Home » Archived » Test and Performance Tools Platform (TPTP) » Adding new attributs for recording and playing back the table items
Adding new attributs for recording and playing back the table items [message #139734] Tue, 27 January 2009 07:47 Go to next message
For recording and Playback of JFace Cell Editor item, we have to add a
set of new attributes to the <command> element in the recorded XML
script, for storing the parent (Table) control information.
// Reference ID if Object Mine used
public static final String PARENT_REFERENCE_ID_ATTRIBUTE =
"parent-referenceId";
// If Object Mine not used, the Resolver ID
public static final String PARENT_RESOLVER_ATTRIBUTE = "parent-resolverId";
// If Object Mine not used, the Context ID
public static final String PARENT_CONTEXT_ID_ATTRIBUTE =
"parent-contextId";
// If Object Mine not used, the Widget ID
public static final String PARENT_WIDGET_ID_ATTRIBUTE = "parent-widgetId";
// The column and row of the parent Table.
public static final String PARENT_CELL_X_ATTRIBUTE = "parent-cell-x";
public static final String PARENT_CELL_Y_ATTRIBUTE = "parent-cell-y";
Can anyone tell me how to add those in <command>. I m using objectmine
<--------My recorded XML is -------------->
<macro version="1.0">
<shell descriptive="Workspace - ReadiONE - sdfs/src/test.testsuite -
E..." referenceId="0" return-code="0">
<command type="select" referenceId="87"/>
</shell>
<shell descriptive="Person Editor" referenceId="89" return-code="0">
<command type="focus" referenceId="91"/>
<command type="focus" referenceId="90"/>
<command descriptive="AA" type="choice-select" referenceId="90"
choiceId="item#0"/>
<command descriptive="AA" type="focus" referenceId="93"/>
<command descriptive="Name" type="item-select" referenceId="91">
<item referenceId="96"/>
</command>
<command descriptive="4 - 7" type="choice-select" referenceId="93"
choiceId="item#2"/>
<item referenceId="92"/>
</command>
<command descriptive="0 - 3" type="choice-select" referenceId="93"
choiceId="item#1"/>
</shell>
</macro>
Re: Adding new attributs for recording and playing back the table items [message #139746 is a reply to message #139734] Wed, 28 January 2009 06:52 Go to previous messageGo to next message
Hi Asha,
You would have to modify the AGR recorder component to capture and emit
these new attributes. There is no extensibility in the AGR to support this.
Paul
"Asha " <asha@readiminds.com> wrote in message
news:3e25cf081e948d011d15e47d608908b7$1@www.eclipse.org...
> "parent-contextId";
> <shell descriptive="Workspace - ReadiONE - sdfs/src/test.testsuite - E..."
> </shell>
> choiceId="item#0"/>
> </command>
> choiceId="item#2"/>
> </command>
> choiceId="item#1"/>
> </shell>
> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139757 is a reply to message #139746] Wed, 28 January 2009 07:14 Go to previous messageGo to next message
Hi Paul,
Thanks for ur reply.which AGR Component i have to modify? There
its written that we have to add these attributes in recorded xml.can u plz
clarify where i have to modify.
Asha
Paul Slauenwhite wrote:
> Hi Asha,
> Paul
>> Hi,
>> "parent-contextId";
>> </shell>
>> choiceId="item#0"/>
>> </command>
>> choiceId="item#2"/>
>> </command>
>> choiceId="item#1"/>
>> </shell>
>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139779 is a reply to message #139757] Thu, 29 January 2009 06:31 Go to previous messageGo to next message
Hi Asha,
I would start in the org.eclipse.tptp.test.auto.gui.internal.macro and
org.eclipse.tptp.test.auto.gui.internal.codegen packages of the
org.eclipse.tptp.test.auto.gui plug-in.
Paul
news:a17f423716be8235e89a9dd09edf4ac9$1@www.eclipse.org...
> Hi Paul,
> Regards,
> Asha
>> Hi Asha,
>> emit these new attributes. There is no extensibility in the AGR to
>> support this.
>> Paul
>>> Hi,
>>> a set of new attributes to the <command> element in the recorded XML
>>> "parent-contextId";
>>> "parent-widgetId";
>>> </shell>
>>> choiceId="item#0"/>
>>> </command>
>>> choiceId="item#2"/>
>>> </command>
>>> choiceId="item#1"/>
>>> </shell>
>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139789 is a reply to message #139779] Thu, 29 January 2009 09:04 Go to previous messageGo to next message
Hi Paul,
Thanks for ur reply. There are so many class file in these
packages, which class files i have to modify? plz reply soon
> Hi Asha,
> Paul
>> Hi Paul,
>> Regards,
>> Asha
>>> Hi Asha,
>>> support this.
>>> Paul
>>>> Hi,
>>>> "parent-contextId";
>>>> "parent-widgetId";
>>>> </shell>
>>>> choiceId="item#0"/>
>>>> </command>
>>>> choiceId="item#2"/>
>>>> </command>
>>>> choiceId="item#1"/>
>>>> </shell>
>>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139800 is a reply to message #139789] Fri, 30 January 2009 06:41 Go to previous messageGo to next message
Hi Asha,
Start with
/org.eclipse.tptp.test.auto.gui/src/org/eclipse/tptp/test/au to/gui/internal/macro/MacroConstants.java
and search for uses of the
org.eclipse.tptp.test.auto.gui.internal.macro.MacroConstants .COMMAND_ELEMENT
field. For example,
org.eclipse.tptp.test.auto.gui.internal.commands.AbstractMac roCommand.write(int,
StringBuffer, boolean, boolean).
Paul
news:43514242fb171e069d839181d43d952b$1@www.eclipse.org...
> Hi Paul,
>> Hi Asha,
>> and org.eclipse.tptp.test.auto.gui.internal.codegen packages of the
>> Paul
>>> Hi Paul,
>>> plz clarify where i have to modify.
>>> Regards,
>>> Asha
>>>> Hi Asha,
>>>> support this.
>>>> Paul
>>>>> Hi,
>>>>> add a set of new attributes to the <command> element in the recorded
>>>>> XML
>>>>> "parent-contextId";
>>>>> "parent-widgetId";
>>>>> </shell>
>>>>> choiceId="item#0"/>
>>>>> </command>
>>>>> choiceId="item#2"/>
>>>>> </command>
>>>>> choiceId="item#1"/>
>>>>> </shell>
>>>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139811 is a reply to message #139800] Fri, 30 January 2009 09:24 Go to previous messageGo to next message
Hi Paul,
Only these attributes i have to add in macroconstant.
="parent-referenceId";
public static final String PARENT_CONTEXT_ID_ATTRIBUTE ="parent-contextId";
public static final String PARENT_WIDGET_ID_ATTRIBUTE ="parent-widgetId";
Other than that what i have to do. because i added thode attributs but
still same error is coming.
Asha
> Hi Asha,
> Start with
> field. For example,
> Paul
>> Hi Paul,
>>> Hi Asha,
>>> Paul
>>>> Hi Paul,
>>>> Regards,
>>>> Asha
>>>>> Hi Asha,
>>>>> support this.
>>>>> Paul
>>>>>> Hi,
>>>>>> XML
>>>>>> "parent-contextId";
>>>>>> "parent-widgetId";
>>>>>> </shell>
>>>>>> choiceId="item#0"/>
>>>>>> </command>
>>>>>> choiceId="item#2"/>
>>>>>> </command>
>>>>>> choiceId="item#1"/>
>>>>>> </shell>
>>>>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139823 is a reply to message #139811] Mon, 02 February 2009 02:40 Go to previous messageGo to next message
Hi Paul,
At how many places i have to change the code? i m not able to
understand where i have to modify other than MacroConstant.plz reply soon..
Asha wrote:
> Hi Paul,
> Asha
>> Hi Asha,
>> Start with
>> field. For example,
>> Paul
>>> Hi Paul,
>>>> Hi Asha,
>>>> Paul
>>>>> Hi Paul,
>>>>> Regards,
>>>>> Asha
>>>>>> Hi Asha,
>>>>>> support this.
>>>>>> Paul
>>>>>>> Hi,
>>>>>>> XML
>>>>>>> "parent-contextId";
>>>>>>> "parent-widgetId";
>>>>>>> </shell>
>>>>>>> choiceId="item#0"/>
>>>>>>> </command>
>>>>>>> choiceId="item#2"/>
>>>>>>> </command>
>>>>>>> choiceId="item#1"/>
>>>>>>> </shell>
>>>>>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139833 is a reply to message #139823] Mon, 02 February 2009 06:34 Go to previous messageGo to next message
Hi Asha,
In TPTP 4.5, the AGR was moved from a Technology Preview component to an
As-Is component. As-Is components are primarily provided for prior users
but imply no support (for example, defects, news group, and mailing lists).
Paul
news:819f0fe163e39537974805c21be077bc$1@www.eclipse.org...
> Hi Paul,
> soon..
> Asha wrote:
>> Hi Paul,
>> ="parent-widgetId";
>> Asha
>>> Hi Asha,
>>> Start with
>>> field. For example,
>>> Paul
>>>> Hi Paul,
>>>>> Hi Asha,
>>>>> Paul
>>>>>> Hi Paul,
>>>>>> There its written that we have to add these attributes in recorded
>>>>>> xml.can u plz clarify where i have to modify.
>>>>>> Regards,
>>>>>> Asha
>>>>>>> Hi Asha,
>>>>>>> and emit these new attributes. There is no extensibility in the AGR
>>>>>>> to support this.
>>>>>>> Paul
>>>>>>>> Hi,
>>>>>>>> recorded XML
>>>>>>>> "parent-contextId";
>>>>>>>> "parent-widgetId";
>>>>>>>> "parent-cell-x";
>>>>>>>> "parent-cell-y";
>>>>>>>> objectmine
>>>>>>>> sdfs/src/test.testsuite - E..." referenceId="0" return-code="0">
>>>>>>>> </shell>
>>>>>>>> return-code="0">
>>>>>>>> choiceId="item#0"/>
>>>>>>>> </command>
>>>>>>>> choiceId="item#2"/>
>>>>>>>> </command>
>>>>>>>> choiceId="item#1"/>
>>>>>>>> </shell>
>>>>>>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139844 is a reply to message #139833] Mon, 02 February 2009 06:46 Go to previous messageGo to next message
Ok..But i m using 4.4.0.2. For that what should i do?
> Hi Asha,
> Paul
>> Hi Paul,
>> soon..
>> Asha wrote:
>>> Hi Paul,
>>> ="parent-widgetId";
>>> Asha
>>>> Hi Asha,
>>>> Start with
>>>> field. For example,
>>>> Paul
>>>>> Hi Paul,
>>>>>> Hi Asha,
>>>>>> Paul
>>>>>>> Hi Paul,
>>>>>>> Regards,
>>>>>>> Asha
>>>>>>>> Hi Asha,
>>>>>>>> to support this.
>>>>>>>> Paul
>>>>>>>>> Hi,
>>>>>>>>> recorded XML
>>>>>>>>> "parent-contextId";
>>>>>>>>> "parent-widgetId";
>>>>>>>>> "parent-cell-x";
>>>>>>>>> "parent-cell-y";
>>>>>>>>> objectmine
>>>>>>>>> </shell>
>>>>>>>>> return-code="0">
>>>>>>>>> choiceId="item#0"/>
>>>>>>>>> </command>
>>>>>>>>> choiceId="item#2"/>
>>>>>>>>> </command>
>>>>>>>>> choiceId="item#1"/>
>>>>>>>>> </shell>
>>>>>>>>> </macro>
Re: Adding new attributs for recording and playing back the table items [message #139887 is a reply to message #139844] Tue, 03 February 2009 08:16 Go to previous message
Hi Asha,
Since this component is no longer supported, we are not in a position to
support or refactor this code due to resource constraints. If you
interested in refactoring the code to meet your requirements, you will need
to follow the pointers I gave in this thread and implement/debug your
changes.
Paul
news:be933be9b5ab91e06dd63f396644a381$1@www.eclipse.org...
>> Hi Asha,
>> an As-Is component. As-Is components are primarily provided for prior
>> users but imply no support (for example, defects, news group, and mailing
>> lists).
>> Paul
>>> Hi Paul,
>>> soon..
>>> Asha wrote:
>>>> Hi Paul,
>>>> ="parent-widgetId";
>>>> Asha
>>>>> Hi Asha,
>>>>> Start with
>>>>> field. For example,
>>>>> Paul
>>>>>> Hi Paul,
>>>>>>> Hi Asha,
>>>>>>> Paul
>>>>>>>> Hi Paul,
>>>>>>>> Regards,
>>>>>>>> Asha
>>>>>>>>> Hi Asha,
>>>>>>>>> Paul
>>>>>>>>>> Hi,
>>>>>>>>>> to add a set of new attributes to the <command> element in the
>>>>>>>>>> recorded XML
>>>>>>>>>> "parent-contextId";
>>>>>>>>>> "parent-widgetId";
>>>>>>>>>> "parent-cell-x";
>>>>>>>>>> "parent-cell-y";
>>>>>>>>>> objectmine
>>>>>>>>>> </shell>
>>>>>>>>>> return-code="0">
>>>>>>>>>> choiceId="item#0"/>
>>>>>>>>>> </command>
>>>>>>>>>> referenceId="93" choiceId="item#2"/>
>>>>>>>>>> </command>
>>>>>>>>>> referenceId="93" choiceId="item#1"/>
>>>>>>>>>> </shell>
>>>>>>>>>> </macro>
Previous Topic:java.exe crashes when launching (but it worked before)
Next Topic:Linux TPTP is not working properly
Current Time: Sat Jul 26 13:18:04 EDT 2025
Powered by FUDForum. Page generated in 0.08124 seconds
