Home » Archived » BIRT » Using BIRT charts as input in GEF style
Using BIRT charts as input in GEF style [message #139283] Sat, 04 March 2006 12:52 Go to next message
Charts are normally used to display output data. However, it is also
possible to use a chart for graphically create input data. A quick example
is the way that GEF elements can be created from a panel, they can be
moved and modified in size , and finally they can be deleted.
Here is the question: what is the optimal way to implement the GEF style
elements in BIRT charts?
The examples for interactivity do not include anything for moving elements.
Re: Using BIRT charts as input in GEF style [message #139595 is a reply to message #139283] Mon, 06 March 2006 09:19 Go to previous messageGo to next message
There is no such feature for now. I am not sure I really understand what you
are trying to achieve when you mention "Graphically create input data". I am
familiar with GEF, but I don't see exactly how this would work within a
chart. Could you elaborate your thought on that?
David
"Ali" <saveez@hotmail.com> wrote in message
news:87e5df655ce30b66fe80eb8a96004619$1@www.eclipse.org...
> elements.
Re: Using BIRT charts as input in GEF style [message #139626 is a reply to message #139595] Mon, 06 March 2006 10:06 Go to previous messageGo to next message
David,
Here is a simple example:
Assume a bar chart.
(1) Creating bars: from a panel the user can select a 'bar element' and
drag and drop it to the chart
(2) Manipulating data: by selecting a bar, the user can move/resize the bar
(3) Deleting data: selecting a bar allows the user to delete the data
graphically.
The above features may be found in GEF. Hope the example helps the
question now.
-Ali
David Michonneau wrote:
> David
>> elements.
Re: Using BIRT charts as input in GEF style [message #139728 is a reply to message #139626] Mon, 06 March 2006 11:21 Go to previous message
Thanks, I see what you mean. There is no way to do this now, in fact it
seems a different product altogether. I imagine it can be implemented in GEF
to create static charts. The real challenge would be to map those GEF
figures to a BIRT Chart model, that seems quite difficult to render exactly
the same thing using the chart engine and Draw2D Figures.
David
"Ali" <saveez@hotmail.com> wrote in message news:duhj5d$vpv$1@eclipse.org...
> David,
> Assume a bar chart.
> bar
> graphically.
> question now.
> -Ali
>> Hi,
>> you are trying to achieve when you mention "Graphically create input
>> data". I am familiar with GEF, but I don't see exactly how this would
>> work within a chart. Could you elaborate your thought on that?
>> Thanks,
>> David
>>> example is the way that GEF elements can be created from a panel, they
>>> can be moved and modified in size , and finally they can be deleted.
>>> elements.
Previous Topic:ODA for EJBQL available?
Next Topic:Report concurrent execution
Current Time: Sat Jul 26 08:56:58 EDT 2025
Powered by FUDForum. Page generated in 0.05461 seconds
