Home » Newcomers » Newcomers » Can't remove colour scheme from Eclipse Luna(Can't remove colour scheme from Eclipse Luna)
Can't remove colour scheme from Eclipse Luna [message #1389777] Sat, 28 June 2014 05:54 Go to next message
Apologies if this is not the best forum for my question.
I just downloaded Eclipse Luna CDT and tried out the "Dark" colour scheme. It had the deficiency that the editor window background was not set to a dark colour so I googled around and found the Moonrise UI at guari dot github dot io slash eclipse-ui-theme . I installed RainbowDrops.epf and this did set my editor colours to dark but the scrollbars were not affected. I checked and found this is not supported yet so tried switching out of the dark scheme back to Windows 7 but it has not worked : all my editor windows are still in the dark colour scheme. I deleted my entire Eclipse directory and tried again but it is still the same :
whenever I switch to W7 theme the line numbers are still dark and as soon as I restart E Luna the dark editor colours return.
All ideas greatefully received,
Mike
Re: Can't remove colour scheme from Eclipse Luna [message #1392084 is a reply to message #1389777] Tue, 01 July 2014 17:37 Go to previous messageGo to next message
If you look in the plugins directory you'll find something like "org.eclipse" one of them will contain a folder called "css" find it and delete everything inside of it. Eclipse better obeys native settings then, this works really well on Kepler, I've actually posted something about how bad Luna is.
Alec
Re: Can't remove colour scheme from Eclipse Luna [message #1392115 is a reply to message #1392084] Tue, 01 July 2014 18:42 Go to previous message
I think you need to be a little more specific when recommending deleting contents from the plugins directory.
Previous Topic:Unhandled loop exception when moving frames around
Next Topic:Somehow screwed up my editor
Current Time: Tue Jul 22 02:16:23 EDT 2025
Powered by FUDForum. Page generated in 0.10267 seconds
