Home » Archived » Visual Editor (VE) » VE does not show up in my 3.3 installation
VE does not show up in my 3.3 installation [message #139510] Thu, 02 August 2007 14:26 Go to next message
I installed Eclipse 3.3 and then I added the files from
ve_eclipse_33_win32.zip which I got from
http://www.ehecht.com/eclipse_ve/ve.html and still saw nothing. Any ideas
why?
Rob
Re: VE does not show up in my 3.3 installation [message #139521 is a reply to message #139510] Thu, 02 August 2007 14:49 Go to previous messageGo to next message
Rob,
Did you run eclipse.exe -clean after unzipping the new plugins so that
the old configuration is cleaned up and a new configuration to that
knows about the new plugins is created?
> why?
> Rob
Re: VE does not show up in my 3.3 installation [message #139540 is a reply to message #139521] Fri, 03 August 2007 10:12 Go to previous messageGo to next message
Yes, I tried -clean and still nothing.
The Eclipse version I have is
Version: 3.3.0
Build id: 120070625-1500
The zip file for the VE upgrade has paths specifying
ve_eclipse_33_win32\features and \plugins. I extracted the \features files
to the features folder under eclipse and the \plugins files to the plugings
folder under eclipse. All the other features I have on my system are in
their own subfolder under features. I tried creating folders with the same
name as the jar files and then extracting the contents of the jar files to
those folders and still I got nothing.
Is there anything else that I can try to get VE to show up?
Rob
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f8t90c$8bl$2@build.eclipse.org...
> Rob,
> Did you run eclipse.exe -clean after unzipping the new plugins so that the
> old configuration is cleaned up and a new configuration to that knows
>> why?
>> Thanks,
>> Rob
Re: VE does not show up in my 3.3 installation [message #139552 is a reply to message #139540] Fri, 03 August 2007 10:16 Go to previous messageGo to next message
--------------000204060108000505030604
Rob,
Are you using a 5.0 JRE? Try running with -clean -debug and have a
close look at the Error log view for clues...
> Version: 3.3.0
> Rob
>> Rob,
>>> why?
>>> Thanks,
>>> Rob
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Rob,<br>
<br>
Are you using a 5.0 JRE?&nbsp;&nbsp; Try running with -clean -debug and have a
close look at the Error log view for clues...<br>
<br>
<br>
Rob Roy wrote:
<blockquote cite="mid:f8vd43$6tp$1@build.eclipse.org" type="cite">
<pre wrap="">Yes, I tried -clean and still nothing.
Version: 3.3.0
Rob
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:f8t90c$8bl$2@build.eclipse.org">news:f8t90c$8bl$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Rob,
Rob Roy wrote:
</pre>
<pre wrap="">I installed Eclipse 3.3 and then I added the files from
<a class="moz-txt-link-freetext" href="http://www.ehecht.com/eclipse_ve/ve.html">http://www.ehecht.com/eclipse_ve/ve.html</a> and still saw nothing. Any ideas
why?
Rob
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000204060108000505030604--
Re: VE does not show up in my 3.3 installation [message #139562 is a reply to message #139552] Fri, 03 August 2007 12:42 Go to previous message
Thanks. The hint about the Error log view helped (I've never used it
before). I was missing some dependencies. I see VE now.
Thanks again,
Rob
news:f8vdcn$777$2@build.eclipse.org...
> Rob,
>> Version: 3.3.0
>> files
>> plugings
>> same
>> to
>> Thanks,
>> Rob
>>> Rob,
>>> the
>>>> ideas
>>>> why?
>>>> Thanks,
>>>> Rob
Re: VE does not show up in my 3.3 installation [message #616361 is a reply to message #139510] Thu, 02 August 2007 14:49 Go to previous message
Rob,
> why?
> Rob
Re: VE does not show up in my 3.3 installation [message #616364 is a reply to message #139521] Fri, 03 August 2007 10:12 Go to previous message
Version: 3.3.0
Rob
> Rob,
>> why?
>> Thanks,
>> Rob
Re: VE does not show up in my 3.3 installation [message #616365 is a reply to message #139540] Fri, 03 August 2007 10:16 Go to previous message
Rob,
> Version: 3.3.0
> Rob
>> Rob,
>>> why?
>>> Thanks,
>>> Rob
<html>
<head>
</head>
Rob,<br>
<br>
<br>
<br>
Version: 3.3.0
Rob
</pre>
<pre wrap="">Rob,
Rob Roy wrote:
</pre>
why?
Rob
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: VE does not show up in my 3.3 installation [message #616366 is a reply to message #139552] Fri, 03 August 2007 12:42 Go to previous message
Thanks again,
Rob
> Rob,
>> Version: 3.3.0
>> files
>> plugings
>> same
>> to
>> Thanks,
>> Rob
>>> Rob,
>>> the
>>>> ideas
>>>> why?
>>>> Thanks,
>>>> Rob
Previous Topic:VE does not show up in my 3.3 installation
Next Topic:VE do not show the class editor
Current Time: Sat Jul 26 08:08:17 EDT 2025
Powered by FUDForum. Page generated in 0.18341 seconds
