Home » Archived » Jubula » Change AUT Config Path before executing test
Change AUT Config Path before executing test [message #1393503] Thu, 03 July 2014 18:39 Go to next message
Is it possible to change the AUT executable path, in the AUT config before running a test?
For example, I'm testing one installer, and after running the installer I would need to run the uninstaler, but the uninstaller path will depend on the path you supplied to the installer. <-This means, it will vary, I can't have a static AUT Config for this.
So, is there a way of changing the AUT Config of the Uninstaller Test Project, just before running it?
Thanks ind Advance.
Re: Change AUT Config Path before executing test [message #1393689 is a reply to message #1393503] Fri, 04 July 2014 01:51 Go to previous messageGo to next message
I can't think of a way I know right now, but I'll ask.
Alex
Re: Change AUT Config Path before executing test [message #1393725 is a reply to message #1393689] Fri, 04 July 2014 03:14 Go to previous messageGo to next message
I asked, and the suggestion is to start your AUT via a script that can read an environment variable. Then you can set the environment variable to be the flexible part of your path.
Hope that helps!
Alex
Re: Change AUT Config Path before executing test [message #1395916 is a reply to message #1393725] Mon, 07 July 2014 11:44 Go to previous messageGo to next message
Thanks for looking into that Alex, I'll see what I can do with the script approach
Edit: I got another question,
I have a program that changes its behaviour depending if it can find certain files(or environmental variables) in the system, so if it finds these files it send you to a determined screen, if it doesn.t it sends you to another screen.
Is there a way to check in the Jubula test if a file/variable exist in order to choose which testsuite to use?
Edit2: Also, is it possible to choose a variable depending on the OS I have running in the machine?
[Updated on: Mon, 07 July 2014 12:22] by Moderator
Re: Change AUT Config Path before executing test [message #1395960 is a reply to message #1395916] Mon, 07 July 2014 13:13 Go to previous messageGo to next message
For the AUT config path, you can also modify the database directly (quite easy if you're already using ANT to launch tests) :
update aut_conf_attr
set attr_value = 'XXXX'
where attr_key = 'WORKING_DIR';
set attr_value = 'XXXXX\\YYYY.exe'
where attr_key = 'EXECUTABLE';
you may want to add more conditions in the where clauses in order to be sure to modify only the project you really want to modify.
Re: Change AUT Config Path before executing test [message #1397518 is a reply to message #1395960] Wed, 09 July 2014 17:05 Go to previous messageGo to next message
Thanks, I'll look into that
Re: Change AUT Config Path before executing test [message #1397531 is a reply to message #1397518] Wed, 09 July 2014 17:31 Go to previous messageGo to next message
For checking whether a file or variable exists, you can execute a script as an external command and check its return value.
Re: Change AUT Config Path before executing test [message #1397576 is a reply to message #1397531] Wed, 09 July 2014 19:08 Go to previous messageGo to next message
But can you use that return value to 'branch' your testing?(go through a different flow than what you would normally do?)
Thanks in Advance
Fernando
Re: Change AUT Config Path before executing test [message #1397592 is a reply to message #1397576] Wed, 09 July 2014 19:44 Go to previous message
You can use an event handler to do that; however, if the script's exit code does not match your expected value, then the test case that calls the script will still show up as a failure.
You might be able to get around this by storing your command in a variable, using the value of that variable as your COMMAND parameter, and then (in the event handler) overwriting the variable with a command that will always return your expected value. Then you can give the event handler a reentry type of RETRY, and the test case should pass after the event handler executes.
Previous Topic:Check If a Gigantic Mult Line Text Matches
Next Topic:JavaFX
Current Time: Wed Jul 23 23:04:57 EDT 2025
Powered by FUDForum. Page generated in 0.04939 seconds
