Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » ECP 1.3.x RAP target does not resolve
ECP 1.3.x RAP target does not resolve [message #1387168] Tue, 24 June 2014 11:01 Go to next message
I tried to use RAP with Luna and ECP 1.3.
According to this thread:
https://www.eclipse.org/forums/index.php/m/1220805/#msg_1220805
the target file "ecpRAP.target" within the bundle org.eclipse.emf.ecp.target.rap should be used. However I get the following problems when trying to use it:
index.php/fa/18357/0/
I tried to use the latest target file from the master branch instead of the 1.3 branch - no success either.
Help is very much appreciated.
Thx,
Chris
Re: ECP 1.3.x RAP target does not resolve [message #1389020 is a reply to message #1387168] Fri, 27 June 2014 04:07 Go to previous messageGo to next message
Hi Chris,
I updated the target files on the master branch. Because of the Luna release, Milestones and RC versions were deleted.
Thank you for the report.
Eugen
Re: ECP 1.3.x RAP target does not resolve [message #1391123 is a reply to message #1389020] Mon, 30 June 2014 09:28 Go to previous messageGo to next message
Hi Eugen,
thx for the update. It is working now in general.
However I can not use a view model to customize the views with RAP.
If I add one via the plugin extension point the object is not rendered and I get a NPE instead.
I guess I need to add some more bundles to the run config in order to use a view model.
I started by adding only the bundle org.eclipse.emf.ecp.view.editor.controls and pressing "Add Required Bundles".
This increased the number of plugins from 138 to 183.
Unfortunately this configuration throws a ton of errors already during startup.
Could you please give me a hint how to determine which bundles I must add to my run confguration? I am really having a hard time finding out which bundles I need. Seems like every time there are either some bundles missing or some conflictiong bundles.
Here is the NPE I get when I use the original "ecpRapDemo" run config and try to open a view with a view model attached:
2014-06-30 14:31:22.256:INFO:oejs.Server:jetty-8.1.14.v20131031
2014-06-30 14:31:22.511:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:52979
UIProviderDescriptor: org.eclipse.emf.ecp.emfstore.ui [36] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.ui_1.3.0.20140610-1229.jar
osgi> ProviderDescriptor: org.eclipse.emf.ecp.emfstore.core [7] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.core_1.3.0.20140610-1229.jar
Loading ECPProjectManagerImpl from E:\Develop\Workspaces\DataFlow\.metadata\.plugins\org.eclipse.rap.tools.launch\ecpRapDemo\.metadata\.plugins\org.eclipse.emf.ecp.core\projects
Loading ECPRepositoryManagerImpl from E:\Develop\Workspaces\DataFlow\.metadata\.plugins\org.eclipse.rap.tools.launch\ecpRapDemo\.metadata\.plugins\org.eclipse.emf.ecp.core\repositories
RepositoryDescriptor: org.eclipse.emf.ecp.emfstore.ui [36] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.ui_1.3.0.20140610-1229.jar
!SESSION 2014-06-30 14:31:09.796 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Command-line arguments:  -dev file:E:/Develop/Workspaces/DataFlow/.metadata/.plugins/org.eclipse.pde.core/ecpRapDemo/dev.properties -os win32 -ws win32 -arch x86_64 -console -consolelog -data E:\Develop\Workspaces\DataFlow/.metadata/.plugins/org.eclipse.rap.tools.launch/ecpRapDemo
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:31:44.289
!MESSAGE Value not found.
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:31:44.300
!MESSAGE Error while instantiating location provider or none configured, switching to default location!
!ENTRY org.eclipse.emf.emfstore.client 2 2 2014-06-30 14:31:44.492
!MESSAGE No EMFStore migrator registered.
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.080
!MESSAGE Resource save options initialized:
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.089
!MESSAGE 	USE_ENCODED_ATTRIBUTE_STYLE: true
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.097
!MESSAGE 	USE_CACHED_LOOKUP_TABLE: []
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.105
!MESSAGE 	ENCODING: UTF-8
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.112
!MESSAGE 	FLUSH_THRESHOLD: 100000
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-06-30 14:32:04.120
!MESSAGE 	USE_FILE_BUFFER: true
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2014-06-30 14:32:04.389
!MESSAGE EMFStoreProvider received INIT for ECPProjectImpl efgt
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2014-06-30 14:32:04.399
!MESSAGE EMFStoreProvider received CREATE for ECPProjectImpl efgt
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2014-06-30 14:32:04.417
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 14:32:31.797
!MESSAGE An unexpected exception was thrown.
!STACK 0
	at org.eclipse.emf.ecp.editor.internal.e3.MEEditorPage.dispose(MEEditorPage.java:224)
	at org.eclipse.ui.forms.editor.FormEditor.dispose(FormEditor.java:409)
	at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.dispose(SharedHeaderFormEditor.java:160)
	at org.eclipse.emf.ecp.editor.internal.e3.MEEditor.dispose(MEEditor.java:322)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:703)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:464)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:599)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:310)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:185)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:265)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:64)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:479)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1262)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1215)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1614)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:508)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:106)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:494)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:115)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:65)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:775)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:673)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:633)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2855)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2763)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2755)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2706)
	at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2702)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2686)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2677)
	at org.eclipse.emf.ecp.explorereditorbridge.internal.EditorModelElementOpener.openModelElement(EditorModelElementOpener.java:58)
	at org.eclipse.emf.ecp.internal.ui.util.ECPHandlerHelper.openModelElement(ECPHandlerHelper.java:448)
	at org.eclipse.emf.ecp.internal.ui.util.ECPHandlerHelper.addModelElement(ECPHandlerHelper.java:203)
	at org.eclipse.emf.ecp.ui.commands.NewModelElementWizardHandler.execute(NewModelElementWizardHandler.java:40)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:304)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:167)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:239)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:834)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:820)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:810)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:700)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:602)
	at org.eclipse.swt.widgets.Display.executeNextEvent(Display.java:1212)
	at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1193)
	at org.eclipse.swt.widgets.Display.safeReadAndDispatch(Display.java:1176)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1168)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
	at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:701)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:684)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
	at org.eclipse.emf.ecp.rap.Application.createUI(Application.java:39)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:172)
	at org.eclipse.rap.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:284)
	at java.lang.Thread.run(Thread.java:662)
	at org.eclipse.rap.rwt.internal.lifecycle.UIThread.run(UIThread.java:105)
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 14:32:31.811
!MESSAGE Unable to create editor ID org.eclipse.emf.ecp.editor: There must be exactly one LayoutProvider!
Found 0 providers.
!STACK 0
java.lang.IllegalStateException: There must be exactly one LayoutProvider!
Found 0 providers.
	at org.eclipse.emf.ecp.view.spi.swt.layout.LayoutProviderHelper.checkProviderLength(LayoutProviderHelper.java:142)
	at org.eclipse.emf.ecp.view.spi.swt.layout.LayoutProviderHelper.getColumnLayout(LayoutProviderHelper.java:107)
	at org.eclipse.emf.ecp.view.spi.horizontal.swt.HorizontalLayoutSWTRenderer.renderControl(HorizontalLayoutSWTRenderer.java:105)
	at org.eclipse.emf.ecp.view.spi.swt.AbstractSWTRenderer.render(AbstractSWTRenderer.java:213)
	at org.eclipse.emf.ecp.view.spi.core.swt.ContainerSWTRenderer.renderControl(ContainerSWTRenderer.java:155)
	at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:80)
	at org.eclipse.emf.ecp.editor.internal.e3.MEEditorPage.createFormContent(MEEditorPage.java:131)
	at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:152)
	at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormPage.java:150)
	at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor.java:477)
	at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1070)
	at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEditor.java:616)
	at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.createPages(SharedHeaderFormEditor.java:103)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:668)
!ENTRY org.eclipse.emf.ecp.ui 4 0 2014-06-30 14:32:31.829
!MESSAGE java.lang.NullPointerException
!STACK 0
	at org.eclipse.emf.ecp.editor.e3.MEEditorInput.getName(MEEditorInput.java:150)
	at org.eclipse.ui.internal.ErrorEditorPart.init(ErrorEditorPart.java:82)
	at org.eclipse.ui.internal.EditorReference.getEmptyEditor(EditorReference.java:795)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:485)
If I add the controls-bundle + required plugins as described above I get this:
!ENTRY org.eclipse.rap.ui 2 2 2014-06-30 15:07:22.662
!MESSAGE Could not start styling support.
!STACK 0
java.lang.NoSuchMethodException: org.eclipse.e4.ui.css.swt.internal.theme.BootstrapTheme3x.<init>(org.eclipse.swt.widgets.Display)
	at java.lang.Class.getConstructor0(Class.java:2706)
	at java.lang.Class.getConstructor(Class.java:1657)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2568)
!ENTRY org.eclipse.rap.ui 4 4 2014-06-30 15:07:23.222
!MESSAGE The proxied handler for 'org.eclipse.ui.internal.handlers.SaveHandler' could not be loaded
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 15:07:23.231
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveHandler".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:361)
	at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:330)
	at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
	at org.eclipse.core.commands.Command.setHandler(Command.java:1025)
	at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:457)
	at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:247)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:118)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:110)
	at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:105)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.readDefaultHandlersFromRegistry(HandlerPersistence.java:271)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:226)
	at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:180)
	at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:184)
	at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:59)
	at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
	at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:173)
	at org.eclipse.ui.internal.Workbench$40.runWithException(Workbench.java:1899)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:230)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:1092)
	at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:110)
	at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:1895)
	at org.eclipse.ui.internal.Workbench.init(Workbench.java:1593)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2655)
	at org.eclipse.ui.internal.handlers.DirtyStateTracker.<init>(DirtyStateTracker.java:37)
	at org.eclipse.ui.internal.handlers.AbstractSaveHandler.<init>(AbstractSaveHandler.java:38)
	at org.eclipse.ui.internal.handlers.SaveHandler.<init>(SaveHandler.java:37)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
	at java.lang.Class.newInstance0(Class.java:355)
	at java.lang.Class.newInstance(Class.java:308)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
	... 38 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-06-30 15:07:23.235
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveHandler".
!STACK 0
!ENTRY org.eclipse.rap.ui 4 4 2014-06-30 15:07:23.246
!MESSAGE The proxied handler for 'org.eclipse.ui.internal.handlers.SaveAsHandler' could not be loaded
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 15:07:23.255
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAsHandler".
	at org.eclipse.ui.internal.handlers.SaveAsHandler.<init>(SaveAsHandler.java:32)
	... 38 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-06-30 15:07:23.258
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAsHandler".
!STACK 0
!ENTRY org.eclipse.rap.ui 4 4 2014-06-30 15:07:23.269
!MESSAGE The proxied handler for 'org.eclipse.ui.internal.handlers.SaveAllHandler' could not be loaded
!ENTRY org.eclipse.rap.ui 4 0 2014-06-30 15:07:23.277
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAllHandler".
	at org.eclipse.ui.internal.handlers.SaveAllHandler.<init>(SaveAllHandler.java:38)
	... 38 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2014-06-30 15:07:23.280
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.handlers.SaveAllHandler".
!STACK 0
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.699
!MESSAGE A handler conflict occurred.  This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.699
!MESSAGE Conflict for 'org.eclipse.ui.newWizard':
HandlerActivation(commandId=org.eclipse.ui.newWizard,
	handler=org.eclipse.ui.internal.handlers.WizardHandler$New@2bb15387,
	expression=,sourcePriority=0)
	handler=org.eclipse.ui.internal.handlers.WizardHandler$New,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.708
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.708
!MESSAGE Conflict for 'org.eclipse.ui.file.import':
HandlerActivation(commandId=org.eclipse.ui.file.import,
	handler=org.eclipse.ui.internal.handlers.WizardHandler$Import,
	handler=org.eclipse.ui.internal.handlers.WizardHandler$Import@23f3329a,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.717
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.718
!MESSAGE Conflict for 'org.eclipse.ui.file.export':
HandlerActivation(commandId=org.eclipse.ui.file.export,
	handler=org.eclipse.ui.internal.handlers.WizardHandler$Export,
	handler=org.eclipse.ui.internal.handlers.WizardHandler$Export@666558bb,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.726
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.726
!MESSAGE Conflict for 'org.eclipse.ui.file.properties':
HandlerActivation(commandId=org.eclipse.ui.file.properties,
	handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler,
	handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler@3e91cc3a,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.734
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.734
!MESSAGE Conflict for 'org.eclipse.ui.file.exit':
HandlerActivation(commandId=org.eclipse.ui.file.exit,
	handler=org.eclipse.ui.internal.handlers.QuitHandler@6b8a3745,
	handler=org.eclipse.ui.internal.handlers.QuitHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.742
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.743
!MESSAGE Conflict for 'org.eclipse.ui.window.newWindow':
HandlerActivation(commandId=org.eclipse.ui.window.newWindow,
	handler=org.eclipse.ui.internal.handlers.OpenInNewWindowHandler@38e02fc4,
	handler=org.eclipse.ui.internal.handlers.OpenInNewWindowHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.750
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.751
!MESSAGE Conflict for 'org.eclipse.ui.window.switchToEditor':
HandlerActivation(commandId=org.eclipse.ui.window.switchToEditor,
	handler=org.eclipse.ui.internal.WorkbenchEditorsHandler,
	handler=org.eclipse.ui.internal.WorkbenchEditorsHandler@2635ee49,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.759
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.759
!MESSAGE Conflict for 'org.eclipse.ui.window.minimizePart':
HandlerActivation(commandId=org.eclipse.ui.window.minimizePart,
	handler=org.eclipse.ui.internal.handlers.MinimizePartHandler,
	handler=org.eclipse.ui.internal.handlers.MinimizePartHandler@72de4f4b,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.767
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.768
!MESSAGE Conflict for 'org.eclipse.ui.file.closePart':
HandlerActivation(commandId=org.eclipse.ui.file.closePart,
	handler=org.eclipse.ui.internal.handlers.ClosePartHandler@61202afe,
	handler=org.eclipse.ui.internal.handlers.ClosePartHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.783
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.783
!MESSAGE Conflict for 'org.eclipse.ui.window.preferences':
HandlerActivation(commandId=org.eclipse.ui.window.preferences,
	handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler,
	handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@361c98b2,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.794
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.795
!MESSAGE Conflict for 'org.eclipse.ui.views.showView':
HandlerActivation(commandId=org.eclipse.ui.views.showView,
	handler=org.eclipse.ui.handlers.ShowViewHandler,
	handler=org.eclipse.ui.handlers.ShowViewHandler@24f61f5c,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.803
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.803
!MESSAGE Conflict for 'org.eclipse.ui.help.displayHelp':
HandlerActivation(commandId=org.eclipse.ui.help.displayHelp,
	handler=org.eclipse.ui.internal.handlers.DisplayHelpHandler@3864064b,
	handler=org.eclipse.ui.internal.handlers.DisplayHelpHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.820
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.821
!MESSAGE Conflict for 'org.eclipse.ui.perspectives.showPerspective':
HandlerActivation(commandId=org.eclipse.ui.perspectives.showPerspective,
	handler=org.eclipse.ui.handlers.ShowPerspectiveHandler,
	handler=org.eclipse.ui.handlers.ShowPerspectiveHandler@4b3ca972,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.830
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:23.831
!MESSAGE Conflict for 'org.eclipse.ui.navigate.showIn':
HandlerActivation(commandId=org.eclipse.ui.navigate.showIn,
	handler=org.eclipse.ui.internal.ShowInHandler@219baf0b,
	handler=org.eclipse.ui.internal.ShowInHandler,
ProviderDescriptor: org.eclipse.emf.ecp.emfstore.core [8] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.emfstore.core_1.3.0.20140610-1229.jar
ProviderDescriptor: org.eclipse.emf.ecp.workspace.core [122] --> file:E:\eclipse\IDEs\eclipse-4.4-luna-x64\plugins\org.eclipse.emf.ecp.workspace.core_1.3.0.20140610-1229.jar
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.036
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.037
!MESSAGE Conflict for 'org.eclipse.ui.window.activateEditor':
HandlerActivation(commandId=org.eclipse.ui.window.activateEditor,
	handler=org.eclipse.ui.internal.ActivateEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.045
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.046
!MESSAGE Conflict for 'org.eclipse.ui.window.showSystemMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showSystemMenu,
	handler=org.eclipse.ui.internal.ShowPartPaneMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.053
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.054
!MESSAGE Conflict for 'org.eclipse.ui.window.showViewMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showViewMenu,
	handler=org.eclipse.ui.internal.ShowViewMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.062
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.062
!MESSAGE Conflict for 'org.eclipse.ui.file.close':
HandlerActivation(commandId=org.eclipse.ui.file.close,
	handler=org.eclipse.ui.internal.CloseEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.071
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.071
!MESSAGE Conflict for 'org.eclipse.ui.file.closeAll':
HandlerActivation(commandId=org.eclipse.ui.file.closeAll,
	handler=org.eclipse.ui.internal.CloseAllHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.081
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.082
!MESSAGE Conflict for 'org.eclipse.ui.file.closeOthers':
HandlerActivation(commandId=org.eclipse.ui.file.closeOthers,
	handler=org.eclipse.ui.internal.CloseOthersHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.091
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.092
!MESSAGE Conflict for 'org.eclipse.ui.ToggleCoolbarAction':
HandlerActivation(commandId=org.eclipse.ui.ToggleCoolbarAction,
	handler=org.eclipse.ui.internal.handlers.ToggleCoolbarHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.100
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.101
!MESSAGE Conflict for 'org.eclipse.ui.window.nextEditor':
HandlerActivation(commandId=org.eclipse.ui.window.nextEditor,
	handler=org.eclipse.ui.internal.CycleEditorHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.110
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.111
!MESSAGE Conflict for 'org.eclipse.ui.window.previousEditor':
HandlerActivation(commandId=org.eclipse.ui.window.previousEditor,
	handler=org.eclipse.ui.internal.CycleEditorHandler:false,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.119
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.120
!MESSAGE Conflict for 'org.eclipse.ui.window.nextView':
HandlerActivation(commandId=org.eclipse.ui.window.nextView,
	handler=org.eclipse.ui.internal.CycleViewHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2014-06-30 15:07:24.128
Re: ECP 1.3.x RAP target does not resolve [message #1391887 is a reply to message #1391123] Tue, 01 July 2014 11:01 Go to previous messageGo to next message
Hi Christian,
The only bundle you are missing is org.eclipse.emf.ecp.view.swt.layout . It is not needed if all controls are directly added to the view. This is also what the error says: Quote:
Found 0 providers.
!STACK 0
When you added Quote:
you probably also added swt bundles and e4 bundles. Those are part of the rap.target but must not be added to the launch configuration.
The second StackTrace is produced because of the wrong dependencies.
I will fix the launch configurations to include the missing bundle so this use case works out of the box in the future.
Eugen
Re: ECP 1.3.x RAP target does not resolve [message #1403244 is a reply to message #1391887] Tue, 22 July 2014 11:20 Go to previous message
Hi Eugen,
Thx for your reply.
I was working on a different project for a while so I tried your solution today and it is working as expected now.
There are still some issues but these do not belong to this topic.
Thx again,
Chris
Previous Topic:[EMFStore] REST feature branch
Next Topic:Guice Injection error
Current Time: Thu Jul 24 23:42:57 EDT 2025
Powered by FUDForum. Page generated in 0.06885 seconds
