Home » Eclipse Projects » Oomph » Create mylyn query in user .setup, episode 2
Create mylyn query in user .setup, episode 2 [message #1392052] Tue, 01 July 2014 16:27 Go to next message
I recall my need : setting up a bugzilla query in my user .setup file so
that this query is available in all my eclipse instances.
Step 1 : I tried to create the task WITHOUT installing Oomph tools in me
eclipse instance (see the post : Could not figure out how to create a
mylyn query task). I learnedhow to directly edit the .xmi file to add the
required xmlns to copy/past such query from oomph.setup file. My
underknowledge of EMF engine does not enable me to understand deeply how
this worked but the .setup produced this way was validated...
Step 2 : I created the query in my user.setup using the classical create
child of emf tree editor : now that the oomph tools and oomph mylyn
queries are installed, I guess that the top setup .ecore model has been
extended with new element, which I can add with the tree editor.
Step 3 : test the user.setup - I did this by pushing the "Perform the
setup task..." action (which I suppose relaunch the setup chain
eclipseInstallTasks/projectTasks/userTasks that lead to my running
eclipse)... I probably had an error in my .setup, because I saw only one
variable upon two. For my user setup file, I did not see anything in my
outline view
Step 4 : created a dummy project.setup model, which I populated with the
setup task to create my bugzilla query, along with the two variables I
needed (user and passwd). I dragged this setup on Oomph installer project
catalog, and I saw my two variables prompted for a value : conclusion the
file is OK
Step 5 : I loaded dummy project .setup model as external project in my
user .setup file, and copy pasted bugzilla query in my user. setup and
launched "Perform the setup task..." again, which lead to the following
error below :
Thank you in advance for any help
Cedric, frustrated, but still happy :)
[21:57:55] Executing startup tasks
[21:57:55] Performing setup task Mylyn Queries https://bugs.eclipse.org/
bugs/buglist.cgi?
product=Oomph&bug_status=UNCONFIRMED&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&bug_severity=blocker&bug_severity=critical&bug_severity=major&bug_severity=normal&bug_severity=minor&bug_severity=trivial
(bugzilla)
[21:57:55] Adding bugzilla repository: https://bugs.eclipse.org/bugs/
buglist.cgi?
[21:57:55] org.eclipse.core.runtime.AssertionFailedException: assertion
failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
at
org.eclipse.mylyn.internal.tasks.ui.util.TasksUiInternal.synchronizeQueries
(TasksUiInternal.java:386)
at org.eclipse.oomph.setup.mylyn.impl.MylynQueriesTaskImpl
$MylynHelperImpl.perform(MylynQueriesTaskImpl.java:595)
at org.eclipse.oomph.setup.mylyn.impl.MylynQueriesTaskImpl.perform
(MylynQueriesTaskImpl.java:474)
at
org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.doPerformNeededSetupTasks
(SetupTaskPerformer.java:2288)
at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.access$0
(SetupTaskPerformer.java:2261)
$WorkspaceUtil$1.run(SetupTaskPerformer.java:2985)
at org.eclipse.core.internal.resources.Workspace.run
(Workspace.java:2313)
$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:2979)
$WorkspaceUtil.access$0(SetupTaskPerformer.java:2977)
at
org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.performNeededSetupTasks
(SetupTaskPerformer.java:2252)
at
org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.performTriggeredSetupTasks
(SetupTaskPerformer.java:2236)
at org.eclipse.oomph.internal.setup.core.SetupTaskPerformer.perform
(SetupTaskPerformer.java:2178)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$7.run
(ProgressPage.java:358)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9$1.run
(ProgressPage.java:435)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
[21:57:55] ERROR: org.eclipse.oomph.setup.core code=0 assertion failed:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at
at
at
at
[21:57:55] Took 0 seconds.
[21:57:55] Press Finish to close the dialog.
Re: Create mylyn query in user .setup, episode 2 [message #1392268 is a reply to message #1392052] Wed, 02 July 2014 00:34 Go to previous messageGo to next message
Cedric,
Comments below.
That sounds scary. Certainly we've tried hard to make the XMI human
readable, to the extent one can even reasonably argue that XML in
general ought to be human readable in the first place. E.g., use
singular element names for multi-valued features that have a plural name
in the model, and setting a very narrow line width limit so that
generally each attribute and element is on a separate line, but editing
by hand the text is still very error prone.
> My
Note that in the latest version we've added a discovery catalog. So
you'll see in the new menu when creating a task, that there an
"Additional Tasks" submenu for models that are registered (in the index)
but not installed. Choosing one of those will bring up the update
wizard, install the associated bundles, and restart the IDE.
The models contain discovery information, so when you install an IDE,
each task's model is inspected and all bundles needed by all tasks that
will be performed in the launched IDE are installed automatically.
> variable upon two.
Not sure what this means, but note there is a "Show all variables"
checkbox, so you'll generally be prompted for very few things, once
you've been prompted once and those values have been recorded in your
user.setup.
> outline view
No, the outline view is only meaning relative to a stream. Although I
suppose we could consider showing an outline relative to an empty stream
of an empty project...
> file is OK
> error below :
Does your query look like this Oomph one?
<setupTask
xsi:type="mylyn:MylynQueriesTask"
repositoryURL="https://bugs.eclipse.org/bugs"
userID="${bugzilla.id}"
password="${eclipse.user.password}">
<query
summary="Bugs in ${bugzilla.version}"
url="https://bugs.eclipse.org/bugs/buglist.cgi?product=Oomph&amp;bug_status=UNCONFIRMED&amp;bug_status=NEW&amp;bug_status=ASSIGNED&amp;bug_status=REOPENED&amp;version=${bugzilla.version}&amp;bug_severity=blocker&amp;bug_severity=critical&amp;bug_severity=major&amp;bug_severity=normal&amp;bug_severity=minor&amp;bug_severity=trivial"/>
<query
summary="Features in ${bugzilla.version}"
url="https://bugs.eclipse.org/bugs/buglist.cgi?product=Oomph&amp;bug_status=UNCONFIRMED&amp;bug_status=NEW&amp;bug_status=ASSIGNED&amp;bug_status=REOPENED&amp;version=${bugzilla.version}&amp;bug_severity=enhancement"/>
<query
summary="Resolved in ${bugzilla.version}"
url="https://bugs.eclipse.org/bugs/buglist.cgi?product=Oomph&amp;bug_status=RESOLVED&amp;resolution=FIXED&amp;version=${bugzilla.version}"/>
<query
summary="Unspecified Version"
url="https://bugs.eclipse.org/bugs/buglist.cgi?product=Oomph&amp;version=unspecified"/>
</setupTask>
Note though that I'm not happy with the current design of prompting for
a password and storing it in secure storage independant of the place
Mylyn normally stores the password. In the past weeks I had to update
my password, and the one stored by Oomph kept getting applied, with no
way for me to update it....
Include the XML of your task so we can try it out...
> bugs/buglist.cgi?
> (bugzilla)
> buglist.cgi?
> failed:
> at
> at
> at
> at
> at
> at
> at
> at
Re: Create mylyn query in user .setup, episode 2 [message #1392783 is a reply to message #1392268] Wed, 02 July 2014 17:14 Go to previous messageGo to next message
Hello Ed
Thank you for your answer. My answers belox
On Wed, 02 Jul 2014 06:34:56 +0200, Ed Merks wrote :
> Cedric,
> Comments below.
>> so that this query is available in all my eclipse instances.
>> me eclipse instance (see the post : Could not figure out how to create
>> a mylyn query task). I learnedhow to directly edit the .xmi file to add
>> the required xmlns to copy/past such query from oomph.setup file.
Ok if it is scary for you, then it is not a recommended way. I can safely
rely on my old habit to use emf tree editor :-)
> but not installed.
What is this index ? Some EMF internal or a feature/element of Oomph
metamodel ?
>> create child of emf tree editor : now that the oomph tools and oomph
>> mylyn queries are installed, I guess that the top setup .ecore model
>> has been extended with new element, which I can add with the tree
>> editor.
Does these discovery informations enable Oomph to install both Oomph
bundles and dependant bundles (example : Oomph mylyn bundle and the
official org.eclipse.mylyn required bundles) ? It should be the best,
because it ensures that the IDE is operational, but looks trickier.
In case of creating a user .setup, just for managing many different
eclipses (Topcased, CDT, Customs.. )
That was one of my Questions : how to manage password. At the moment I
have set "store prompted value" to false, but I am not sure that's the
good way.
Damn I only created the setuptask, not the query!
I continue my tests :)
Re: Create mylyn query in user .setup, episode 2 [message #1392974 is a reply to message #1392783] Thu, 03 July 2014 00:09 Go to previous messageGo to next message
Cedric,
Comments below.
On 02/07/2014 11:14 PM, cedric wrote:
> Hello Ed
>> Cedric,
>> Comments below.
>> but not installed.
> metamodel ?
The root object that's loaded from which all the information about
products and projects are loaded.
http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
>>> editor.
Yes, and not so tricky. The oomph bundles themselves specify their
dependencies so we need only "discover" the annotations that specify
which additional oomph bundles need to be installed along with a p2 site
to satisfy the Mylyn dependencies it has.
So you're creating tasks that are restricted to certain products or
projects? In the end, only the SetupTaskPerformer interprets the
meaning of the tasks, and it needs a SetupContext that specifies a
ProductVersion and zero or more Streams and the outline must be relative
to those context.
> good way.
As I mentioned, I don't like the way we currently manage the passwords.
Generally I think we shouldn't manage it. Each technology that needs
passwords already manages that, generally prompting when it needs one
and storing it where it expects to find it again the next time it needs it.
In the latest builds of Oomph, I've enhanced the Preferences model to
include the secure storage preferences so you if install Oomph
Preferences Management you'll see there is an Oomph -> All Preferences
preferences page with an Edit... button. This allows you to inspect all
preferences, including secure preferences, even allowing you to edit
them and save them, also including the ability to set/modify passwords
in the secure storage, or even to inspect them, if you turn on the
advanced filter in the properties view and change the Secure property to
false.
So I imagine using the paths for such secure properties in the
Preferences Task and having the variable for a prompted value being
stored to the secure storage that way.
Can you explain what specifically you need to manage passwords for? The
whole security thing associated with passwords makes me a little
paranoid, so I've been careful that I don't store clear-text secure
values in the Preferences model, but I think we'd need to be equally
paranoid about how their stored in the Setup models so that don't end up
in logs or in outline views, or anywhere else...
Hehehe. Looking at an existing example is always a good idea. Note that
the Setup Editor has a new feature, i.e., the tool bar button to show
the whole resource set. When editing the user.setup, you'll generally
see the resource set is full of the entire index, so from there you can
see all the existing projects and can copy their tasks.
Re: Create mylyn query in user .setup, episode 2 [message #1395390 is a reply to message #1392974] Sun, 06 July 2014 17:32 Go to previous messageGo to next message
Hello
I managed to get my query created after executing setup tasks !!
>>> stream of an empty project...
> to those context.
For this point, I definitely has to take a look at the Oomph MetaModel to
be able to get the best of your answers.
Cedric
Password secure storage with Oomph [message #1395397 is a reply to message #1392974] Sun, 06 July 2014 17:46 Go to previous message
I moved this part of my post into a new thread, since it is dedicated to
password management.
>>> for a password and storing it in secure storage independant of the
>>> place Mylyn normally stores the password. In the past weeks I had to
>>> update my password, and the one stored by Oomph kept getting applied,
>>> with no way for me to update it....
>> good way.
> it.
> false.
I will have a look at it
I am paranoid too regarding passwords, and to be honest, I think it is the
major reason why I issued such question.
From my point of you, I would not store passwords but rely on each bundle
secure storage. Hence, any variable tagged as "password" shall be input
with special obfuscated text input widget (with * in place of each
character).
cedric
Previous Topic:Variables in targlet requirement versions?
Next Topic:Variable for .setup file location
Current Time: Wed Jul 23 15:00:46 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
