Home » Modeling » TMF (Xtext) » Upgrade from 2.4.3 to 2.6.2 Problem(1) No implementation for org.eclipse.xtext.ui.shared.contribution.ISharedStateContributionRegistry was bound.)
Upgrade from 2.4.3 to 2.6.2 Problem [message #1393858] Fri, 04 July 2014 07:32 Go to next message
We ran xText 2.4.3 with Eclipse 3.7.1 and it worked well.
Running the same xText Project with Eclipse 4.3.1 and the latest xText Version (2.6.2.) results in an error:
com.google.inject.CreationException: Guice creation errors:
  while locating org.eclipse.xtext.ui.shared.contribution.ISharedStateContributionRegistry
    for parameter 0 at org.eclipse.xtext.builder.trace.StorageAwareTrace.initializeContributions(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.builder.trace.StorageAwareTrace>
    for field at org.eclipse.xtext.builder.trace.TraceForStorageProvider.traceToSourceProvider(Unknown Source)
  while locating org.eclipse.xtext.builder.trace.TraceForStorageProvider
    for field at org.eclipse.xtext.builder.EclipseResourceFileSystemAccess2.fileBasedTraceInformation(Unknown Source)
  at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
2) No implementation for org.eclipse.xtext.ui.shared.contribution.ISharedStateContributionRegistry was bound.
    for parameter 0 at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.initializeContributions(Unknown Source)
2 errors
	at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
	at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:154)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
	at com.google.inject.Guice.createInjector(Guice.java:95)
	at com.google.inject.Guice.createInjector(Guice.java:72)
	at com.google.inject.Guice.createInjector(Guice.java:62)
	at ch.basler.service.dsl.ServiceDSLStandaloneSetupGenerated.createInjector(ServiceDSLStandaloneSetupGenerated.java:28)
	at ch.basler.service.dsl.ServiceDSLStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(ServiceDSLStandaloneSetupGenerated.java:22)
	at ch.basler.service.dsl.ServiceDSLInjectorProvider.internalCreateInjector(ServiceDSLInjectorProvider.java:34)
	at ch.basler.service.dsl.ServiceDSLInjectorProvider.getInjector(ServiceDSLInjectorProvider.java:27)
	at ch.basler.service.dsl.ServiceDSLInjectorProvider.setupRegistry(ServiceDSLInjectorProvider.java:42)
	at org.eclipse.xtext.junit4.XtextRunner.methodBlock(XtextRunner.java:43)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Actions taken to solve the problem:
rebuild all, regenerate xText Artifacts, check the release note
Any hints, how to solve that?
Thanks a lot for your help
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1393983 is a reply to message #1393858] Fri, 04 July 2014 11:33 Go to previous messageGo to next message
sure you updated org.eclipse.ui.shared as well.
there SharedModule class should contain the binding
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1395845 is a reply to message #1393983] Mon, 07 July 2014 09:38 Go to previous messageGo to next message
Hi Christian,
thanks for the answer.
I suppose you mean
which should be replaced.
Yes org.eclipse.xtext.ui.shared is upgraded as well.
I tried something differrent to be sure to exclude all the update problems:
I downloaded the whole bundle (Eclipse and xText together) but the problem persists
Furthermore I generated a new xText Project, included some xtend code - and it worked.
It seems that this is an upgrade issue for existing projects younger that 2.5
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1395861 is a reply to message #1395845] Mon, 07 July 2014 09:59 Go to previous messageGo to next message
did you compare the 2 projects?
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1395874 is a reply to message #1395861] Mon, 07 July 2014 10:23 Go to previous messageGo to next message
yes, I did and found a lot of differences - due to the different DSL naming. But no hint which led me to a solution.
should there be a classpath dependency between the plugin, and org.eclipse.xtext.ui.shared?
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1395875 is a reply to message #1395874] Mon, 07 July 2014 10:24 Go to previous messageGo to next message
or do you have a hint for what to search?
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1395911 is a reply to message #1395875] Mon, 07 July 2014 11:30 Go to previous messageGo to next message
You could do a breakpoint in the corresponding line of the Module that does the binding. is it ever called?
if you want to nail down the comparison then compare the activator classes
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1396527 is a reply to message #1395911] Tue, 08 July 2014 08:29 Go to previous messageGo to next message
do you have a hint, at which point exactly the injection of the ISharedStateContributionRegistry is expected?
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1396554 is a reply to message #1396527] Tue, 08 July 2014 09:24 Go to previous messageGo to next message
das i said: the class SharedModule should provide the binding
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1396557 is a reply to message #1396554] Tue, 08 July 2014 09:25 Go to previous messageGo to next message
P.S: do you use mydslinjectorprovider to run a Ui Test?
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1396581 is a reply to message #1396557] Tue, 08 July 2014 10:07 Go to previous messageGo to next message
yes I use the injectorprovider. Our DSL is called ServiceDSL
Declartion of the unit test class:
import ch.basler.service.dsl.ServiceDSLInjectorProvider
import ch.basler.service.dsl.serviceDSL.ComplexTypeDef
import ch.basler.service.dsl.serviceDSL.Model
import com.google.inject.Inject
import org.eclipse.xtext.junit4.InjectWith
import org.eclipse.xtext.junit4.XtextRunner
import org.eclipse.xtext.junit4.util.ParseHelper
import org.junit.Test
import org.junit.runner.RunWith
import static org.junit.Assert.*
@InjectWith(typeof(ServiceDSLInjectorProvider))
@RunWith(typeof(XtextRunner))
class ITypeBaseTest {
SharedModule: neither configure() nor the constructor is called when I execute the unit test.
But: if i run ServiceDSL in runtimeEclipseMode SharedModule gets called (configure()), i can see in the debugger the execution of the line:
bind(ISharedStateContributionRegistry.class).to(SharedStateContributionRegistryImpl.class);
gets called - but the problem persists.
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1396690 is a reply to message #1396581] Tue, 08 July 2014 12:52 Go to previous messageGo to next message
why dont you use the uiinjectorprovider then?
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1398022 is a reply to message #1396690] Thu, 10 July 2014 09:45 Go to previous messageGo to next message
we found the originator of the problem:
in the DSLModule declaration we override like the following:
public class ServiceDSLRuntimeModule extends ch.basler.service.dsl.AbstractServiceDSLRuntimeModule {
 public Class<? extends EclipseResourceFileSystemAccess2> bindEclipseFSA() {
   return UTF8EclipseFilesSystemAccess.class;
we need this as otherwise the generated sourcecode does not understand german umlauts.
UTF8EclipseFilesSystemAccess:
public class UTF8EclipseFilesSystemAccess extends EclipseResourceFileSystemAccess2 {
  private IProject project;
  private File projectFolder;
  protected StringInputStream getInputStream(String contentsAsString, String encoding) {
    return super.getInputStream(contentsAsString, "UTF-8");
  public void setProject(IProject project) {
    this.project = project;
    IFile dotProject = project.getFile(".project");
    URI dotProjectURI = dotProject.getRawLocationURI();
    File dotProjectFile = new File(dotProjectURI);
    projectFolder = dotProjectFile.getParentFile();
    super.setProject(project);
  public IProject getProject() {
    return project;
  public File getProjectFolder() {
    return projectFolder;
  public File getJavaIOFile(String path) {
    return getJavaIOFile(path, DEFAULT_OUTPUT);
  private File getJavaIOFile(String path, String outputConfiguration) {
    org.eclipse.emf.common.util.URI uri = getURI(path, outputConfiguration);
    List<String> segmentsList = uri.segmentsList();
    List<String> subList = segmentsList.subList(2, segmentsList.size());
    File ret = getProjectFolder();
    for (String segment : subList) {
      ret = new File(ret, segment);
    return ret;
if I remove the binding, the generation works fine - but the umlauts don't work.
Any ideas, what's wrong with the implementation?
Cheers
Frank
Re: Upgrade from 2.4.3 to 2.6.2 Problem [message #1398042 is a reply to message #1398022] Thu, 10 July 2014 10:19 Go to previous message
the EclipseFilesSystemAccess is meant to be used in eclipse and not at runtime (standalone)
so the binding should be in the uimodule.
in the runtime module you should bind a subclass off JavaIoFileSystemaccess
Previous Topic:clean temp folders created by xtext-maven-plugin
Next Topic:new run configuration eclipse from web
Current Time: Sat Jul 19 01:42:11 EDT 2025
Powered by FUDForum. Page generated in 0.04971 seconds
