Home » Eclipse Projects » Remote Application Platform (RAP) » Object null within Qooxdoo code
Object null within Qooxdoo code [message #139277] Sun, 05 July 2009 14:18 Go to next message
Originally posted by: s0181013.mail.inf.tu-dresden.de
--------------030505070805040508040705
Hello everyone,
while trying to add a simple Flash Video within a RWT Widget, I
sometimes get the exception that the element is null.
So the
document.getElementById(this._id).innerHTML = ""; as well as the
this.getElement().innerHTML = "";
do not work. Both return null or at least after the application was
started a second time. The latter was suggested by Ivan in a previous thread
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg06813.html
By the way: Thank you very much for your reply!
I attachted the whole code to this thread for detailed information.
Thank you in advance!
Content-Type: application/x-javascript;
name="FlashForm.js"
Content-Disposition: inline;
filename="FlashForm.js"
LyoqDQoqIFRoaXMgY2xhc3MgcmVwcmVzZW50cyB0aGUgY29kZSBmb3IgdGhl IGNsaWVudC1z
aWRlZCBpbXBsZW1lbnRhdGlvbiBvZiB0aGUgZG9qb0Zvcm0gd2lkZ2V0IA0K Ki8NCg0KLyog
VGhlIEphdmEgQ2xhc3MgdGhhdCB3aWxsIGJlIGVzdGFibGlzaGVkLiAqLw0K cXguQ2xhc3Mu
ZGVmaW5lKCJvcmcuZWNsaXBzZS5yYXAud2lkZ2V0LmZsYXNoLkNyZWF0ZUNv bXBvc2l0ZSIs
IHsNCiAgICANCiAgICAvKiBVc2UgdGhlIFFvb3hkb28gTGF5b3V0IE1hbmFn ZXIgYXMgc3Vw
ZXIgY2xhc3MgKi8NCiAgICBleHRlbmQ6IHF4LnVpLmxheW91dC5DYW52YXNM YXlvdXQsDQog
ICAgDQogICAgY29uc3RydWN0IDogZnVuY3Rpb24oaWQpIHsNCiAgICAgICAg dGhpcy5iYXNl
KCBhcmd1bWVudHMgKTsNCiAgICAgICAgLy8gUG9wdWxhdGUgdGhlIGlkIHRv IHRoZSBicm93
c2VyDQogICAgICAgIHRoaXMuc2V0SHRtbEF0dHJpYnV0ZSggImlkIiwgaWQg KTsNCiAgICAg
ICAgdGhpcy5faWQgPSBpZDsNCiAgICAgICAgY29uc29sZS5kZWJ1ZygnZmxh c2ggY29uc3Ry
dWN0Jyk7DQogICAgfSwNCiAgICAgDQogICAgcHJvcGVydGllcyA6IHsNCiAg ICAgICAgZmxh
c2hGb3JtIDogew0KICAgICAgICAgICAgaW5pdCA6ICIiLA0KICAgICAgICAg ICAgYXBwbHk6
ICJsb2FkIg0KICAgICAgICB9DQogICAgfSwNCiAgICANCiAgICBtZW1iZXJz IDogew0KICAg
IAlfZG9BY3RpdmF0ZSA6IGZ1bmN0aW9uKCkgew0KICAgIAlhbGVydCgiX2Rv QWN0aXZhdGUi
KTsNCiAgICAJCXZhciBzaGVsbCA9IG51bGw7DQogICAgCQl2YXIgcGFyZW50 ID0gdGhpcy5n
ZXRQYXJlbnQoKTsNCiAgICAJCXdoaWxlKHNoZWxsID09IG51bGwgJiYgcGFy ZW50ICE9IG51
bGwpIHsNCiAgICAJCQlpZihwYXJlbnQuY2xhc3NuYW1lID09IA0KICAgIAkJ CQkib3JnLmVj
bGlwc2Uuc3d0LndpZGdldHMuU2hlbGwiKSB7DQogICAgCQkJCXNoZWxsID0g cGFyZW50Ow0K
ICAgIAkJCX0NCiAgICAJCQlwYXJlbnQgPSBwYXJlbnQuZ2V0UGFyZW50KCk7 DQogICAgCQl9
DQogICAgCQlpZihzaGVsbCAhPSBudWxsKSB7DQogICAgCQkJc2hlbGwuc2V0 QWN0aXZlQ2hp
bGQodGhpcyk7DQogICAgCQl9DQogICAgfSwNCiAgICAJDQogICAgCWxvYWQg OiBmdW5jdGlv
bigpIHsNCiAgICAJDQogICAgCWlmICh0aGlzLmdldEZsYXNoRm9ybSgpKSB7 DQogICAgICAg
IAkNCgkJCQlkb2N1bWVudC5nZXRFbGVtZW50QnlJZCh0aGlzLl9pZCkuaW5u ZXJIVE1MID0g
DQoJCQkJICAgICc8b2JqZWN0IHdpZHRoPSI0MjUiIGhlaWdodD0iMzczIj4n DQoJCQkgICAg
ICArICc8cGFyYW0gbmFtZT0ibW92aWUiIHZhbHVlPSJodHRwOi8vd3d3Lnlv dXR1YmUuY29t
L3YvJysgdGhpcy5nZXRGbGFzaEZvcm0oKQ0KCQkJICAgICAgKyAnIj48L3Bh cmFtPicNCgkJ
CSAgICAgICsgJzxwYXJhbSBuYW1lPSJ3bW9kZSIgdmFsdWU9InRyYW5zcGFy ZW50Ij48L3Bh
cmFtPicNCgkJCSAgICAgICsgJzxlbWJlZCBzcmM9Imh0dHA6Ly93d3cueW91 dHViZS5jb20v
di8nKyB0aGlzLmdldEZsYXNoRm9ybSgpDQoJCQkgICAgICArICciIHR5cGU9 ImFwcGxpY2F0
aW9uL3gtc2hvY2t3YXZlLWZsYXNoIiB3bW9kZT0idHJhbnNwYXJlbnQiIHdp ZHRoPSI0MjUi
IGhlaWdodD0iMzczIj48L2VtYmVkPicNCgkJCSAgICAgICsgJzwvb2JqZWN0 PicgICAgICAg
ICAgICAJDQogICAgICAgICB9IA0KICAgICAgIH0NCiAgICB9DQp9KTsg
--------------030505070805040508040705--
Re: Object null within Qooxdoo code [message #139290 is a reply to message #139277] Sun, 05 July 2009 14:39 Go to previous messageGo to next message
Hi Jessica.
I'm happy that my suggestions helped you. To workaround this issue just
register a listener to the "appear" event ( on appear the widget element
is already created ) and put your flash initialization code there:
construct : function( id ) {
this.addEventListener( "appear", this._onAppear, this );
members : {
_onAppear : function() {
document.getElementById(this._id).innerHTML = ....
Best,
Ivan
Jessica Nierth wrote:
> Hello everyone,
> So the
> thread
Re: Object null within Qooxdoo code [message #139298 is a reply to message #139290] Mon, 06 July 2009 02:36 Go to previous messageGo to next message
Hi Ivan,
thanks a lot again! The NullPointerException is gone but unfortunately
the video doesn't show up. Do you have any idea about this. The
_onAppear function is entered - tested by some alert - and the link of
the video will be given to the widget too.
> Hi Jessica.
> members : {
> Best,
> Ivan
>> Hello everyone,
>> So the
>> thread
Re: Object null within Qooxdoo code [message #139310 is a reply to message #139298] Mon, 06 July 2009 04:35 Go to previous messageGo to next message
Hi Jessica,
unfortunately I have no idea. Maybe you can try to "inspect" the DOM
with Firebug Inspector and to see if the flash code is there, looking
for a javascript errors or so.
Best,
Ivan
> Hi Ivan,
>> Hi Jessica.
>> just register a listener to the "appear" event ( on appear the widget
>> element is already created ) and put your flash initialization code
>> there:
>> members : {
>> Best,
>> Ivan
>>> Hello everyone,
>>> So the
>>> previous thread
Re: Object null within Qooxdoo code [message #139356 is a reply to message #139310] Mon, 06 July 2009 05:19 Go to previous messageGo to next message
--------------000301040001020304010801
Hello Ivan,
I attached a picture showing that the Flash Video is added to the DOM
but as said before, it is some kind of hidden. By the way, is there a
strategy to make the flash video resize itself according to the size of
its container-Element?
Jes
> Hi Jessica,
> Best,
> Ivan
>> Hi Ivan,
>>> Hi Jessica.
>>> there:
>>> members : {
>>> Best,
>>> Ivan
>>>> Hello everyone,
>>>> So the
>>>> previous thread
Content-Type: image/jpeg;
name="Firebug - FlashVideo.jpg"
filename="Firebug - FlashVideo.jpg"
/9j/4AAQSkZJRgABAgEASABIAAD/4RAkRXhpZgAATU0AKgAAAAgABwESAAMA AAABAAEAAAEa
AAUAAAABAAAAYgEbAAUAAAABAAAAagEoAAMAAAABAAIAAAExAAIAAAAcAAAA cgEyAAIAAAAU
AAAAjodpAAQAAAABAAAApAAAANAACvyAAAAnEAAK/IAAACcQQWRvYmUgUGhv dG9zaG9wIENT
MyBXaW5kb3dzADIwMDk6MDc6MDYgMTE6MTQ6MDYAAAAAA6ABAAMAAAABAAEA AKACAAQAAAAB
AAAECKADAAQAAAABAAADLwAAAAAAAAAGAQMAAwAAAAEABgAAARoABQAAAAEA AAEeARsABQAA
AAEAAAEmASgAAwAAAAEAAgAAAgEABAAAAAEAAAEuAgIABAAAAAEAAA7uAAAA AAAAAEgAAAAB
AAAASAAAAAH/2P/gABBKRklGAAECAABIAEgAAP/tAAxBZG9iZV9DTQAB/+4A DkFkb2JlAGSA
AAAAAf/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8VGBMTFRMTGBEMDAwMDAwR DAwMDAwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4ODhQUDg4ODhQRDAwM DAwREQwMDAwM
DBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgAfgCgAwEiAAIR AQMRAf/dAAQA
Cv/EAT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEA AAAAAAAAAQAC
AwQFBgcICQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIG FJGhsUIjJBVS
wWIzNHKC0UMHJZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePz RieUpIW0lcTU
5PSltcXV5fVWZnaGlqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYH BwYFNQEAAhED
ITESBEFRYXEiEwUygZEUobFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcm NcLSRJNUoxdk
RVU2dGXi8rOEw9N14/NGlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dX Z3eHl6e3x//a
AAwDAQACEQMRAD8A38xhxKn325bzWyw1bW1BjnOFj8fcx1udXU1jbKf5Hs/m /wDg6D+p1MDi
63JaGTu9lJggbv8Ayzd/mf8AW10eSytzyx9db2hz3Br62PEue8ud+kY73OQf s2L/ANxsf/ti
n/0kr8CK9UQddNIj0/4rQnwg0OIVp80t/wDHanTOn5HWcZ9+F1F+O2m01P31 NeSQ1lunp5eR
Tt2XMVr/AJqdX/8ALk/+wzf/AEqiNbWwbWV1sHMNrraJ+DWBPP8AJb/mM/8A Iph4r0MQP7kD
/wBykHFWon/jzH/dov8Amp1f/wAuT/7DN/8ASqX/ADU6v/5cn/2Gb/6VRZ/k t/zGf+RSn+S3
/MZ/5FL9Z3h/4Xj/AO9VeH93J/4Zk/79F/zU6v8A+XJ/9hm/+lUv+anV/wDy 5P8A7DN/9Kos
/wAlv+Yz/wAilp+63/Mb/wCRS/Wd4f8AheP/AL1V4f3cn/hmT/v0X/NTq/8A 5cn/ANhm/wDp
VIfVXrAMjrTgfEY4/wDSq0em0UWm31aq37dsSxuk7v5KvfYsL/uPV/mN/uUc skomrj/4Xj/7
1mhixyiJAS1/1mX/AL5wv+a/W/8Ay8f/ANsD/wBKpf8ANfrf/l4//tgf+lVu /YsL/uPV/mN/
uS+xYX/cer/Mb/ch70v6v/heP/vV33eH9b/wzL/3zhf81+t/+Xj/APtgf+lU v+a/W/8Ay8f/
ANsD/wBKrd+xYX/cer/Mb/cl9iwv+49X+Y3+5L3pf1f/AAvH/wB6r7vD+t/4 Zl/75wT9Vusn
nrbz8ccH/wBGpv8Amp1j/wAunf8AsM3/ANKrf+xYX/cer/Mb/cl9iwv+49X+ Y3+5L3pf1f8A
wvH/AN6r7vD+t/4Zl/75wP8Amp1j/wAunf8AsM3/ANKpf81Osf8Al0f/AGGb /wClVv8A2LC/
7j1f5jf7kvsWF/3Hq/zG/wByXvS/q/8AheP/AL1X3eH9b/wzL/3zzLOhZ9lj 62dbe51ZDXxi
TBLvSj22fmv+n+5/OfQRaugdSpurtu6k++tjmufS7HDA8btnpmz1Hbdy6H7F hf8AcerXn2N/
uQcjGx6345rqZWTc0EtaAYLX+CEcs6qRjI6/LihDT/nJODGDcRIbb5ckn//Q 7S/+dd8T/wBU
9QU7/wCdd8T/ANU9QV0bBz5/PLzKkkkkVqkkkklKSSSSU3+kc3f2f+/LRWd0 jm7+z/35aKrZ
PnP0buD+bj9f+kpJJJMZFJJJJKUkkkkpSSSSSlKvl/Sxv+Pb/wBS9WFXy/pY 3/Ht/wCpekP2
FRf/0e0v/nXfE/8AVPUFO/8AnXfE/wDVPUFdGwc+fzy8ypJJJFapJJJJSkkk klN/pHN39n/v
y0VndI5u/s/9+Wiq2T5z9G7g/m4/X/pKSSSTGRSSSSSlJJJJKUkkkkpSr5f0 sb/j2/8AUvVh
V8v6WN/x7f8AqXpD9hUX/9LtL/513xP/AFT1BEy2PZkuYDI5BjgOmyP+kgy/ z/zf/MlcjsPJ
z5/PLzLJJR9/jHxH+1L3fvD7v9qcsZJKPu/eH3f7Uvd+8Pu/2pKZJKPu/eH3 f7Uvd+8Pu/2p
KdHpHN39n/vy0VldMFx9XZa1n0Z3M3T9L+W1XtuV/wByK/8Atv8A9SqtkHrO ob2D+bjp3/6S
dJA25X/civ8A7b/9Spbcr/uRX/23/wCpU2h3DJ9E6SBtyv8AuRX/ANt/+pUt uV/3Ir/7b/8A
UqVDuFfROkgbcr/uRX/23/6lS25X/civ/tv/ANSpUO4V9E6SBtyv+5Ff/bf/ AKlS25X/AHIr
/wC2/wD1KlQ7hX0Tqvl/Sxv+Pb/1L0CvKyrLLK2E/onBpcaQAZd6biN1zfaz +d/4tTcMh9lR
tdLWPa8Q0ATPpbdwss/Nfv8AopsZRkLEgRqOqZAg0RWz/9P0O7BZfeXEu1YC dpaOPZ+c137q
b9lM8bP85n/kFeb9EJ0/jl3WHFAmzEauf+y2TzZ/nM/8gn/ZTPGz/OZ/5BX0 keOf7xR7WP8A
dDRb0qrUue8a6CWn8jE/7Ko/0ln/AEf/ACKupJe5Lur2sf7oaX7Ko/0ln/R/ 8il+yqP9JZ/0
f/Iq6kl7ku6vax/uhBjYjMbfsc52+J3R2n90eaOkkmkkmyvAAFDQKSSSSUpJ JJJSkkkklKSS
SSUqSoW/RH9dn/VNU1C36I/rs/6pqSX/1PUG/RCdc4/qzq7LRZl7AB+iYS+R oHF9uvu9x/wf
5n/CJn9WvpoN+Tl1VVuY59TgbyCG7d1lkB36P3tS4vBVPSJLmsrqPUaa6wzI p9Z7NxL/AFzW
S4NdS6r0jv2e73+qpWdVsqvDLckMrgAtJsFm8jTZ7vTczclxKp6NJYDuqsZa KHX2C0kNDPfM
kSB+6nZ1MPe+tl9jn16PaC6QlxKp3klh/bbP9Jb97v70vttn+kt+9396XEqn cSWH9ts/0lv3
u/vS+22f6S373f3pcSqdxJYf22z/AElv3u/vQj1mgWGk5ZFoMGsuIdP9WUuJ VPQpLCf1EV1u
tuyXU1tIDn2OcGgu3Fuvu/0b0z+qV1sZY7KPpWtD67A521zXfRLXJcXgqneS XPnq9YrFpyH+
m4lrXguIJHP0f6qmzqDrGNsZdY5jwHNcC7UHvylxKp3UlifbbP8ASW/e7+9L 7bZ/pLfvd/el
xKp21C36I/rs/wCqasf7bZ/pLfvd/emOY86Gyw9+XdtfFLiVT//V9QGLijil g/sj+5O3Gx2m
W1MB50aBqiJJKRfZMXn0a9efaP7khi4o0FNY/sj+5FSSU5/2Oiu4D0y6tjQ0 AbzP/GCfSehn
BrbNbq9xb7p/Ska9t2/3f8WjZVc5Mv2hjmkydpdDdsu2ux7Pobv9KqxNVrtx dW8CXvsO0u2j
i0g4n85s/NQqZBoEgM8RAUeKI0Z2YdRh7aiPUg7YeA06btzGP/Rs0UhhVSGi kAtJ1O/af3Q3
X3KIsovydoe1zWNaPaGudt/lM+ze3dH+lScKxU9zttbeKmgN2yQ5+z34ntb/ ANuoESuiCkCN
WCB3/wAJkMakWfzEkjT2PLdx43bvbs9yZuG2S01NmIcSHlp0/wAE7ckS2wVW h26CBwIA9rtr
HHF3fmb9n6NT+xPf6m0BtbjLBFY8PzH4vt/d9/qJUbqk+mrMhqPyRuxqiC9l PtdoGubbu4ng
fQ9353/W0enBYxziaqzW6TqHOM9tLPoIj8JjnbtxbxoG1xoI/Oqc5WDwkAxz mKABu93JwMGx
tdrGWsfY1xm66oOcdzWOaNrHVbWM93tURcx1RsPoF5fq7ZTwQ6G/0p35zf8A Sq3iSftDBy46
HWB7K+7Yd+ckMTJB1eOD/hLudP8AhETfRhN9ETbcSs/pa6nnaDIFLdHS5v0r v3P/ADBPkZHT
6bNrsZjiYLTNA3Bw+k31ba3fS9iKcbLDAGuaTrMvt78e71C5Sfi2vsY7cQGs DXRZaNfg2zb/
AG3fpEYVfqUL6pG4mI5oJx6xPYtb/wB9lP8AY8T/AEFf+Y3+5Q2Zzfax1e0f R3hxd/aduScO
ox7HUz2Ba7x/rfuI14hLP7Hif6Cv/Mb/AHJfY8T/AEFf+Y3+5RjqEs91MQd5 2u5g7dg3fvJg
OoyJNMSJgO4j3/nfvJcPiFP/1vVUkkklKSSSSUpVcgS86vAj3BosOkfmek9n vVpZWe3A+0n1
3UeqQI9Q0hwbHv8A52t79u1GNXrf+DukC+oH97ZtPbYXH3OnTgWR+FjWpzLb CZfBnSLHcnyf
sVC1vTgP0jqHWlzdweaAQ6Helu/Ru3ez6COGtBa2pzC8ElrwaQ4jiAPT9rdn vTdPH6hkETrr
E/3SFndOpse553bjLiSLANfd/pP3lKjEqo32VB4JaGk7X+Pu/ObY7+wgUt6c Lm+iccmAYBon
bsb7fYxr9uz/AKH/AAaewYwrG/0DSbG+ludTtFnb0pq/nvS+glY8fsUIX1j0 6j8242t7oG5w
26En1B2HjbuVhoe1sOIMDsDP/Sc5ZdLcL05acf0C0gjdTtDp/SfQq2/QR2N6 S1hD3UPcOXEM
En83j2peQVKIAqUvsHF/zvSgodXYLX5T3YcPdA9X03FobT73Q7b/AOk1fdjM seLBdYC0gw15
DZaI9zPof12qvjGkjIOQGj3xFu2I2M3Hv7U5GTtJE7+A0PeGn+U53oO2v3JM RKZ+Ex7w/wBW
5pDt8NscAf5O2fofyVYaNoiSdSdfMyqJGWC309zrAWgB7n7HD882n0m7X7f3 fZ6iZrc8XlzS
Dr9B737CDO//ALTt27P8H704Cx2U6CSrh2f3rq5HD3cfnf4L6SZruohwDq6S 2dXB7gYge7b6
Tv5Xt3pV5fapspKu12fHuZUDt7Pcfd/239FNv6htP6KndPtHqOjb5/ofpJV5 fap//9n/7RUC
UGhvdG9zaG9wIDMuMAA4QklNBCUAAAAAABAAAAAAAAAAAAAAAAAAAAAAOEJJ TQPtAAAAAAAQ
AEgAAAABAAIASAAAAAEAAjhCSU0EJgAAAAAADgAAAAAAAAAAAAA/gAAAOEJJ TQQNAAAAAAAE
AAAAeDhCSU0EGQAAAAAABAAAAB44QklNA/MAAAAAAAkAAAAAAAAAAAEAOEJJ TQQKAAAAAAAB
AAA4QklNJxAAAAAAAAoAAQAAAAAAAAACOEJJTQP1AAAAAABIAC9mZgABAGxm ZgAGAAAAAAAB
AC9mZgABAKGZmgAGAAAAAAABADIAAAABAFoAAAAGAAAAAAABADUAAAABAC0A AAAGAAAAAAAB
OEJJTQP4AAAAAABwAAD/////////////////////////////A+gAAAAA//// ////////////
/////////////wPoAAAAAP////////////////////////////8D6AAAAAD/ ////////////
////////////////A+gAADhCSU0EAAAAAAAAAgABOEJJTQQCAAAAAAAEAAAA ADhCSU0EMAAA
AAAAAgEBOEJJTQQtAAAAAAAGAAEAAAACOEJJTQQIAAAAAAAQAAAAAQAAAkAA AAJAAAAAADhC
SU0EHgAAAAAABAAAAAA4QklNBBoAAAAAA0sAAAAGAAAAAAAAAAAAAAMvAAAE CAAAAAsAVQBu
AGIAZQBuAGEAbgBuAHQALQAxAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAABAAAA AAAAAAAAAAQI
AAADLwAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAB AAAAAAAAbnVs
bAAAAAIAAAAGYm91bmRzT2JqYwAAAAEAAAAAAABSY3QxAAAABAAAAABUb3Ag bG9uZwAAAAAA
AAAATGVmdGxvbmcAAAAAAAAAAEJ0b21sb25nAAADLwAAAABSZ2h0bG9uZwAA BAgAAAAGc2xp
Y2VzVmxMcwAAAAFPYmpjAAAAAQAAAAAABXNsaWNlAAAAEgAAAAdzbGljZUlE bG9uZwAAAAAA
AAAHZ3JvdXBJRGxvbmcAAAAAAAAABm9yaWdpbmVudW0AAAAMRVNsaWNlT3Jp Z2luAAAADWF1
dG9HZW5lcmF0ZWQAAAAAVHlwZWVudW0AAAAKRVNsaWNlVHlwZQAAAABJbWcg AAAABmJvdW5k
c09iamMAAAABAAAAAAAAUmN0MQAAAAQAAAAAVG9wIGxvbmcAAAAAAAAAAExl ZnRsb25nAAAA
AAAAAABCdG9tbG9uZwAAAy8AAAAAUmdodGxvbmcAAAQIAAAAA3VybFRFWFQA AAABAAAAAAAA
bnVsbFRFWFQAAAABAAAAAAAATXNnZVRFWFQAAAABAAAAAAAGYWx0VGFnVEVY VAAAAAEAAAAA
AA5jZWxsVGV4dElzSFRNTGJvb2wBAAAACGNlbGxUZXh0VEVYVAAAAAEAAAAA AAlob3J6QWxp
Z25lbnVtAAAAD0VTbGljZUhvcnpBbGlnbgAAAAdkZWZhdWx0AAAACXZlcnRB bGlnbmVudW0A
AAAPRVNsaWNlVmVydEFsaWduAAAAB2RlZmF1bHQAAAALYmdDb2xvclR5cGVl bnVtAAAAEUVT
bGljZUJHQ29sb3JUeXBlAAAAAE5vbmUAAAAJdG9wT3V0c2V0bG9uZwAAAAAA AAAKbGVmdE91
dHNldGxvbmcAAAAAAAAADGJvdHRvbU91dHNldGxvbmcAAAAAAAAAC3JpZ2h0 T3V0c2V0bG9u
ZwAAAAAAOEJJTQQoAAAAAAAMAAAAAT/wAAAAAAAAOEJJTQQUAAAAAAAEAAAA AjhCSU0EDAAA
AAAPCgAAAAEAAACgAAAAfgAAAeAAAOxAAAAO7gAYAAH/2P/gABBKRklGAAEC AABIAEgAAP/t
AAxBZG9iZV9DTQAB/+4ADkFkb2JlAGSAAAAAAf/bAIQADAgICAkIDAkJDBEL CgsRFQ8MDA8V
GBMTFRMTGBEMDAwMDAwRDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAEN CwsNDg0QDg4Q
FA4ODhQUDg4ODhQRDAwMDAwREQwMDAwMDBEMDAwMDAwMDAwMDAwMDAwMDAwM DAwMDAwMDAwM
/8AAEQgAfgCgAwEiAAIRAQMRAf/dAAQACv/EAT8AAAEFAQEBAQEBAAAAAAAA AAMAAQIEBQYH
CAkKCwEAAQUBAQEBAQEAAAAAAAAAAQACAwQFBgcICQoLEAABBAEDAgQCBQcG CAUDDDMBAAIR
AwQhEjEFQVFhEyJxgTIGFJGhsUIjJBVSwWIzNHKC0UMHJZJT8OHxY3M1FqKy gyZEk1RkRcKj
dDYX0lXiZfKzhMPTdePzRieUpIW0lcTU5PSltcXV5fVWZnaGlqa2xtbm9jdH V2d3h5ent8fX
5/cRAAICAQIEBAMEBQYHBwYFNQEAAhEDITESBEFRYXEiEwUygZEUobFCI8FS 0fAzJGLhcoKS
Q1MVY3M08SUGFqKygwcmNcLSRJNUoxdkRVU2dGXi8rOEw9N14/NGlKSFtJXE 1OT0pbXF1eX1
VmZ2hpamtsbW5vYnN0dXZ3eHl6e3x//aAAwDAQACEQMRAD8A38xhxKn325bz Wyw1bW1BjnOF
j8fcx1udXU1jbKf5Hs/m/wDg6D+p1MDi63JaGTu9lJggbv8Ayzd/mf8AW10e Sytzyx9db2hz
3Br62PEue8ud+kY73OQfs2L/ANxsf/tin/0kr8CK9UQddNIj0/4rQnwg0OIV p80t/wDHanTO
n5HWcZ9+F1F+O2m01P31NeSQ1lunp5eRTt2XMVr/AJqdX/8ALk/+wzf/AEqi NbWwbWV1sHMN
rraJ+DWBPP8AJb/mM/8AIph4r0MQP7kD/wBykHFWon/jzH/dov8Amp1f/wAu T/7DN/8ASqX/
ADU6v/5cn/2Gb/6VRZ/kt/zGf+RSn+S3/MZ/5FL9Z3h/4Xj/AO9VeH93J/4Z k/79F/zU6v8A
+XJ/9hm/+lUv+anV/wDy5P8A7DN/9Kos/wAlv+Yz/wAilp+63/Mb/wCRS/Wd 4f8AheP/AL1V
4f3cn/hmT/v0X/NTq/8A5cn/ANhm/wDpVIfVXrAMjrTgfEY4/wDSq0em0UWm 31aq37dsSxuk
7v5KvfYsL/uPV/mN/uUcskomrj/4Xj/71mhixyiJAS1/1mX/AL5wv+a/W/8A y8f/ANsD/wBK
pf8ANfrf/l4//tgf+lVu/YsL/uPV/mN/uS+xYX/cer/Mb/ch70v6v/heP/vV 33eH9b/wzL/3
zhf81+t/+Xj/APtgf+lUv+a/W/8Ay8f/ANsD/wBKrd+xYX/cer/Mb/cl9iwv +49X+Y3+5L3p
f1f/AAvH/wB6r7vD+t/4Zl/75wT9Vusnnrbz8ccH/wBGpv8Amp1j/wAunf8A sM3/ANKrf+xY
X/cer/Mb/cl9iwv+49X+Y3+5L3pf1f8AwvH/AN6r7vD+t/4Zl/75wP8Amp1j /wAunf8AsM3/
ANKpf81Osf8Al0f/AGGb/wClVv8A2LC/7j1f5jf7kvsWF/3Hq/zG/wByXvS/ q/8AheP/AL1X
3eH9b/wzL/3zzLOhZ9lj62dbe51ZDXxiTBLvSj22fmv+n+5/OfQRaugdSpur tu6k++tjmufS
7HDA8btnpmz1Hbdy6H7Fhf8AcerXn2N/uQcjGx6345rqZWTc0EtaAYLX+CEc s6qRjI6/LihD
T/nJODGDcRIbb5ckn//Q7S/+dd8T/wBU9QU7/wCdd8T/ANU9QV0bBz5/PLzK kkkkVqkkkklK
SSSSU3+kc3f2f+/LRWd0jm7+z/35aKrZPnP0buD+bj9f+kpJJJMZFJJJJKUk kkkpSSSSSlKv
l/Sxv+Pb/wBS9WFXy/pY3/Ht/wCpekP2FRf/0e0v/nXfE/8AVPUFO/8AnXfE /wDVPUFdGwc+
fzy8ypJJJFapJJJJSkkkklN/pHN39n/vy0VndI5u/s/9+Wiq2T5z9G7g/m4/ X/pKSSSTGRSS
SSSlJJJJKUkkkkpSr5f0sb/j2/8AUvVhV8v6WN/x7f8AqXpD9hUX/9LtL/51 3xP/AFT1BEy2
PZkuYDI5BjgOmyP+kgy/z/zf/MlcjsPJz5/PLzLJJR9/jHxH+1L3fvD7v9qc sZJKPu/eH3f7
Uvd+8Pu/2pKZJKPu/eH3f7Uvd+8Pu/2pKdHpHN39n/vy0VldMFx9XZa1n0Z3 M3T9L+W1XtuV
/wByK/8Atv8A9SqtkHrOob2D+bjp3/6SdJA25X/civ8A7b/9Spbcr/uRX/23 /wCpU2h3DJ9E
6SBtyv8AuRX/ANt/+pUtuV/3Ir/7b/8AUqVDuFfROkgbcr/uRX/23/6lS25X /civ/tv/ANSp
UO4V9E6SBtyv+5Ff/bf/AKlS25X/AHIr/wC2/wD1KlQ7hX0Tqvl/Sxv+Pb/1 L0CvKyrLLK2E
/onBpcaQAZd6biN1zfaz+d/4tTcMh9lRtdLWPa8Q0ATPpbdwss/Nfv8AopsZ RkLEgRqOqZAg
0RWz/9P0O7BZfeXEu1YCdpaOPZ+c137qb9lM8bP85n/kFeb9EJ0/jl3WHFAm zEauf+y2TzZ/
nM/8gn/ZTPGz/OZ/5BX0keOf7xR7WP8AdDRb0qrUue8a6CWn8jE/7Ko/0ln/ AEf/ACKupJe5
Lur2sf7oaX7Ko/0ln/R/8il+yqP9JZ/0f/Iq6kl7ku6vax/uhBjYjMbfsc52 +J3R2n90eaOk
kmkkmyvAAFDQKSSSSUpJJJJSkkkklKSSSSUqSoW/RH9dn/VNU1C36I/rs/6p qSX/1PUG/RCd
c4/qzq7LRZl7AB+iYS+RoHF9uvu9x/wf5n/CJn9WvpoN+Tl1VVuY59TgbyCG 7d1lkB36P3tS
4vBVPSJLmsrqPUaa6wzIp9Z7NxL/AFzWS4NdS6r0jv2e73+qpWdVsqvDLckM rgAtJsFm8jTZ
7vTczclxKp6NJYDuqsZaKHX2C0kNDPfMkSB+6nZ1MPe+tl9jn16PaC6QlxKp 3klh/bbP9Jb9
7v70vttn+kt+9396XEqncSWH9ts/0lv3u/vS+22f6S373f3pcSqdxJYf22z/ AElv3u/vQj1m
gWGk5ZFoMGsuIdP9WUuJVPQpLCf1EV1utuyXU1tIDn2OcGgu3Fuvu/0b0z+q V1sZY7KPpWtD
67A521zXfRLXJcXgqneSXPnq9YrFpyH+m4lrXguIJHP0f6qmzqDrGNsZdY5j wHNcC7UHvylx
Kp3UlifbbP8ASW/e7+9L7bZ/pLfvd/elxKp21C36I/rs/wCqasf7bZ/pLfvd /emOY86Gyw9+
XdtfFLiVT//V9QGLijilg/sj+5O3Gx2mW1MB50aBqiJJKRfZMXn0a9efaP7k hi4o0FNY/sj+
5FSSU5/2Oiu4D0y6tjQ0AbzP/GCfSehnBrbNbq9xb7p/Ska9t2/3f8WjZVc5 Mv2hjmkydpdD
dsu2ux7Pobv9KqxNVrtxdW8CXvsO0u2ji0g4n85s/NQqZBoEgM8RAUeKI0Z2 YdRh7aiPUg7Y
eA06btzGP/Rs0UhhVSGikAtJ1O/af3Q3X3KIsovydoe1zWNaPaGudt/lM+ze 3dH+lScKxU9z
ttbeKmgN2yQ5+z34ntb/ANuoESuiCkCNWCB3/wAJkMakWfzEkjT2PLdx43bv bs9yZuG2S01N
mIcSHlp0/wAE7ckS2wVWh26CBwIA9rtrHHF3fmb9n6NT+xPf6m0BtbjLBFY8 PzH4vt/d9/qJ
Ubqk+mrMhqPyRuxqiC9lPtdoGubbu4ngfQ9353/W0enBYxziaqzW6TqHOM9t LPoIj8Jjnbtx
bxoG1xoI/Oqc5WDwkAxzmKABu93JwMGxtdrGWsfY1xm66oOcdzWOaNrHVbWM 93tURcx1RsPo
F5fq7ZTwQ6G/0p35zf8ASq3iSftDBy46HWB7K+7Yd+ckMTJB1eOD/hLudP8A hETfRhN9ETbc
Ss/pa6nnaDIFLdHS5v0rv3P/ADBPkZHT6bNrsZjiYLTNA3Bw+k31ba3fS9iK cbLDAGuaTrMv
t78e71C5Sfi2vsY7cQGsDXRZaNfg2zb/AG3fpEYVfqUL6pG4mI5oJx6xPYtb /wB9lP8AY8T/
AEFf+Y3+5Q2Zzfax1e0fR3hxd/aduScOox7HUz2Ba7x/rfuI14hLP7Hif6Cv /Mb/AHJfY8T/
AEFf+Y3+5RjqEs91MQd52u5g7dg3fvJgOoyJNMSJgO4j3/nfvJcPiFP/1vVU kkklKSSSSUpV
cgS86vAj3BosOkfmek9nvVpZWe3A+0n13UeqQI9Q0hwbHv8A52t79u1GNXrf +DukC+oH97Zt
PbYXH3OnTgWR+FjWpzLbCZfBnSLHcnyfsVC1vTgP0jqHWlzdweaAQ6Helu/R u3ez6COGtBa2
pzC8ElrwaQ4jiAPT9rdnvTdPH6hkETrrE/3SFndOpse553bjLiSLANfd/pP3 lKjEqo32VB4J
aGk7X+Pu/ObY7+wgUt6cLm+iccmAYBonbsb7fYxr9uz/AKH/AAaewYwrG/0D SbG+ludTtFnb
0pq/nvS+glY8fsUIX1j06j8242t7oG5w26En1B2HjbuVhoe1sOIMDsDP/Sc5 ZdLcL05acf0C
0gjdTtDp/SfQq2/QR2N6S1hD3UPcOXEMEn83j2peQVKIAqUvsHF/zvSgodXY LX5T3YcPdA9X
03FobT73Q7b/AOk1fdjMseLBdYC0gw15DZaI9zPof12qvjGkjIOQGj3xFu2I 2M3Hv7U5GTtJ
E7+A0PeGn+U53oO2v3JMRKZ+Ex7w/wBW5pDt8NscAf5O2fofyVYaNoiSdSdf MyqJGWC309zr
AWgB7n7HD882n0m7X7f3fZ6iZrc8XlzSDr9B737CDO//ALTt27P8H704Cx2U 6CSrh2f3rq5H
D3cfnf4L6SZruohwDq6S2dXB7gYge7b6Tv5Xt3pV5fapspKu12fHuZUDt7Pc fd/239FNv6ht
P6KndPtHqOjb5/ofpJV5fap//9k4QklNBCEAAAAAAFUAAAABAQAAAA8AQQBk AG8AYgBlACAA
UABoAG8AdABvAHMAaABvAHAAAAATAEEAZABvAGIAZQAgAFAAaABvAHQAbwBz AGgAbwBwACAA
QwBTADMAAAABADhCSU0EBgAAAAAABwAIAAAAAQEA/+EPz2h0dHA6Ly9ucy5h ZG9iZS5jb20v
eGFwLzEuMC8APD94cGFja2V0IGJlZ2luPSLvu78iIGlkPSJXNU0wTXBDZWhp SHpyZVN6TlRj
emtjOWQiPz4gPHg6eG1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyIg eDp4bXB0az0i
QWRvYmUgWE1QIENvcmUgNC4xLWMwMzYgNDYuMjc2NzIwLCBNb24gRmViIDE5 IDIwMDcgMjI6
NDA6MDggICAgICAgICI+IDxyZGY6UkRGIHhtbG5zOnJkZj0iaHR0cDovL3d3 dy53My5vcmcv
MTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+IDxyZGY6RGVzY3JpcHRpb24g cmRmOmFib3V0
PSIiIHhtbG5zOmRjPSJodHRwOi8vcHVybC5vcmcvZGMvZWxlbWVudHMvMS4x LyIgeG1sbnM6
eGFwPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIiB4bWxuczp4YXBN TT0iaHR0cDov
L25zLmFkb2JlLmNvbS94YXAvMS4wL21tLyIgeG1sbnM6c3RSZWY9Imh0dHA6 Ly9ucy5hZG9i
ZS5jb20veGFwLzEuMC9zVHlwZS9SZXNvdXJjZVJlZiMiIHhtbG5zOnBob3Rv c2hvcD0iaHR0
cDovL25zLmFkb2JlLmNvbS9waG90b3Nob3AvMS4wLyIgeG1sbnM6dGlmZj0i aHR0cDovL25z
LmFkb2JlLmNvbS90aWZmLzEuMC8iIHhtbG5zOmV4aWY9Imh0dHA6Ly9ucy5h ZG9iZS5jb20v
ZXhpZi8xLjAvIiBkYzpmb3JtYXQ9ImltYWdlL2pwZWciIHhhcDpDcmVhdG9y VG9vbD0iQWRv
YmUgUGhvdG9zaG9wIENTMyBXaW5kb3dzIiB4YXA6Q3JlYXRlRGF0ZT0iMjAw OS0wNy0wNlQx
MToxNDowNiswMjowMCIgeGFwOk1vZGlmeURhdGU9IjIwMDktMDctMDZUMTE6 MTQ6MDYrMDI6
MDAiIHhhcDpNZXRhZGF0YURhdGU9IjIwMDktMDctMDZUMTE6MTQ6MDYrMDI6 MDAiIHhhcE1N
OkRvY3VtZW50SUQ9InV1aWQ6ODY5QkQwM0EwRDZBREUxMUE2RkY4NzEzNUVE MDE5QTgiIHhh
cE1NOkluc3RhbmNlSUQ9InV1aWQ6ODc5QkQwM0EwRDZBREUxMUE2RkY4NzEz NUVEMDE5QTgi
IHBob3Rvc2hvcDpDb2xvck1vZGU9IjMiIHBob3Rvc2hvcDpJQ0NQcm9maWxl PSJzUkdCIElF
QzYxOTY2LTIuMSIgcGhvdG9zaG9wOkhpc3Rvcnk9IiIgdGlmZjpPcmllbnRh dGlvbj0iMSIg
dGlmZjpYUmVzb2x1dGlvbj0iNzIwMDAwLzEwMDAwIiB0aWZmOllSZXNvbHV0 aW9uPSI3MjAw
MDAvMTAwMDAiIHRpZmY6UmVzb2x1dGlvblVuaXQ9IjIiIHRpZmY6TmF0aXZl RGlnZXN0PSIy
NTYsMjU3LDI1OCwyNTksMjYyLDI3NCwyNzcsMjg0LDUzMCw1MzEsMjgyLDI4 MywyOTYsMzAx
LDMxOCwzMTksNTI5LDUzMiwzMDYsMjcwLDI3MSwyNzIsMzA1LDMxNSwzMzQz Mjs0MjRGRTkw
RUE5MkM5QkZDNUM0QkI3NEZDMTgyNTBFMSIgZXhpZjpQaXhlbFhEaW1lbnNp b249IjEwMzIi
IGV4aWY6UGl4ZWxZRGltZW5zaW9uPSI4MTUiIGV4aWY6Q29sb3JTcGFjZT0i MSIgZXhpZjpO
YXRpdmVEaWdlc3Q9IjM2ODY0LDQwOTYwLDQwOTYxLDM3MTIxLDM3MTIyLDQw OTYyLDQwOTYz
LDM3NTEwLDQwOTY0LDM2ODY3LDM2ODY4LDMzNDM0LDMzNDM3LDM0ODUwLDM0 ODUyLDM0ODU1
LDM0ODU2LDM3Mzc3LDM3Mzc4LDM3Mzc5LDM3MzgwLDM3MzgxLDM3MzgyLDM3 MzgzLDM3Mzg0
LDM3Mzg1LDM3Mzg2LDM3Mzk2LDQxNDgzLDQxNDg0LDQxNDg2LDQxNDg3LDQx NDg4LDQxNDky
LDQxNDkzLDQxNDk1LDQxNzI4LDQxNzI5LDQxNzMwLDQxOTg1LDQxOTg2LDQx OTg3LDQxOTg4
LDQxOTg5LDQxOTkwLDQxOTkxLDQxOTkyLDQxOTkzLDQxOTk0LDQxOTk1LDQx OTk2LDQyMDE2
LDAsMiw0LDUsNiw3LDgsOSwxMCwxMSwxMiwxMywxNCwxNSwxNiwxNywxOCwy MCwyMiwyMywy
NCwyNSwyNiwyNywyOCwzMDs2NzM1RUI5OTAzMUMzRUI0NDREQUFCNTlCRjRF OTI3MCI+IDx4
YXBNTTpEZXJpdmVkRnJvbSBzdFJlZjppbnN0YW5jZUlEPSJ1dWlkOjg1OUJE MDNBMEQ2QURF
MTFBNkZGODcxMzVFRDAxOUE4IiBzdFJlZjpkb2N1bWVudElEPSJ1dWlkOjg1 OUJEMDNBMEQ2
QURFMTFBNkZGODcxMzVFRDAxOUE4Ii8+IDwvcmRmOkRlc2NyaXB0aW9uPiA8 L3JkZjpSREY+
IDwveDp4bXBtZXRhPiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgIDw/eHBhY2tldCBlbmQ9InciPz7/4gxYSUNDX1BST0ZJTEUA AQEAAAxITGlu
bwIQAABtbnRyUkdCIFhZWiAHzgACAAkABgAxAABhY3NwTVNGVAAAAABJRUMg c1JHQgAAAAAA
AAAAAAAAAQAA9tYAAQAAAADTLUhQICAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAABFjcHJ0AAABUAAAADNkZXNjAAABhAAAAGx3dHB0 AAAB8AAAABRi
a3B0AAACBAAAABRyWFlaAAACGAAAABRnWFlaAAACLAAAABRiWFlaAAACQAAA ABRkbW5kAAAC
VAAAAHBkbWRkAAACxAAAAIh2dWVkAAADTAAAAIZ2aWV3AAAD1AAAACRsdW1p AAAD+AAAABRt
ZWFzAAAEDAAAACR0ZWNoAAAEMAAAAAxyVFJDAAAEPAAACAxnVFJDAAAEPAAA CAxiVFJDAAAE
PAAACAx0ZXh0AAAAAENvcHlyaWdodCAoYykgMTk5OCBIZXdsZXR0LVBhY2th cmQgQ29tcGFu
eQAAZGVzYwAAAAAAAAASc1JHQiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAABJz UkdCIElFQzYx
OTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAWFlaIAAAAAAAAPNRAAEAAAABFsxYWVogAAAAAAAAAAAAAAAAAAAAAFhZ WiAAAAAAAABv
ogAAOPUAAAOQWFlaIAAAAAAAAGKZAAC3hQAAGNpYWVogAAAAAAAAJKAAAA+E AAC2z2Rlc2MA
AAAAAAAAFklFQyBodHRwOi8vd3d3LmllYy5jaAAAAAAAAAAAAAAAFklFQyBo dHRwOi8vd3d3
LmllYy5jaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAABk
ZXNjAAAAAAAAAC5JRUMgNjE5NjYtMi4xIERlZmF1bHQgUkdCIGNvbG91ciBz cGFjZSAtIHNS
R0IAAAAAAAAAAAAAAC5JRUMgNjE5NjYtMi4xIERlZmF1bHQgUkdCIGNvbG91 ciBzcGFjZSAt
IHNSR0IAAAAAAAAAAAAAAAAAAAAAAAAAAAAAZGVzYwAAAAAAAAAsUmVmZXJl bmNlIFZpZXdp
bmcgQ29uZGl0aW9uIGluIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAALFJlZmVy ZW5jZSBWaWV3
aW5nIENvbmRpdGlvbiBpbiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AHZpZXcAAAAAABOk/gAUXy4AEM8UAAPtzAAEEwsAA1yeAAAAAVhZWiAAAAAA AEwJVgBQAAAA
Vx/nbWVhcwAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAo8AAAACc2lnIAAA AABDUlQgY3Vy
dgAAAAAAAAQAAAAABQAKAA8AFAAZAB4AIwAoAC0AMgA3ADsAQABFAEoATwBU AFkAXgBjAGgA
bQByAHcAfACBAIYAiwCQAJUAmgCfAKQAqQCuALIAtwC8AMEAxgDLANAA1QDb AOAA5QDrAPAA
9gD7AQEBBwENARMBGQEfASUBKwEyATgBPgFFAUwBUgFZAWABZwFuAXUBfAGD AYsBkgGaAaEB
qQGxAbkBwQHJAdEB2QHhAekB8gH6AgMCDAIUAh0CJgIvAjgCQQJLAlQCXQJn AnECegKEAo4C
mAKiAqwCtgLBAssC1QLgAusC9QMAAwsDFgMhAy0DOANDA08DWgNmA3IDfgOK A5YDogOuA7oD
xwPTA+AD7AP5BAYEEwQgBC0EOwRIBFUEYwRxBH4EjASaBKgEtgTEBNME4QTw BP4FDQUcBSsF
OgVJBVgFZwV3BYYFlgWmBbUFxQXVBeUF9gYGBhYGJwY3BkgGWQZqBnsGjAad Bq8GwAbRBuMG
9QcHBxkHKwc9B08HYQd0B4YHmQesB78H0gflB/gICwgfCDIIRghaCG4IggiW CKoIvgjSCOcI
+wkQCSUJOglPCWQJeQmPCaQJugnPCeUJ+woRCicKPQpUCmoKgQqYCq4KxQrc CvMLCwsiCzkL
UQtpC4ALmAuwC8gL4Qv5DBIMKgxDDFwMdQyODKcMwAzZDPMNDQ0mDUANWg10 DY4NqQ3DDd4N
+A4TDi4OSQ5kDn8Omw62DtIO7g8JDyUPQQ9eD3oPlg+zD88P7BAJECYQQxBh EH4QmxC5ENcQ
9RETETERTxFtEYwRqhHJEegSBxImEkUSZBKEEqMSwxLjEwMTIxNDE2MTgxOk E8UT5RQGFCcU
SRRqFIsUrRTOFPAVEhU0FVYVeBWbFb0V4BYDFiYWSRZsFo8WshbWFvoXHRdB F2UXiReuF9IX
9xgbGEAYZRiKGK8Y1Rj6GSAZRRlrGZEZtxndGgQaKhpRGncanhrFGuwbFBs7 G2MbihuyG9oc
AhwqHFIcexyjHMwc9R0eHUcdcB2ZHcMd7B4WHkAeah6UHr4e6R8THz4faR+U H78f6iAVIEEg
bCCYIMQg8CEcIUghdSGhIc4h+yInIlUigiKvIt0jCiM4I2YjlCPCI/AkHyRN JHwkqyTaJQkl
OCVoJZclxyX3JicmVyaHJrcm6CcYJ0kneierJ9woDSg/KHEooijUKQYpOClr KZ0p0CoCKjUq
aCqbKs8rAis2K2krnSvRLAUsOSxuLKIs1y0MLUEtdi2rLeEuFi5MLoIuty7u LyQvWi+RL8cv
/jA1MGwwpDDbMRIxSjGCMbox8jIqMmMymzLUMw0zRjN/M7gz8TQrNGU0njTY NRM1TTWHNcI1
/TY3NnI2rjbpNyQ3YDecN9c4FDhQOIw4yDkFOUI5fzm8Ofk6Njp0OrI67zst O2s7qjvoPCc8
ZTykPOM9Ij1hPaE94D4gPmA+oD7gPyE/YT+iP+JAI0BkQKZA50EpQWpBrEHu QjBCckK1QvdD
OkN9Q8BEA0RHRIpEzkUSRVVFmkXeRiJGZ0arRvBHNUd7R8BIBUhLSJFI10kd SWNJqUnwSjdK
fUrESwxLU0uaS+JMKkxyTLpNAk1KTZNN3E4lTm5Ot08AT0lPk0/dUCdQcVC7 UQZRUFGbUeZS
MVJ8UsdTE1NfU6pT9lRCVI9U21UoVXVVwlYPVlxWqVb3V0RXklfgWC9YfVjL WRpZaVm4Wgda
VlqmWvVbRVuVW+VcNVyGXNZdJ114XcleGl5sXr1fD19hX7NgBWBXYKpg/GFP YaJh9WJJYpxi
8GNDY5dj62RAZJRk6WU9ZZJl52Y9ZpJm6Gc9Z5Nn6Wg/aJZo7GlDaZpp8WpI ap9q92tPa6dr
/2xXbK9tCG1gbbluEm5rbsRvHm94b9FwK3CGcOBxOnGVcfByS3KmcwFzXXO4 dBR0cHTMdSh1
hXXhdj52m3b4d1Z3s3gReG54zHkqeYl553pGeqV7BHtje8J8IXyBfOF9QX2h fgF+Yn7CfyN/
hH/lgEeAqIEKgWuBzYIwgpKC9INXg7qEHYSAhOOFR4Wrhg6GcobXhzuHn4gE iGmIzokziZmJ
/opkisqLMIuWi/yMY4zKjTGNmI3/jmaOzo82j56QBpBukNaRP5GokhGSepLj k02TtpQglIqU
9JVflcmWNJaflwqXdZfgmEyYuJkkmZCZ/JpomtWbQpuvnByciZz3nWSd0p5A nq6fHZ+Ln/qg
aaDYoUehtqImopajBqN2o+akVqTHpTilqaYapoum/adup+CoUqjEqTepqaoc qo+rAqt1q+ms
XKzQrUStuK4trqGvFq+LsACwdbDqsWCx1rJLssKzOLOutCW0nLUTtYq2AbZ5 tvC3aLfguFm4
0blKucK6O7q1uy67p7whvJu9Fb2Pvgq+hL7/v3q/9cBwwOzBZ8Hjwl/C28NY w9TEUcTOxUvF
yMZGxsPHQce/yD3IvMk6ybnKOMq3yzbLtsw1zLXNNc21zjbOts83z7jQOdC6 0TzRvtI/0sHT
RNPG1EnUy9VO1dHWVdbY11zX4Nhk2OjZbNnx2nba+9uA3AXcit0Q3ZbeHN6i 3ynfr+A24L3h
ROHM4lPi2+Nj4+vkc+T85YTmDeaW5x/nqegy6LzpRunQ6lvq5etw6/vshu0R 7ZzuKO6070Dv
zPBY8OXxcvH/8ozzGfOn9DT0wvVQ9d72bfb794r4Gfio+Tj5x/pX+uf7d/wH /Jj9Kf26/kv+
3P9t////7gAOQWRvYmUAZEAAAAAB/9sAhAABAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAgICAgICAgICAgIDAwMDAwMDAwMDAQEBAQEBAQEB AQECAgECAgMD
AwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMD AwP/wAARCAMv
BAgDAREAAhEBAxEB/90ABACB/8QBogAAAAYCAwEAAAAAAAAAAAAABwgGBQQJ AwoCAQALAQAA
BgMBAQEAAAAAAAAAAAAGBQQDBwIIAQkACgsQAAIBAwQBAwMCAwMDAgYJdQEC AwQRBRIGIQcT
IgAIMRRBMiMVCVFCFmEkMxdScYEYYpElQ6Gx8CY0cgoZwdE1J+FTNoLxkqJE VHNFRjdHYyhV
VlcassLS4vJkg3SThGWjs8PT4yk4ZvN1Kjk6SElKWFlaZ2hpanZ3eHl6hYaH iImKlJWWl5iZ
mqSlpqeoqaq0tba3uLm6xMXGx8jJytTV1tfY2drk5ebn6Onq9PX29/j5+hEA AgEDAgQEAwUE
BAQGBgVtAQIDEQQhEgUxBgAiE0FRBzJhFHEIQoEjkRVSoWIWMwmxJMHRQ3Lw F+GCNCWSUxhj
RPGisiY1GVQ2RWQnCnODk0Z0wtLi8lVldVY3hIWjs8PT4/MpGpSktMTU5PSV pbXF1eX1KEdX
Zjh2hpamtsbW5vZnd4eXp7fH1+f3SFhoeIiYqLjI2Oj4OUlZaXmJmam5ydnp +So6Slpqeoqa
qrrK2ur6/9oADAMBAAIRAxEAPwC/WD489xz1VVm6fr75jTT5rH4SmqK2JviB LFWY/CSZyrwg
i01jU4jgfc9a6vGAZRP6iwWPSjNjMBoKRUB/iPH9vy6e+oSurU9aen+x1K/2 Xvu7/n3fzK/5
I+IH/wBU+6/QSfwRf70f+gut/UL/ABP+z/Y69/svfd3/AD7v5lf8kfED/wCq ffvoJP4Iv96P
/QXXvqF/if8AZ/sde/2Xvu7/AJ938yv+SPiB/wDVPv30En8EX+9H/oLr31C/ xP8As/2Ovf7L
33d/z7v5lf8AJHxA/wDqn376CT+CL/ej/wBBde+oX+J/2f7HXv8AZe+7v+fd /Mr/AJI+IH/1
T799BJ/BF/vR/wCguvfUL/E/7P8AY69/svfd3/Pu/mV/yR8QP/qn376CT+CL /ej/ANBde+oX
+J/2f7HXv9l77u/5938yv+SPiB/9U+/fQSfwRf70f+guvfUL/E/7P9jr3+y9 93f8+7+ZX/JH
xA/+qffvoJP4Iv8Aej/0F176hf4n/Z/sde/2Xvu7/n3fzK/5I+IH/wBU+/fQ SfwRf70f+guv
fUL/ABP+z/Y69/svfd3/AD7v5lf8kfED/wCqffvoJP4Iv96P/QXXvqF/if8A Z/sde/2Xvu7/
AJ938yv+SPiB/wDVPv30En8EX+9H/oLr31C/xP8As/2Ovf7L33d/z7v5lf8A JHxA/wDqn376
CT+CL/ej/wBBde+oX+J/2f7HXv8AZe+7v+fd/Mr/AJI+IH/1T799BJ/BF/vR /wCguvfUL/E/
7P8AY69/svfd3/Pu/mV/yR8QP/qn376CT+CL/ej/ANBde+oX+J/2f7HXv9l7 7u/5938yv+SP
iB/9U+/fQSfwRf70f+guvfUL/E/7P9jr3+y993f8+7+ZX/JHxA/+qffvoJP4 Iv8Aej/0F176
hf4n/Z/sde/2Xvu7/n3fzK/5I+IH/wBU+/fQSfwRf70f+guvfUL/ABP+z/Y6 9/svfd3/AD7v
5lf8kfED/wCqffvoJP4Iv96P/QXXvqF/if8AZ/sde/2Xvu7/AJ938yv+SPiB /wDVPv30En8E
X+9H/oLr31C/xP8As/2Ovf7L33d/z7v5lf8AJHxA/wDqn376CT+CL/ej/wBB de+oX+J/2f7H
Xv8AZe+7v+fd/Mr/AJI+IH/1T799BJ/BF/vR/wCguvfUL/E/7P8AY69/svfd 3/Pu/mV/yR8Q
P/qn376CT+CL/ej/ANBde+oX+J/2f7HXv9l77u/5938yv+SPiB/9U+/fQSfw Rf70f+guvfUL
/E/7P9jr3+y993f8+7+ZX/JHxA/+qffvoJP4Iv8Aej/0F176hf4n/Z/sde/2 Xvu7/n3fzK/5
I+IH/wBU+/fQSfwRf70f+guvfUL/ABP+z/Y69/svfd3/AD7v5lf8kfED/wCq ffvoJP4Iv96P
+J/2f7HUCf40dwVORxGWn61+ZT5DAy5GfE1F/iKv2kuVw9fga9/ElasM/wBx icnPFaRXC69S
2cKwsLKZQwCxZFD3H/P1ozoaVL4+X+x1P/2Xvu7/AJ938yv+SPiB/wDVPuv0 En8EX+9H/oLr
f1C/xP8As/2Ovf7L33d/z7v5lf8AJHxA/wDqn376CT+CL/ej/wBBde+oX+J/ 2f7HXv8AZe+7
v+fd/Mr/AJI+IH/1T799BJ/BF/vR/wCguvfUL/E/7P8AY69/svfd3/Pu/mV/ yR8QP/qn376C
T+CL/ej/ANBde+oX+J/2f7HXv9l77u/5938yv+SPiB/9U+/fQSfwRf70f+gu vfUL/E/7P9jr
3+y993f8+7+ZX/JHxA/+qffvoJP4Iv8Aej/0F176hf4n/Z/sde/2Xvu7/n3f zK/5I+IH/wBU
+/fQSfwRf70f+guvfUL/ABP+z/Y69/svfd3/AD7v5lf8kfED/wCqffvoJP4I v96P/QXXvqF/
if8AZ/sde/2Xvu7/AJ938yv+SPiB/wDVPv30En8EX+9H/oLr31C/xP8As/2O vf7L33d/z7v5
lf8AJHxA/wDqn376CT+CL/ej/wBBde+oX+J/2f7HXv8AZe+7v+fd/Mr/AJI+ IH/1T799BJ/B
F/vR/wCguvfUL/E/7P8AY69/svfd3/Pu/mV/yR8QP/qn376CT+CL/ej/ANBd e+oX+J/2f7HX
v9l77u/5938yv+SPiB/9U+/fQSfwRf70f+guvfUL/E/7P9jr3+y993f8+7+Z X/JHxA/+qffv
oJP4Iv8Aej/0F176hf4n/Z/sde/2Xvu7/n3fzK/5I+IH/wBU+/fQSfwRf70f +guvfUL/ABP+
z/Y69/svfd3/AD7v5lf8kfED/wCqffvoJP4Iv96P/QXXvqF/if8AZ/sde/2X vu7/AJ938yv+
SPiB/wDVPv30En8EX+9H/oLr31C/xP8As/2Ovf7L33d/z7v5lf8AJHxA/wDq n376CT+CL/ej
/wBBde+oX+J/2f7HXv8AZe+7v+fd/Mr/AJI+IH/1T799BJ/BF/vR/wCguvfU L/E/7P8AY69/
svfd3/Pu/mV/yR8QP/qn376CT+CL/ej/ANBde+oX+J/2f7HXv9l77u/5938y v+SPiB/9U+/f
QSfwRf70f+guvfUL/E/7P9jr3+y993f8+7+ZX/JHxA/+qffvoJP4Iv8Aej/0 F176hf4n/Z/s
de/2Xvu7/n3fzK/5I+IH/wBU+/fQSfwRf70f+guvfUL/ABP+z/Y69/svfd3/ AD7v5lf8kfED
/wCqffvoJP4Iv96P/QXXvqF/if8AZ/sde/2Xvu7/AJ938yv+SPiB/wDVPv30 En8EX+9H/oLr
31C/xP8As/2Ovf7L33d/z7v5lf8AJHxA/wDqn376CT+CL/ej/wBBde+oX+J/ 2f7HXv8AZe+7
3+y993f8+7+ZX/JHxA/+qffvoJP4Iv8Aej/0F176hf4n/Z/sdNeb+MXbm4sT kcFmesvmVWYr
K0stFX0ur4j0/wBxSzroli81LXQVEWpT9UdWH4Pva2UqkMFiqD/Ef8/WjOhB BZ6fZ/sdGV+3
7q/7xa71/wCpvTf/ANuD23+77j+NP966t9TH/C37Ovfb91f94td6/wDU3pv/ AO3B79+77j+N
P96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb 91f94td6/wDU
3pv/AO3B79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+N P96699TH/C37
Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb91f94td6/wDU 3pv/AO3B79+7
7j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH/C37 Ovfb91f94td6
/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+7 7j+NP96699TH
/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb91f94td6 /wDU3pv/AO3B
79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH /C37Ovfb91f9
4td6/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B 79+77j+NP966
99TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb91f9 4td6/wDU3pv/
AO3B79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP966 99TH/C37Ovfb
91f94td6/wDU3pv/AO3B79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/ AO3B79+77j+N
79+77j+NP96699TH/C37Ovfb91f94td6/wDU3pv/AO3B79+77j+NP96699TH /C37Oi84j46d
04LE4zB4rrn5l0mLw2OosVjaW3xDm+2oMdTRUlHT+aoq5qiXw08Krqkdna12 JNz7caxlYlik
NSf4j/n6qLhQAAz0+z/Y6cP9BPfH/PA/Mv8A6k/D3/r/AO9fQSfwQ/70f+gu t/UL/E/7P9jr
3+gnvj/ngfmX/wBSfh7/ANf/AH76CT+CH/ej/wBBde+oX+J/2f7HXv8AQT3x /wA8D8y/+pPw
9/6/+/fQSfwQ/wC9H/oLr31C/wAT/s/2Ovf6Ce+P+eB+Zf8A1J+Hv/X/AN++ gk/gh/3o/wDQ
XXvqF/if9n+x17/QT3x/zwPzL/6k/D3/AK/+/fQSfwQ/70f+guvfUL/E/wCz /Y69/oJ74/54
H5l/9Sfh7/1/9++gk/gh/wB6P/QXXvqF/if9n+x17/QT3x/zwPzL/wCpPw9/ 6/8Av30En8EP
+9H/AKC699Qv8T/s/wBjr3+gnvj/AJ4H5l/9Sfh7/wBf/fvoJP4If96P/QXX vqF/if8AZ/sd
e/0E98f88D8y/wDqT8Pf+v8A799BJ/BD/vR/6C699Qv8T/s/2Ovf6Ce+P+eB +Zf/AFJ+Hv8A
1/8AfvoJP4If96P/AEF176hf4n/Z/sde/wBBPfH/ADwPzL/6k/D3/r/799BJ /BD/AL0f+guv
fUL/ABP+z/Y69/oJ74/54H5l/wDUn4e/9f8A376CT+CH/ej/ANBde+oX+J/2 f7HXv9BPfH/P
A/Mv/qT8Pf8Ar/799BJ/BD/vR/6C699Qv8T/ALP9jr3+gnvj/ngfmX/1J+Hv /X/376CT+CH/
AHo/9Bde+oX+J/2f7HXv9BPfH/PA/Mv/AKk/D3/r/wC/fQSfwQ/70f8AoLr3 1C/xP+z/AGOv
f6Ce+P8AngfmX/1J+Hv/AF/9++gk/gh/3o/9Bde+oX+J/wBn+x17/QT3x/zw PzL/AOpPw9/6
/wDv30En8EP+9H/oLr31C/xP+z/Y69/oJ74/54H5l/8AUn4e/wDX/wB++gk/ gh/3o/8AQXXv
qF/if9n+x17/AEE98f8APA/Mv/qT8Pf+v/v30En8EP8AvR/6C699Qv8AE/7P 9jr3+gnvj/ng
fmX/ANSfh7/1/wDfvoJP4If96P8A0F176hf4n/Z/sde/0E98f88D8y/+pPw9 /wCv/v30En8E
P+9H/oLr31C/xP8As/2Ovf6Ce+P+eB+Zf/Un4e/9f/fvoJP4If8Aej/0F176 hf4n/Z/sde/0
E98f88D8y/8AqT8Pf+v/AL99BJ/BD/vR/wCguvfUL/E/7P8AY69/oJ74/wCe B+Zf/Un4e/8A
X/376CT+CH/ej/0F176hf4n/AGf7HXv9BPfH/PA/Mv8A6k/D3/r/AO/fQSfw Q/70f+guvfUL
/E/7P9jr3+gnvj/ngfmX/wBSfh7/ANf/AH76CT+CH/ej/wBBde+oX+J/2f7H Xv8AQT3x/wA8
D8y/+pPw9/6/+/fQSfwQ/wC9H/oLr31C/wAT/s/2Ovf6Ce+P+eB+Zf8A1J+H v/X/AN++gk/g
h/3o/wDQXXvqF/if9n+x17/QT3x/zwPzL/6k/D3/AK/+/fQSfwQ/70f+guvf UL/E/wCz/Y69
/oJ74/54H5l/9Sfh7/1/9++gk/gh/wB6P/QXXvqF/if9n+x17/QT3x/zwPzL /wCpPw9/6/8A
v30En8EP+9H/AKC699Qv8T/s/wBjr3+gnvj/AJ4H5l/9Sfh7/wBf/fvoJP4I f96P/QXXvqF/
if8AZ/sdMu4+rO29oYHL7o3Rtj5eYHb2BoKnKZnM5R/hzSUGOoKSMy1FVVVE tQqRxxov+uTY
AEkD34bfITQRxV/0x/z9e+pX+J/2f7HSf/uvvb/lT+VX/nZ8Nf8A6p9nn9TN +/6Nsf8AzkH/
AEH0R/1s2P8A6ODf7w//AEB1/9Cyz5jZfee9vnnuTpjrvHtnt7bhx/TeK27g VyWKxRyFfV9E
9e5QU4r83XY3FUt4S7ap54k4+tyPedftjb7btvtFtPMe7y+FtsIuWkfSzaVF 5OtdKKzHNPhU
nrml7z3O77x79b9ylsMHj7vO9okUetE1MbC2emqRkRcVNWYD59AR2T158i+p cpsPEb52JPQ1
fZ24W2lsWXC7p2XvLGbg3QlbQY5tu0+b2XuTcGGpc0KzJwJ9tUVEM3rvp0qx Ax2bd+T9/g3S
42zdA0dlD4s4eKaFo4qM3iFJo43KUVjqVSMcakdR/wAwbDz9yvc7La7zspSX cZ/BtzHNBOks
2pV8ISW8ssayanUaGZWzWlAaPmH6Y+UWc7G7M6mouv0h3707R4fIdk4bL796 22/TbXodwQUl
Thauoz+f3jjduV1PkaevheN6SrnUrKp4uPaW45j5Htdn2Xfpd2J2rcWdbd0g uJDK0ZIcBEha
RSpUghkXgellpyj7kXu/8w8sQ7GBve1JG13G9zaxCFZQpjYyyTpEwYMpBR2w R0nsPsL5DZ3u
nPfHnHbIkbt/bGImz+d2lWbs2Ti0x+Fhw2O3E+VfceU3LRbUmoWweWpqpJI6 51kglVkLC9ld
xuvKFry5a82zbkP6vzyBElEUzanLtHp8NYzKG1oykFBQihp0htdj58vebr3k WDZ/+RVbxGSS
FpoECxiNJdfivKsJXw3RwRIQVYEV6m7v627/ANhRU1VvDDbSwOLqd14DZA3B Wdy9LHa1Lufc
+D3HuPCYzJ7rg7Cl23iBWYbaVfMZ6uqhpofCqSyJJLCkje37zynurOm33FxL OsDzeGLS88Ux
xvHG7LEbcSPR5UGlVLGpKghWIe3Tl7nnZFjk3W0tYLZrmO38Vr+w8ETTRyyx o8wuTEmqOCRt
TuqLpAZgzIGLphO5MjuPNYjb2FkNbmM9lMfhsTRiop6c1eSylXFQ0NMJ6qaC mh89VOi65HSN
b3ZgAT7F9zy7BZ21xd3I028SM7GhNFUFmNACTQAmgBJ8h0ArPmu5v7u1sLQ6 7ueRY0WtNTuw
VRUkAVJAqSAPMgdK2u3R2LQdjbk6i/u1nsn2VtLObu25n9nbdpTurMUeX2Ec sd4wQxbabLR5
GDbsOCrJqmopnmpkpqaSfyGFS/tBFY7NLs9nv/1sSbNcRRSJNIfCQpPp8Eky aSpkLoFVgGLM
FpqNOjObceYId/v+V/3fNJzBazTxSQRAzOr22vxwBFrDiIRyM7IWQIjPq0iv Ubee9t5de02y
KveFE2Hp+x9j47sjZchyWKrv41svLZXN4TH5oLjK+tegFRlNu1sX29UIKpfD qaIIyM19t23b
d3fc49vk8R7O5a3m7WXRMio7J3KNVFkQ6l1Ka0DVBApu+77vsUezy7rD4Ud/ ZpdQHWreJbu8
kaydjNpq8Ug0vpcaalQCCUR/p+X/AJXT/wAlj/ivsz/qoP8AfXRN/XY/79/w 9LePe28putq3
t2OiZuu8fvjGdb1m4v4ligsO9MzgcvufG4X+FtXjNOanB4Krn+4WmalTxaGl WRkVixtt21d5
j5fMn+7d7ZrgR6WzCjpGz6tOjDuq6S2o1qFIBIOV3fd25fm5pWH/AHQx3iWr S61xcSRvMkej
V4hrHG7agmgaaFgxALHme3q3Ax4SWuyuFnXcGEptwUAw26dtbjkgoKqqraOK nzcO3svlJttZ
tZqCQyYzJLSZKGJo5ZIFimhd1Vty/DdG5WKCQGKUxtrikjqwAJKGRFEiUYUk j1Rk1UMWVgEV
3zRPZLZtNcwsJ4RKvhzRSkKSygSCJ3MUlVNYZdEqgqzIFdSWT/T8v/K6f+Sx /wAV9qf6qD/f
XSP+ux/37/h6Md1vsfv/ALZ2HU9m7I2lT1exKbIZTFLuLO736/2VS5DIYWmp avLU+Dg3turb
tbuE46GsjEzUEVSqSN4yfIGUA7eNz5T2HdE2Xc78ruhRW8NIZ5iquSELmGKQ R6iDTWVJGeFD
0P8Al/ZueeZ9lk5i2fa1bZVkdPFkuLa3DNGAziMXE0TS6Qw1GMOATprqBHRc f9Py/wDK6f8A
ksf8V9jH+qg/310AP67H/fv+Hp8ou1tyZLA5zdOOxWdr9sbYqMPR7l3HRYyu qsDt6r3E9dHt
+lzmXggkx+JqM7JjKlaNKiSNqpqeURhjG1ksmxWUN1a2M08SXs4cxxllDyCP SZCiE6nCal1l
QQupa0qOlsPMu43FleblBbTPt1s0ayyqjmOJpdQiEjgFUMhRxGGIL6W010mj H/p+X/ldP/JY
/wCK+1X9VB/vrpF/XY/79/w9e/0/L/yun/ksf8V9+/qoP99de/rsf9+/4evf 6fl/5XT/AMlj
/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+Sx/xX37+qg/3117+ux/37/h6 9/p+X/ldP/JY
/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/AJLH/Fffv6qD/fXXv67H/fv+ Hr3+n5f+V0/8
lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx/wAV9+/qoP8AfXXv67H/AH7/ AIevf6fl/wCV
0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yun/ksf8V9+/qoP99de/rsf9+/ 4evf6fl/5XT/
AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+Sx/xX37+qg/3117+ux/3 7/h69/p+X/ld
P/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/AJLH/Fffv6qD/fXXv67H /fv+Hr3+n5f+
V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx/wAV9+/qoP8AfXXv67H/ AH7/AIevf6fl
/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yun/ksf8V9+/qoP99de/rs f9+/4evf6fl/
5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+Sx/xX37+qg/3117+ ux/37/h69/p+
X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/AJLH/Fffv6qD/fXX v67H/fv+Hr3+
n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx/wAV9+/qoP8AfXXv 67H/AH7/AIev
f6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yun/ksf8V9+/qoP99d e/rsf9+/4evf
6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+Sx/xX37+qg/3 117+ux/37/h6
9/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/AJLH/Fffv6qD /fXXv67H/fv+
Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx/wAV9+/qoP8A fXXv67H/AH7/
AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yun/ksf8V9+/qo P99de/rsf9+/
4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+Sx/xX37+ qg/3117+ux/3
7/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/AJLH/Fff v6qD/fXXv67H
/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx/wAV9+/q oP8AfXXv67H/
AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yun/ksf8V9 +/qoP99de/rs
f9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+Sx/x X37+qg/3117+
ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/AJLH /Fffv6qD/fXX
v67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx/wAV 9+/qoP8AfXXv
67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yun/ks f8V9+/qoP99d
e/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8AK6f+ Sx/xX37+qg/3
117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8Ayun/ AJLH/Fffv6qD
/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6f+Sx /wAV9+/qoP8A
fXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/L/yu n/ksf8V9+/qo
P99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBPy/8A K6f+Sx/xX37+
qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T8v8A yun/AJLH/Fff
v6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8v/K6 f+Sx/wAV9+/q
oP8AfXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9e/0/ L/yun/ksf8V9
+/qoP99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e/wBP y/8AK6f+Sx/x
X37+qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D17/T 8v8Ayun/AJLH
/Fffv6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D17/T8 v/K6f+Sx/wAV
9+/qoP8AfXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/79/w9 e/0/L/yun/ks
f8V9+/qoP99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/AA9e /wBPy/8AK6f+
Sx/xX37+qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8Av3/D 17/T8v8Ayun/
AJLH/Fffv6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v3/D1 7/T8v/K6f+Sx
/wAV9+/qoP8AfXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/XY/7 9/w9e/0/L/yu
n/ksf8V9+/qoP99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj/v3/ AA9e/wBPy/8A
K6f+Sx/xX37+qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf12P8A v3/D17/T8v8A
yun/AJLH/Fffv6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39dj/v 3/D17/T8v/K6
f+Sx/wAV9+/qoP8AfXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7669/ XY/79/w9e/0/
L/yun/ksf8V9+/qoP99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr39dj /v3/AA9e/wBP
y/8AK6f+Sx/xX37+qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++uvf1 2P8Av3/D17/T
8v8Ayun/AJLH/Fffv6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/vrr39 dj/v3/D17/T8
v/K6f+Sx/wAV9+/qoP8AfXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/VQf7 669/XY/79/w9
e/0/L/yun/ksf8V9+/qoP99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB/vrr 39dj/v3/AA9e
/wBPy/8AK6f+Sx/xX37+qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1UH++ uvf12P8Av3/D
17/T8v8Ayun/AJLH/Fffv6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39VB/v rr39dj/v3/D1
7/T8v/K6f+Sx/wAV9+/qoP8AfXXv67H/AH7/AIevf6fl/wCV0/8AJY/4r79/ VQf7669/XY/7
9/w9e/0/L/yun/ksf8V9+/qoP99de/rsf9+/4evf6fl/5XT/AMlj/ivv39VB /vrr39dj/v3/
AA9e/wBPy/8AK6f+Sx/xX37+qg/3117+ux/37/h69/p+X/ldP/JY/wCK+/f1 UH++uvf12P8A
v3/D17/T8v8Ayun/AJLH/Fffv6qD/fXXv67H/fv+Hr3+n5f+V0/8lj/ivv39 VB/vrr39dj/v
3/D17/T8v/K6f+Sx/wAV9+/qoP8AfXXv67H/AH7/AIelNtLt4boy82CFUZPv tv7u9GoG/wBt
tPN1n0v+Pt7+4w95eX/ofbbmO60U0m3/AJ3UA/y9TX93fmk7j7xcoWXiV1i7 /lY3Lf5OtlXx
L/vr/wDFfePGs9Zpdf/RN/8AJ/urbXx4/nLP3PvSj3Dk9p9d1nQuezWN2vT0 FbnqqjHxk61p
DFi6PLZXCY2epMtWp0y1UC2BOq9geiHt9y3ec3fdrteXNtkhS/u4bxEaUsEB /eFwe4qrsBQe
Ssfl1yi91+btu5E++FuHN27wzybZYXNhJIsIVpCv7rtVoiu8aE1YfE6j59ZM h/Mp6I3Rvzo7
trdewN7xZT471Hee6tmdEbM6+6v2l0LubtjcW4Mpl+ou09wNjdzx7gw+7JBV 0tVuqeOlyDJm
cfFWYsR+Wphmeh9muabLa+ZthsN1tTBu4sopr2ae5lvo7WONUu7aPVGY3iwy 2ylo6wyNHPXS
jKkn+8FyVuO9cm8z7nsd4LnYW3Ga326C1s4dtmvZZXexvJdEwljmOpHvGCS0 niWW206pFdRt
/NU6Nn2xvnd0fTe6qPujevxpxXQVZs/dONwHdPSVa/Xu9qzK9b5XdGV7P3jW b73suR2jlpaP
PTZenral5qSm8YlbyTlGPYvmdb3bLA8xQNy5bby18JYmezvB9RCFuFiW2hEE OmVA8AiZFAd6
6RRejA/eV5Nfbt53ReU7lObbzl5NtaCZIr/b2+luGe0eZ7udrm41QOyXLTrI 5ZI9Oo6n6KD8
WvnhXdffKve/yd+RE+4uyNxbx6q3nsurnwe1tl1H3mbyW0cXtPaMddtSWp2h tCHauLx2GpqW
amgiEa0kQRaeQXUyDzx7WxbtyLtnJXKCQ2dpb30MwDyzCiLK0sumUCWUyszs wZjUualxx6iv
2396Ztj9y949xee3n3C/u9snt2McNudUjwJDAGhJggEKLGiMiigQABG4dCl8 ev5iHXmw6/bO
f7G67fA5Sg+YnW3yDy23eh+vNkbP6+o9lbI6E371JWYva+1Ydybcx2O3Nksv uOjrZIFihpKl
jVVMlSs7COQj5t9ot33SK9tNn3cSwPy9cWCSX1xNLOZpr6C6DSymORmjVI3Q NUuvYgQqKgSc
ie++w7LPt19v2w+BcpzXabm8W22tvBbLb2+23NkyQwiWJUmd5UkK6VRz4kjS BzpY/HU3ya6P
63+Bm0MpnO6dt7dkwHx62xs6X417L3v07uIZ3sKm7hwu4azsWHZ+HqaHtyj7 W3XiElOVTKU1
JiqRZJTLUzqq1fuKt+5K5m3j3S3CC15bmmEu7yTDcZobuPRAbR4xbmVw1qbW J6eEYmaVqLpR
STH1NvLHuHydy/7KbXc3nN1vbtBsUMB2m3uLGXxLoX0crXQgjK3q3syV8YTI kKAtqkcAS9Ar
tn+cVgV7Jr947yqO5KulX5FfI7J7ayeE2l1nBuna/wAUe2+vq7HbK61xs67l xoG4tu9o47b+
4q+iNT9rU1OHjlbI1EqgES3v3ebo7PFt+3Jtyv8Aufb1kV5bkxS7pazq01ww 8Nv05LZp7dH0
6lWUqIUU4CO3fetsRzBPuu7Sbs0f7+3V4njgtBNDs17aslvaIfFT9WK8S2up I9eh3gVjcOwF
eW5v5qvx8qOr5tpVWF+QfesUXX0uxanqfuva3SuM6l3/AJ9u4K3f9P3LvjMY vJ703JS9jU2H
qlIgpKGXGivQCNYlJnOrL2L5tTe1v0udp2tjdicXVnLeNdQR/SCA2kKMsMZt y4+JnEmg5LHs
63uP3luRZOXH2uW033elFibc2W4Q7ellcy/XNci/uHR7iUXQQjtSMxeIKKFF XL9uL+bb8dcj
vTb+ZbbPyB3bPHne6cxg+2t27U6Kpe1/i/juydlU229ubT+O2LoajJbcz2E2 vXxeVXzFXjJg
kaFvMSUCW09g+b4dtu7cXu026mKzR7WKW9NruTW8xkklv2YLIjyqaUiWQVJp p49Lb/70HIVx
u9jdnbt8unE1+8d7PDty3u0Jd24iih2tFLxSRwsKgzvC1AK68jqJJ/No+OLy 5+kfrzuSXJZj
LbCT/Te23eqY+5Rldr9D7761yHyMjoVzL7Oo+/Gze56WigprT0BwUUsgroKn wwpcewnOAW1k
G77cIY45/wDEvEuvpNMl9BcLt+rR4xsdEbOzdr+OVHhMmpi0fvPcgF72I7Du xuJZbb/dh4Vk
L/XDttzaNuoXxDAu5eJMkar3R/TBm8ZJNKAtq/zKMZsnr7J03UuZ7cw/cVL8 UOlei9r9l5bB
bR+4XfOwfkfvbs/eu7Mkavd+6Zqeg3L17u6Slhn0VlacnNKjokarVsMj7NTb lu0D7/bbfJy8
2/Xl7Lbo8tPBn2+G2hiWkUQLRzxBitUTwwpBJJjEfj7wVvs+x3EfK93ukXNa 8s2G3Q3bxwV+
ott1uLu4mfVPMQstrOUVqSSeKzAgKBKbTNh/NH4t722d2r3DtvsrB/HLZmS3 B8lt25fqOo3J
0Rg90925HfHWNNjMVnu1OtMflMj2e+9cdvCnnbDLgf4olfqinmq7yzUkUHbr 7cc8bbuOxcvX
mzS7xuKRbdEl0I714rNYbksyW1wyrbeC0RXxjP4ZSjKsdFWRskdk92/bfd9p 5l5r2/mCHYNp
kn3ad7Iy7dHNuD3FoESW8tFd7z6hZwxgFt4wkqrtLVniWnb4ofL/AKK6i6Ny /XPfND2Z3rjY
cnvfce2fj/nerOk9w9M0u5c3txMPhszje0N5ZTKdrdc5mSrRpaqswVAscKzO UpJ5TJJLkNz5
7e80cwcz2+8crS2W1zFIY5L5Lm8jvDGkmt0a2hVbW4SmFSd6kgVkVaBcU/bL 3U5L5W5Nutg5
1g3DercSXEsO2SWe3y2CyyRaI5EvJ3e8tZC1S8lvGAoY0idizMaHcf8AML2r sDIfDLc1XLgq
3fm4cJsfu75l716sg2t2HnN87m2dszcHWHTG2dzU8W5tjY6q3Zgdtq+dz+Ay E9IMRmsnDJTz
rU05JA9n7SX27Q+41lGsq7XDLNZ7RDcmW3SGOWaO5vJIyY5mETyUggnjDeLD GwdSj06ke/8A
fXbdjn9pdxlaB96uIbfcN+uLMQ3UlxNBBLZ2EMwE1urTRxVubm2lZPAuJkZH EkZPUet/mm9P
1Oa+XFEKT5Fzdc915PqDee0toZGbZubp92bq2T16dk9nbS7KTdW6dzV21utO 58bhMFichGlf
vGupcVj2dGeRo4Y3IvY3mFLbkGTxNnG77al3DLKomQxRTT+NbS2/hRRrLc2b PNLGSlojSyAE
AAsW5vvJcqyXfujF4W/HYd4ksZ4IHMEgmmt7X6e8gu/GmmaG0v0jt4ZQJL6R IYiQSxVFWfdf
83jpvd++sRv3rbaHZG3twbb6U+TmztnZ7JbNxFPuTZu+e19sbdoutIaaqru8 987fzWyNtblw
q1dVfF0Jxwpozj6EpPUU5LeW/u/8xbftlxtW87hZzWk25bbLMizOY5oLWSQ3 JIWyhkSaSN9K
/qv4mo+LLVUfo35v+9Lynuu82u98v7XuEF9b7Ru8EEjwIJYLi9hiW0AZtxuI pLeKWMO/6Mfh
aF8CGjyRktfyB/mVY/vzoDsnqXdMvY2dzG7+oPiljsPVZvb2yabFUnfPWNfQ VPfXYtZW4zOH
JQRb/pqVoqKqihlqalCI56ejjuAM+U/ZmXlXmvZt/sVs4re33DdGcJJMWNjc qwsbcKyaSYCa
upIVTlXkPUfc8/eDg535H5g5X3Jr+a6utq2ZUMkVuEXcrRlO5XTMkmsC5C0j cKXcUV44l6qF
803/AB1k/wCS2/4r7yA0L/COsWdTep695pv+Osn/ACW3/FfftC/wjr2pvU9e 803/AB1k/wCS
2/4r79oX+Ede1N6nr3mm/wCOsn/Jbf8AFfftC/wjr2pvU9e803/HWT/ktv8A ivv2hf4R17U3
qeveab/jrJ/yW3/FfftC/wAI69qb1PXvNN/x1k/5Lb/ivv2hf4R17U3qevea b/jrJ/yW3/Ff
ftC/wjr2pvU9e803/HWT/ktv+K+/aF/hHXtTep695pv+Osn/ACW3/FfftC/w jr2pvU9e803/
AB1k/wCS2/4r79oX+Ede1N6nr3mm/wCOsn/Jbf8AFfftC/wjr2pvU9e803/H WT/ktv8Aivv2
hf4R17U3qeveab/jrJ/yW3/FfftC/wAI69qb1PXvNN/x1k/5Lb/ivv2hf4R1 7U3qeveab/jr
J/yW3/FfftC/wjr2pvU9e803/HWT/ktv+K+/aF/hHXtTep695pv+Osn/ACW3 /FfftC/wjr2p
vU9e803/AB1k/wCS2/4r79oX+Ede1N6nr3mm/wCOsn/Jbf8AFfftC/wjr2pv U9e803/HWT/k
tv8Aivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wAI69qb1PXvNN/x1k/5Lb/i vv2hf4R17U3q
eveab/jrJ/yW3/FfftC/wjr2pvU9e803/HWT/ktv+K+/aF/hHXtTep695pv+ Osn/ACW3/Fff
tC/wjr2pvU9e803/AB1k/wCS2/4r79oX+Ede1N6nr3mm/wCOsn/Jbf8AFfft C/wjr2pvU9e8
03/HWT/ktv8Aivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wAI69qb1PXvNN/x 1k/5Lb/ivv2h
f4R17U3qeveab/jrJ/yW3/FfftC/wjr2pvU9e803/HWT/ktv+K+/aF/hHXtT ep695pv+Osn/
ACW3/FfftC/wjr2pvU9e803/AB1k/wCS2/4r79oX+Ede1N6nr3mm/wCOsn/J bf8AFfftC/wj
r2pvU9e803/HWT/ktv8Aivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wAI69qb 1PXvNN/x1k/5
Lb/ivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wjr2pvU9e803/HWT/ktv+K+/ aF/hHXtTep69
5pv+Osn/ACW3/FfftC/wjr2pvU9e803/AB1k/wCS2/4r79oX+Ede1N6nr3mm /wCOsn/Jbf8A
FfftC/wjr2pvU9e803/HWT/ktv8Aivv2hf4R17U3qeveab/jrJ/yW3/FfftC /wAI69qb1PXv
NN/x1k/5Lb/ivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wjr2pvU9e803/HWT /ktv+K+/aF/h
HXtTep695pv+Osn/ACW3/FfftC/wjr2pvU9e803/AB1k/wCS2/4r79oX+Ede 1N6nr3mm/wCO
sn/Jbf8AFfftC/wjr2pvU9e803/HWT/ktv8Aivv2hf4R17U3qeveab/jrJ/y W3/FfftC/wAI
69qb1PXvNN/x1k/5Lb/ivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wjr2pvU9 e803/HWT/ktv
+K+/aF/hHXtTep695pv+Osn/ACW3/FfftC/wjr2pvU9e803/AB1k/wCS2/4r 79oX+Ede1N6n
r3mm/wCOsn/Jbf8AFfftC/wjr2pvU9e803/HWT/ktv8Aivv2hf4R17U3qeve ab/jrJ/yW3/F
fftC/wAI69qb1PXvNN/x1k/5Lb/ivv2hf4R17U3qeveab/jrJ/yW3/FfftC/ wjr2pvU9e803
/HWT/ktv+K+/aF/hHXtTep695pv+Osn/ACW3/FfftC/wjr2pvU9e803/AB1k /wCS2/4r79oX
+Ede1N6nr3mm/wCOsn/Jbf8AFfftC/wjr2pvU9e803/HWT/ktv8Aivv2hf4R 17U3qeveab/j
rJ/yW3/FfftC/wAI69qb1PXvNN/x1k/5Lb/ivv2hf4R17U3qeveab/jrJ/yW 3/FfftC/wjr2
pvU9e803/HWT/ktv+K+/aF/hHXtTep695pv+Osn/ACW3/FfftC/wjr2pvU9e 803/AB1k/wCS
r2pvU9e803/HWT/ktv8Aivv2hf4R17U3qeveab/jrJ/yW3/FfftC/wAI69qb 1PQ1/HqSRu1s
MGkdgdv9h3BdiD/xjndh+hNvr7hn7waqPaHm0hRWtp/2m23WRH3UCT7/AHId T5X3/dtvOtz3
7f8AwH+3PvCmvy66b6Ov/9LbB7X/AJd/wa7jzVR3Z3l1TQ5beG49v7H/AL0b vyXaHZ+06Ko/
hG0dubSwnmpMJv7A7doPFi8XSUq+KCLyuoLapXZmmLlv3i9xOVNltdi2PmP6 faYGk0J4Fq+n
XK8jd8kLuau7HuY0rQUAAEJ81/d79oOed+vuaOaOUfqt9uhH4sv1V7Hq8OJI U7IbmONdMcaL
2oK0qasSSDn/AA2T/Kc/59zsb/0ojtX/AO277O/+CF92P+mxX/smsv8Atn6D 3/AnewP/AEwP
/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8A AnewP/TA/wDZ
9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/An ewP/AEwP/Z9u
X/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnew P/TA/wDZ9uX/
AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/ AEwP/Z9uX/bZ
17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA /wDZ9uX/AG2d
e/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP /Z9uX/bZ17/h
sn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ 9uX/AG2de/4b
J/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9u X/bZ17/hsn+U
5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/ AG2de/4bJ/lO
f8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ 17/hsn+U5/z7
nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2d e/4bJ/lOf8+5
2N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/h sn+U5/z7nY3/
AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4b J/lOf8+52N/6
UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U 5/z7nY3/AKUR
2r/9t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lO f8+52N/6UR2r
/wDbd9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7 nY3/AKUR2r/9
t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+5 2N/6UR2r/wDb
d9+/4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/ AKUR2r/9t337
/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6 UR2r/wDbd9+/
4IX3Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR 2r/9t337/ghf
dj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r /wDbd9+/4IX3
Y/6bFf8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9 t337/ghfdj/p
sV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDb d9+/4IX3Y/6b
Ff8Asmsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337 /ghfdj/psV/7
JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/ 4IX3Y/6bFf8A
smsv+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghf dj/psV/7JrL/
ALZ+vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3 Y/6bFf8Asmsv
+2fr3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/p sV/7JrL/ALZ+
vf8AAnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6b Ff8Asmsv+2fr
3/AnewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7 JrL/ALZ+vf8A
AnewP/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8A smsv+2fr3/An
ewP/AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ ALZ+vf8AAnew
P/TA/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv +2fr3/AnewP/
AEwP/Z9uX/bZ17/hsn+U5/z7nY3/AKUR2r/9t337/ghfdj/psV/7JrL/ALZ+ vf8AAnewP/TA
/wDZ9uX/AG2de/4bJ/lOf8+52N/6UR2r/wDbd9+/4IX3Y/6bFf8Asmsv+2fr 3/AnewP/AEwP
t337/ghfdj/psV/7JrL/ALZ+vf8AAnewP/TA/wDZ9uX/AG2dBl8i/wCXf8Gu nPjv2P3Z0b1T
Q4neG3Nvv/dfd+N7Q7P3ZRU/8Xy1LtLN+Gkze/s9t2v8uLylXSt5YJfE7Erp lRWUm5i94vcT
mvZbvYt85j+o2mcprTwLVNWiRZF744UcUdFPawrShqCQRFyn93v2g5G3+x5o 5X5R+l321Enh
S/VXsmnxInhfsmuZI21RyOvchpWoowBBwvsv9o/5N/43794h/i6W+H8uv//T 25Pnr/27++QH
/iAqr/3RY/3JHtv/AMr/AMhf9L2x/wC0yLoL83/8qhzR/wBKy5/6sP1Sh/Kv 7R3LjfiRvvrL
amXq9sfd9/7hzu7dxY9pafJjHZ/r7rTFbfwtBkaWWGuxdLVttjK1VdPTSQVb R0UVNBNCal5U
yP8AvBcsx8ze7+x2sw8SFdihYxnAal1e+fz4U/l1CXtvzFFyx7dbluNP123S RRjy8C28/wA+
jzbo6H6RyWH++oM1u/FbzS9VDvLGZehpMtT19mkWujgo8ZSxRMkvqBiaKrA/ TUCQB/cZW3I8
cs0233HLUEO2KTpIUA6iAK6tRYGgFDkH0HRzde4l6VgubcUuGAL5zozTHmOJ IHRhv5fPyT7A
3nuXtH4z91ZZtw9j9O0OD3VtjetV5VyW++r9x1NZjqWqzLzhZqzN7cydNCsl XLaeopMjSicy
1cdRPLCnOPL/APVrfbnaRMZEVEcN6Bxq01qQacP9VOpb5c3u13/aIdytV0xk spBFO5TpY/mc
59eqRv8AhQH/ANlk9af+Ky7N/wDfp9zWA/1h7zx+6FX/AFtt8qf+W5N/2i2X WNfvt/yt22/9
K2P/AKvXHVGXvKnqFeve/de697917r3v3Xuve/de697917r3v3Xuve/de6mV uLzWL29gt3Zj
bu58DtDdX96ztHd+4dsZ/b+094psTLjAb4m2bubM46hwe7qbZmcdaPLS42oq o8dUyJHUNG7o
GBG2e5HI+8blzJtFjzHB+8do8T6xJA8PgrCzJM5aZY1eKJlIlljZ446oXYB0 LCS95Q5lsLPZ
7+52iT6S/wBH07Lpk8QyKGjUCMsVdwwKIwV2o2lSVakncG39zbQ3Dmto712n vDYm79uVNJSb
g2hv3aW5NjbswlRkMRjc/j48rtndmLw+cx/8QweYpKyAy06rNTVEciFkcEru UedeWee9tn3f
lTc/qtujnMLP4csVJFVHK6Zo42NFkQ1Clc0BqCAm37lzeeWLyOw3yz8C7eMS BdaPVCzKDWNn
HFGFCa44UIruZ/yU/wDsgrY//h89lf8AvUVXvnf94L/p8POf+mtP+0C16y59 pf8Ap3vL3/N/
/tJm6tj9w31I3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+6917 37r3Xvfuvde9
+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3 Xvfuvde9+691
737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfu vde9+691737r
3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9 +691737r3Xvf
uvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691 737r3Xvfuvde
9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r 3Xvfuvde9+69
1737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvf uvde9+691737
r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde 9+691737r3Sd
3durDbH21md2bhnkpsNg
Re: Object null within Qooxdoo code [message #139367 is a reply to message #139356] Mon, 06 July 2009 05:51 Go to previous messageGo to next message
Hi Jessica,
The source of the movie is wrong - see the object/embed tag on your
screenshot (double http://www.youtube.com/v/...) About the size - there
are "changeWidth" and "changeHeight" qooxdoo events that you can listen
to and set the video size manually based on them.
Best,
Ivan
> Hello Ivan,
> of its container-Element?
> Best regards,
> Jes
>> Hi Jessica,
>> Best,
>> Ivan
>>> Hi Ivan,
>>> unfortunately the video doesn't show up. Do you have any idea about
>>> this. The _onAppear function is entered - tested by some alert - and
>>> the link of the video will be given to the widget too.
>>>> Hi Jessica.
>>>> widget element is already created ) and put your flash
>>>> members : {
>>>> Best,
>>>> Ivan
>>>>> Hello everyone,
>>>>> So the
>>>>> was started a second time. The latter was suggested by Ivan in a
>>>>> previous thread
Re: Object null within Qooxdoo code [message #139428 is a reply to message #139367] Mon, 06 July 2009 09:43 Go to previous message
Thanks a lot, Ivan!
> Hi Jessica,
> Best,
> Ivan
>> Hello Ivan,
>> Best regards,
>> Jes
>>> Hi Jessica,
>>> Best,
>>> Ivan
>>>> Hi Ivan,
>>>>> Hi Jessica.
>>>>> members : {
>>>>> Best,
>>>>> Ivan
>>>>>> Hello everyone,
>>>>>> So the
>>>>>> previous thread
Previous Topic:UI component not reclaimed
Next Topic:cell editors on client-side
Current Time: Wed Jul 23 21:38:46 EDT 2025
Powered by FUDForum. Page generated in 0.05106 seconds
