Home » Language IDEs » PHP Development Tools (PDT) » Problem with code assist for arrays
Problem with code assist for arrays [message #1393128] Thu, 03 July 2014 05:26 Go to next message
I am a bit puzzled with array hinting for code assist. Consider this synthetic example :
class foo {
	public $value;
class bar {
	public $foos;
	 * @return foo[]
	public function getHintedFoos(){
		return $this->foo;
	public function getUnhintedFoos(){
		return $this->foo;
$obj_bar = new bar();
$obj_bar->getHintedFoos()[0]->		// WORKS: code assist uses @return as hint
$obj_bar->getUnhintedFoos()[0]->	// DOES NOT WORK, OBVIOUSLY: code assist has no clue what is returned
/* @var $single_foo foo */
$single_foo = $obj_bar->getUnhintedFoos();
$single_foo->						// WORKS: code assist uses @var as hint
/* @var $array_foos foo[] */
$array_foos = $obj_bar->getUnhintedFoos();
$array_foos[0]->					// DOES NOT WORK, WHY???
Is there a bug in PDT (3.3.0.201406110111) or are my hints in wrong syntax?
Re: Problem with code assist for arrays [message #1393759 is a reply to message #1393128] Fri, 04 July 2014 04:19 Go to previous messageGo to next message
First problem, use php doc for $foo field:
Change from
class bar {
	public $foos;
to
class bar {
     * @var foo[]
    public $foo;
Second, pdt vardoc doesn't support array hint. You can create feature request on bugzilla: bugs.eclipse.org
Re: Problem with code assist for arrays [message #1393884 is a reply to message #1393759] Fri, 04 July 2014 08:22 Go to previous messageGo to next message
Dawid Pakula wrote on Fri, 04 July 2014 04:19
I can't. Foo and bar lives somewhere deep in a large 3rd party framework, and arrays of foo (sometimes even baz) instances are returned via the same factory method. My idea was to make hinting by using vardoc as I know excatly what I will get, but unfortunately arrays are not supported.
[Updated on: Fri, 04 July 2014 08:22] by Moderator
Re: Problem with code assist for arrays [message #1395071 is a reply to message #1393884] Sun, 06 July 2014 05:58 Go to previous message
I reported this problem on bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=438972
Previous Topic:Eclipse 3.8 on Xubuntu 14.04 PHP development crash with no reason
Next Topic:how to configure php eclipse to use apache
Current Time: Sun Jul 20 22:47:24 EDT 2025
Powered by FUDForum. Page generated in 0.05090 seconds
