Home » Modeling » Compare » Programmatically "merge without deletions"
Programmatically "merge without deletions" [message #1393101] Thu, 03 July 2014 04:35 Go to next message
Hello everyone,
I would like to use EMF/Compare programmatically to "merge" two models (in my case, Ecore models). By "merge", I mean actually adding (or merging if classes already exist) all classes/datatypes/enums/features/operations of one Ecore model into another one, without removing anything from the base Ecore model.
However, this is not the default behavior in Compare, as some elements may be removed from the base model if they don't get matched by elements of the other model.
I tried some things, such as discarding all non-ADD diff elements (thus preventing deletions): (this is Xtend code, but I'm sure you'll get it Wink)
val EPackage pkg1 = ...
val EPackage pkg2 = ...
val scope = new DefaultComparisonScope(pkg1, pkg2, null)
val comparison = EMFCompare.builder.build.compare(scope)
val diffs = comparison.differences
diffs.filter[
    kind != DifferenceKind.ADD
    && !requires.exists[r | r.kind == DifferenceKind.ADD]
].forEach[
    discard
val mergerRegistry = IMerger.RegistryImpl.createStandaloneInstance
val merger = new BatchMerger(mergerRegistry)
merger.copyAllLeftToRight(diffs, null)
However, this does not meet the expected behavior, e.g. new datatypes are not added into the base model, etc.
Is there any way I can "properly" implement this behavior? I cannot find the appropriate filter/merger for such purpose. Alternatively, do you have some ideas on how I should filter my diffs in order to meet the expected behavior?
Thank you,
Re: Programmatically "merge without deletions" [message #1393189 is a reply to message #1393101] Thu, 03 July 2014 07:42 Go to previous messageGo to next message
Hi Cioran,
I don't understand why you want to discard the changes that are not "additions". You could only merge those additions, and you will get your result:
val diffs = comparison.differences.filter[kind == DifferenceKind.ADD].toList
Hope this helps.
Re: Programmatically "merge without deletions" [message #1393322 is a reply to message #1393189] Thu, 03 July 2014 12:01 Go to previous message
The problem is that some ADD differences depends on other differences that are not ADD-typed.
So I need some kind of transitive closure on all diff objects required by any ADD-typed difference in order to get the expected result. Am I wrong?
Previous Topic:Default Comparison Scope in v3.1.0
Next Topic:Customization and Team support
Current Time: Sat Jul 26 04:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.05927 seconds
