Home » Modeling » EMF » [CDO] Using conflict resolver
[CDO] Using conflict resolver [message #1366176] Mon, 19 May 2014 03:32 Go to next message
Hello all,
I'm having trouble using any sort of ConflictResolver, I've started to use the AbstractObjectConflictResolver.ThreeWayMerge but I don't know what I'm expected to write in the "resolveConflict(CDOObject arg0, CDORevisionDelta arg1, List<CDORevisionDelta> arg2)" method. I'm having trouble finding any guideline for that, because I really don't know how to use the CDORevisionDelta object.
If you can point me to an snippet or, even better a tutorial, it would be great.
Thank you.
Re: [CDO] Using conflict resolver [message #1394745 is a reply to message #1366176] Sat, 05 July 2014 17:06 Go to previous messageGo to next message
You can find an example here: https://github.com/eclipse/cdo/blob/master/plugins/org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/ConflictResolverTest.java
It shows how to use CDOMergingConflictResolver, which works 'out of the box' and where you have nothing to implement to solve simple conflicts.
HTH,
Bernard.
Re: [CDO] Using conflict resolver [message #1436782 is a reply to message #1394745] Fri, 03 October 2014 07:51 Go to previous message
Thank you Bernard.
Previous Topic:how create CDO branches
Next Topic:[Texo] generating a default value for an attribute
Current Time: Sat Jul 26 11:29:47 EDT 2025
Powered by FUDForum. Page generated in 0.07106 seconds
