XMLProcessor.load(inpustream,map) throwing IOWrapped Exception [message #1393654] |
Fri, 04 July 2014 00:37  |
I am trying to process a xml file using xsd file.
In xsd file i have an element type enumeration. If i give some wrong value it is throwing me IOWrapped exception.
Exception contains what is the given value which is wrong but i need which element has received this value. so that i can parse the exception and do some handling.
Can any one how we can find which element has the IOException?
Thanks in advance.
Re: XMLProcessor.load(inpustream,map) throwing IOWrapped Exception [message #1394369 is a reply to message #1393654] |
Sat, 05 July 2014 02:41  |
Shakeer,
I'm not sure your goal, but you can see from where the exception is
thrown, so set a breakpoint and see where the problem is detected and
what you might do to specialize that to add extra logic. Note that when
loading a resource throws and exception, the resource is still loaded
and populated to the extent possible...
On 04/07/2014 4:39 PM, shakeer hussan wrote:
> Thanks in advance.
FUDForum. Page generated in 0.06271 seconds
