How to update GUI from Inherit Class [message #1395194] |
Sun, 06 July 2014 10:37  |
I have 2 panels: Panel1 and Panel2, the Panel2 inherit from Panel1. In constructor of Panel1, I create 3 JLabels and display them in order Label1-Label2-Label3. When I switch from Source Tab to Design Tab, the Preview Window display corectly what I want
In constructor of Panel2, I want to custom Panel1, so, I change order of 3 JLabels, like this:
public class Panel2 extends Panel1 {
public Panel2() {
super();
reverse();
but when I switch from Source Tab to Design Tab, int Preview Window, nothing change
Attachment: Panel2.java
(Size: 0.11KB, Downloaded 184 times)
Attachment: 1.jpg
(Size: 125.37KB, Downloaded 991 times)
Attachment: 2.jpg
(Size: 204.42KB, Downloaded 839 times)
Attachment: Panel1.java
(Size: 2.31KB, Downloaded 319 times)
Re: How to update GUI from Inherit Class [message #1399051 is a reply to message #1398289] |
Fri, 11 July 2014 20:49  |
Sure. All statically defined components and properties are inherited (as you can see by the fact that the widgets all show up in the subclass).
If you embed Panel2 in another class as a custom component, it will show up with those components reversed as you wish.
At design time, however, the reverse() method means nothing and is ignored.
FUDForum. Page generated in 0.04242 seconds
