Home » Modeling » TMF (Xtext) » [XBase] Corss-referencing function definitions
[XBase] Corss-referencing function definitions [message #1395735] Mon, 07 July 2014 06:12 Go to next message
I have created a simple DSL [0] for defining functions (See [1] for example). Also, defined mapping to the Java model [2]. Do I need to override some method in the XBaseScopeProvider to enable cross-referencing of functions [3] ?
I have looked at few examples [4], however I haven't found any clue so far. Any suggestions/tips ?
[0] https://github.com/nbhusare/XBase-test/blob/master/org.xtext.example.function/src/org/xtext/example/function/FunctionDsl.xtext
[1] function getBooksInLibrary (Library library) : List<Book> {
return library.books
[2] https://github.com/nbhusare/XBase-test/blob/master/org.xtext.example.function/src/org/xtext/example/function/jvmmodel/FunctionDslJvmModelInferrer.xtend
[3] function getBook (Library library, String bookName) : Book {
for(Book book : getBooksInLibrary(library)) { // Cross-referencing getBooksInLibrary()
if (book.name.equals(bookName)) {
return book;
return null
[4]
http://www.eclipse.org/Xtext/7languagesDoc.html
Thanks in advance.
Re: [XBase] Corss-referencing function definitions [message #1395957 is a reply to message #1395735] Mon, 07 July 2014 13:07 Go to previous messageGo to next message
On 07/07/2014 12:12, Neeraj Bhusare wrote:
> [0]
> [2]
> getBooksInLibrary() if (book.name.equals(bookName)) {
> return book; } } return null }
> [4]
> Thanks in advance.
if you infer things correctly and consistently in the jvm model inferrer
you don't need to tweak the xbase scope provider... are you asking
because something is not working in your case?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: [XBase] Corss-referencing function definitions [message #1396290 is a reply to message #1395957] Tue, 08 July 2014 01:14 Go to previous messageGo to next message
Hi Lorenzo,
Thanks for responding. In the function below, the call to "getBooksInLibrary(library)" doesn't seem to work. Similar to getBook, getBooksInLibrary is a function definition.
In the model inferrer [2], I have mapped to a Java class, and the function is mapped to a Java function. This allows me to do something like new getBooksInLibrary().getBooksInLibrary(library), however, this is not what I need.
In short, the method getBooksInLibrary() should show up when I perform content-assist in the method getBook.
return book;
return null
[Updated on: Tue, 08 July 2014 01:29] by Moderator
Re: [XBase] Corss-referencing function definitions [message #1396378 is a reply to message #1396290] Tue, 08 July 2014 04:08 Go to previous messageGo to next message
On 08/07/2014 07:14, Neeraj Bhusare wrote:
> Hi Lorenzo,
> function is mapped to a Java function. I believe I have done it correctly.
mh... but are Library and Book types visible in your test program? Are
they imported?
Xtext Book:
Re: [XBase] Corss-referencing function definitions [message #1396433 is a reply to message #1396378] Tue, 08 July 2014 05:34 Go to previous messageGo to next message
Yes, the Library and Book types are imported and are visible inside the function definition. To add, these types are defined using the Entity Dsl.
https://github.com/nbhusare/XBase-test/blob/master/org.xtext.example.entity/src/org/xtext/example/entity/EntityDsl.xtext
https://github.com/nbhusare/XBase-test/blob/master/org.xtext.example.entity/src/org/xtext/example/entity/jvmmodel/EntityDslJvmModelInferrer.xtend
Re: [XBase] Corss-referencing function definitions [message #1397774 is a reply to message #1396290] Thu, 10 July 2014 02:28 Go to previous message
> Hi Lorenzo,
I've just noted that in your function dsl
you can define a single function in a FunctionModel
each function is inferred as a method inside an inferred class, thus
from a function you can't simply access another function (because that
corresponds to a method in another class); you should create an instance
of the inferred class...
so you probably need to customize the scoping...
you might also have to rethink your design... first of all, since these
functions should be callable without an object you might want to infer
them as static methods. After that it could probably be enough to make
all the inferred classes available as implicit imports.
cheers
Lorenzo
Xtext Book:
Previous Topic:Xtext Editor / CellEditor in e4 RCP
Next Topic:Is there a way to infer a non-JVM dsl model
Current Time: Thu Jul 24 22:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.05115 seconds
