Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and fragments - e.g. used for branding
RAP and fragments - e.g. used for branding [message #139581] |
Tue, 07 July 2009 12:09  |
Originally posted by: marco.waimer.uni-ulm.de
Dear RAP developers!
For an easier exchange of brandings, I want to use fragments. For example the
favicon.ico should come from the fragment. And there the first problem already
occurrs, a NullPointerException, since the favicon is searched for in the host
plugin (and not found).
at
org.eclipse.rap.ui.internal.branding.Branding.registerResour ces(Branding.java:171)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.registerBrandingResources(LifeCycleServiceHandlerConf igurer.java:258)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.applyBranding(LifeCycleServiceHandlerConfigurer.java: 221)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getTemplateOfStartupPage(LifeCycleServiceHandlerConfi gurer.java:63)
at
org.eclipse.rwt.internal.service.BrowserSurvey.renderScript( BrowserSurvey.java:89)
at
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:50)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:197)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:185)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:150)
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:48 )
at
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:36)
at
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:157)
at
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:101)
at org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
at
org.eclipse.rap.ui.internal.servlet.RequestHandler.service(R equestHandler.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:311)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:502)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:380)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:535)
at
org.mortbay.jetty.HttpConnection$RequestHandler.headerComple te(HttpConnection.java:865)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:539)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:520)
I currently use M7, but Branding.java itself was not changed for 4 months.
By the way, the same fragment idea works well with RCP, both from Eclipse and
standalone after built.
Is there something I am missing together with RAP and fragments? The fragments
are checked in the launch configuration and resolved during runtime.
Maybe someone could give me a little hint.
Greetings,
Marco
Re: RAP and fragments - e.g. used for branding [message #139708 is a reply to message #139697] |
Wed, 08 July 2009 06:21   |
Hello Ralf,
thank you for the fast response. Getting the favicon works now with a patched
Branding.java. But I think I found another problem with fragments. I have a .png
image that should come from the fragment. Therefor I use
ImageDescriptor.createFromURL(MyClass.class.getResource("myImage.png ")).createImage();
The problem seems to be the background mechanism for binary files like images.
Those were copied to the Eclipse installation directory into
\workspace\.metadata\.plugins\org.eclipse.rap.ui\context\ in a folder
representing the bundle. And the URL representing the folder name, which was
created in SecureAction.getURL (via
ClasspathManager#findLocalResourceImpl#findResourceImpl) contains a ':' (since
the port is 2), which leads to problems on my Windows machine, when trying to
register the image (see stacktrace).
When I use Graphics.getImage("somePath",
MyClass.class.getResourceAsStream("myImage.png")) directly, there are no
problems. So I have a workaround for me, but I thought you should know that.
java.io.IOException: Could not create directory structure:
C:\MyEclipseDirectory\workspace\.metadata\.plugins\org.eclip se.rap.ui\context\250.fwk23328673:2\the\package\of\my\image
at
org.eclipse.rwt.internal.resources.ResourceManagerImpl.creat eFile(ResourceManagerImpl.java:444)
at
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:427)
at
org.eclipse.rwt.internal.resources.ResourceManagerImpl.regis ter(ResourceManagerImpl.java:233)
at
org.eclipse.rap.ui.internal.servlet.ResourceManagerFactory$R esourceManagerWrapper.register(ResourceManagerFactory.java:1 30)
at
org.eclipse.swt.internal.graphics.ResourceFactory.createImag e(ResourceFactory.java:320)
at
org.eclipse.swt.internal.graphics.ResourceFactory.findImage( ResourceFactory.java:147)
at org.eclipse.rwt.graphics.Graphics.getImage(Graphics.java:130 )
at
org.eclipse.jface.resource.URLImageDescriptor.createImage(UR LImageDescriptor.java:124)
at org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:222)
at org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:200)
at MyClass.createControl(MyClass:123)
Marco
Ralf Sternberg schrieb:
> Ralf Sternberg wrote:
>> Rüdiger Herrmann wrote:
>>> did you try that with 1.3 final? Resolving the favIcon isn't done in the
>>> class Branding.
>> This does not work with current CVS. Filed bug 282744:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=282744
> It's fixed in CVS. Thanks for reporting this issue.
> Ralf
>> Ralf
>>>> example the favicon.ico should come from the fragment. And there the
>>>> first problem already occurrs, a NullPointerException, since the
>>>> favicon is searched for in the host plugin (and not found).
>>>> java.lang.NullPointerException
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> months.
>>>> Eclipse and standalone after built.
>>>> fragments are checked in the launch configuration and resolved during
>>>> runtime.
>>>> Greetings,
>>>> Marco
Re: RAP and fragments - e.g. used for branding [message #139720 is a reply to message #139708] |
Wed, 08 July 2009 06:33  |
Hi Marko,
there is already a bug about this issue:
282367: Exception on windows XP on creating images out of URL containing
"host:port"
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282367
Best,
Ivan
Marco Waimer wrote:
> Hello Ralf,
> patched Branding.java. But I think I found another problem with
> fragments. I have a .png image that should come from the fragment.
> Therefor I use
> images. Those were copied to the Eclipse installation directory into
> which was created in SecureAction.getURL (via
> ':' (since the port is 2), which leads to problems on my Windows
> machine, when trying to register the image (see stacktrace).
> no problems. So I have a workaround for me, but I thought you should
> know that.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Marco
>>>> in the
>>>> class Branding.
>> Ralf
>>> Ralf
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> months.
>>>>> runtime.
>>>>> Greetings,
>>>>> Marco
Current Time: Sat Jul 26 11:07:23 EDT 2025
Powered by FUDForum. Page generated in 0.07051 seconds
