SAX2 driver class org.apache.xerces.parsers.SAXParser not found [message #1395796] |
Mon, 07 July 2014 08:08  |
I try to build a feature containing a graphical editor based on Sirius, to be able to install it in an existing RCP application.
The problem is that when I try to open an editor containing 'Dot' representations, I have the following exception :
java.io.IOException: SAX2 driver class org.apache.xerces.parsers.SAXParser not found
at org.apache.batik.dom.util.SAXDocumentFactory.createDocument(Unknown Source)
at org.apache.batik.dom.svg.SAXSVGDocumentFactory.createDocument(Unknown Source)
at org.eclipse.sirius.diagram.ui.tools.api.figure.SVGFigure.loadDocument(SVGFigure.java:90)
at org.eclipse.sirius.diagram.ui.tools.api.figure.SVGFigure.getDocument(SVGFigure.java:105)
at org.eclipse.sirius.diagram.ui.tools.api.figure.BundledImageFigure.updateDocumentColors(BundledImageFigure.java:194)
at org.eclipse.sirius.diagram.ui.tools.api.figure.BundledImageFigure.updateColors(BundledImageFigure.java:147)
at org.eclipse.sirius.diagram.ui.tools.api.figure.BundledImageFigure.refreshFigure(BundledImageFigure.java:311)
at org.eclipse.sirius.diagram.ui.tools.api.figure.BundledImageFigure.createImageFigure(BundledImageFigure.java:119)
at org.eclipse.sirius.diagram.ui.internal.edit.parts.BundledImageEditPart.createNodeShape(BundledImageEditPart.java:133)
at org.eclipse.sirius.diagram.ui.internal.edit.parts.BundledImageEditPart.createNodeFigure(BundledImageEditPart.java:189)
at org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPart.createFigure(ShapeNodeEditPart.java:90)
If I don't misunderstood, my plugins included in this feature depend on the Sirius plugins, which depend themself on the Apache Batik plugins. But the Batik plugin references the Apache Xerces driver as an optional Import-Package :
Bundle-SymbolicName: org.apache.batik.dom
Import-package: org.w3c.dom,org.apache.xerces.parsers;resolution:=optional
Is it normal that the Sirius plugin doesn't depend on the Xerces plugin to ensure that the optional package is resolved ?
Jonathan
Re: SAX2 driver class org.apache.xerces.parsers.SAXParser not found [message #1396416 is a reply to message #1395796] |
Tue, 08 July 2014 05:08   |
Hi Jonathan,
I have just seen that you have created Bug 439095 [1] to report the
issue explained in this thread.
We will look into the issue and answer to your question on the bugzilla.
As a first workaround, it is working if your editor plugin declares the
dependance to xerces as required ? See the "Xerces in Eclipse" wiki page
[2].
Maxime
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=439095
[2] https://wiki.eclipse.org/Orbit/Xerces_in_Eclipse
Le 07/07/2014 14:08, Jonathan Dumont a écrit :
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Import-Package :
> Regards,
> Jonathan
Re: SAX2 driver class org.apache.xerces.parsers.SAXParser not found [message #1396421 is a reply to message #1395796] |
Tue, 08 July 2014 05:17   |
Hi Jonathan,
As an additional answer, please note that RCP is not a primary target
for Sirius, and so be aware that various parts of Sirius depend on the
workspace and workbench.
Maxime
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Import-Package :
> Regards,
> Jonathan
Re: SAX2 driver class org.apache.xerces.parsers.SAXParser not found [message #1396429 is a reply to message #1396421] |
Tue, 08 July 2014 05:29  |
Yes I have also created the following bug : 439095, as it has a real impact on our product. May it won't be confirmed as a bug, as it's a bit tricky ... And I can understand that it's not the main target for Sirius.
Juste to answer to your question, I have a workaround : I have create my own plugin containing the jar provided by Orbit to offer the needed packages. It's not the best solution I think but when I just add the dependencies to the Orbit plugins in my plugin, it doesn't work. The Apache Xerces plugin from Orbit is well included during my feature installation, but the driver is still not found.
Note : I will continue to fill the bug if needed instead of this thread.
[Updated on: Tue, 08 July 2014 05:32] by Moderator
FUDForum. Page generated in 0.06428 seconds
