4.3.2.v20140221-1700/splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.m2e.log.dir=/Users/nikolai/Documents/workspace/.metadata/.plugins/org.eclipse.m2e.logback.configuration
org.eclipse.swt.internal.carbon.smallFonts=
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7
org.osgi.framework.language=de
org.osgi.framework.os.name=MacOSX
org.osgi.framework.os.version=10.9.3
org.osgi.framework.processor=x86-64
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JRE"; version:List="1.0, 1.1",osgi.ee; osgi.ee="JavaSE"; version:List="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=c063e1e3-96ea-0013-1ca7-fac21908e487
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.7.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86_64
os.name=Mac OS X
os.version=10.9.3
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.fx.osgi_0.9.0.201312220701.jar,reference:file:org.eclipse.equinox.weaving.hook_1.0.200.I20130319-1000.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.0.400.v20130327-2119.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/Users/nikolai/Downloads/eclipse/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/Users/nikolai/Downloads/eclipse/configuration/
osgi.framework=file:/Users/nikolai/Downloads/eclipse/plugins/org.eclipse.osgi_3.9.1.v20130814-1242.jar
osgi.framework.extensions=reference:file:org.eclipse.fx.osgi_0.9.0.201312220701.jar,reference:file:org.eclipse.equinox.weaving.hook_1.0.200.I20130319-1000.jar
osgi.framework.shape=jar
osgi.framework.version=3.9.1.v20130814-1242
osgi.frameworkClassPath=., file:/Users/nikolai/Downloads/eclipse/plugins/org.eclipse.fx.osgi_0.9.0.201312220701.jar, file:/Users/nikolai/Downloads/eclipse/plugins/org.eclipse.equinox.weaving.hook_1.0.200.I20130319-1000.jar
osgi.install.area=file:/Users/nikolai/Downloads/eclipse/
osgi.instance.area=file:/Users/nikolai/Documents/workspace/
osgi.instance.area.default=file:/Users/nikolai/Documents/workspace/
osgi.logfile=/Users/nikolai/Documents/workspace/.metadata/.log
osgi.manifest.cache=/Users/nikolai/Downloads/eclipse/configuration/org.eclipse.osgi/manifests
osgi.nl=de_DE
osgi.os=macosx
osgi.splashLocation=/Users/nikolai/Downloads/eclipse/plugins/org.eclipse.platform_4.3.2.v20140221-1700/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/Users/nikolai/Downloads/eclipse/plugins
osgi.tracefile=/Users/nikolai/Documents/workspace/.metadata/trace.log
osgi.user.area=file:/Users/nikolai/user/
osgi.ws=cocoa
path.separator=:
python.home=/Users/nikolai/Downloads/eclipse/plugins/org.python.pydev.jython_3.4.1.201403181715
python.path=/Users/nikolai/Downloads/eclipse/plugins/org.python.pydev.jython_3.4.1.201403181715/jysrc
python.security.respectJavaAccessibility=false
socksNonProxyHosts=local|*.local|169.254/16|*.169.254/16
sun.arch.data.model=64
sun.boot.class.path=/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/alt-rt.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/resources.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/rt.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/sunrsasign.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/jsse.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/jce.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/charsets.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/jfr.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib/JObjC.jar:/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/classes
sun.boot.library.path=/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home/jre/lib
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeBig
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
sun.os.patch.level=unknown
user.country=DE
user.dir=/Users/nikolai/Downloads/eclipse/Eclipse.app/Contents/MacOS
user.home=/Users/nikolai
user.language=de
user.timezone=Europe/Berlin
[Updated on: Mon, 02 June 2014 17:40] by Moderator
Re: JSDT: impossible to use in an middle Java/JavaScript project [message #1397445 is a reply to message #1384901] |
Wed, 09 July 2014 14:49  |
I have the same issue, when JSDT is installed and JS-File from AngularJS Project is opened.
Tried to copy/paste some JavaScript code when Eclipse Luna becomes unresponsive.
- Standard Luna installation, added Maven, AngularJS
- Does no linger crash, after JSDT is uninstalled
- OSX 10.9.4
- Version: Luna Release (4.4.0), Build id: 20140612-0600
Current Time: Fri Jul 25 23:45:39 EDT 2025
Powered by FUDForum. Page generated in 0.03911 seconds
