Home » Modeling » TMF (Xtext) » Error after Xtext Utils add
Error after Xtext Utils add [message #1395729] Mon, 07 July 2014 06:01 Go to next message
I receive the following error since I install xtext utils into my project. I can now neither generate the grammar (Mwe2) nor generate the Xtext artifacts.
I have been trying to fix it somehow, but all my attemps go wrong.
Any ideas what I'm doing wrong?
EDIT: I did receive a missing ANTLR notification the first time I tried to compile the grammar and it was suggested that I download it. I confirmed with y (yes) and received an error.
0    [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering platform uri '/Users/stefan/Documents/workspace/PhD-Stefan/eclipse_workspace'
122  [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
431  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
438  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
465  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
465  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
2606 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
2639 [main] INFO  ipse.emf.mwe.utils.DirectoryCleaner  - Cleaning /Users/stefan/Documents/workspace/PhD-Stefan/eclipse_workspace/ch.cern.enice.ctl/../ch.cern.enice.ctl/src-gen
2642 [main] INFO  ipse.emf.mwe.utils.DirectoryCleaner  - Cleaning /Users/stefan/Documents/workspace/PhD-Stefan/eclipse_workspace/ch.cern.enice.ctl/../ch.cern.enice.ctl/model
2642 [main] INFO  ipse.emf.mwe.utils.DirectoryCleaner  - Cleaning /Users/stefan/Documents/workspace/PhD-Stefan/eclipse_workspace/ch.cern.enice.ctl/../ch.cern.enice.ctl.ui/src-gen
2958 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - org.eclipse.internal.xtend.expression.ast.Identifier.getValue()Ljava/lang/String;
java.lang.NoSuchMethodError: org.eclipse.internal.xtend.expression.ast.Identifier.getValue()Ljava/lang/String;
	at org.eclipse.internal.xpand2.parser.XpandFactory.createTextStatement(XpandFactory.java:77)
	at org.eclipse.internal.xpand2.parser.XpandParser.text(XpandParser.java:1325)
	at org.eclipse.internal.xpand2.parser.XpandParser.template(XpandParser.java:254)
	at org.eclipse.internal.xpand2.parser.XpandParseFacade.file(XpandParseFacade.java:40)
	at org.eclipse.internal.xpand2.parser.XpandParseFacade.file(XpandParseFacade.java:27)
	at org.eclipse.xpand2.XpandExecutionContextImpl$1.parse(XpandExecutionContextImpl.java:173)
	at org.eclipse.xtend.expression.ResourceManagerDefaultImpl.loadResource(ResourceManagerDefaultImpl.java:64)
	at org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(XpandExecutionContextImpl.java:293)
	at org.eclipse.xpand2.XpandExecutionContextImpl.findTemplate(XpandExecutionContextImpl.java:280)
	at org.eclipse.xpand2.XpandExecutionContextImpl.findDefinition(XpandExecutionContextImpl.java:232)
	at org.eclipse.xpand2.XpandFacade.evaluate2(XpandFacade.java:57)
	at org.eclipse.xtext.generator.AbstractGeneratorFragment.generate(AbstractGeneratorFragment.java:42)
	at org.eclipse.xtext.generator.DefaultGeneratorFragment.generate(DefaultGeneratorFragment.java:122)
	at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:154)
	at org.eclipse.xtext.generator.Generator.generate(Generator.java:396)
	at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:138)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
[Updated on: Mon, 07 July 2014 06:02] by Moderator
Re: Error after Xtext Utils add [message #1400595 is a reply to message #1395729] Mon, 14 July 2014 08:39 Go to previous message
Hi Stefan Klikovits,
You download the antlr jar by yourself and place it in lib folder in the plugin(create lib folder)
and add the jar by build path---> configure Build Path. update classpath by PDE tools(*context menu).
After doing the above, generate.
Girish
[Updated on: Mon, 14 July 2014 08:41] by Moderator
Previous Topic:[Xtext] Need help with implicit imports
Next Topic:Using Existing Ecore in XText
Current Time: Sat Jul 26 23:19:33 EDT 2025
Powered by FUDForum. Page generated in 0.22999 seconds
