Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Buttons in setTabList do no accept focus(Buttons in setTabList do no accept focus)
Buttons in setTabList do no accept focus [message #1297466] Tue, 15 April 2014 13:52 Go to next message
I have a Shell displaying three Buttons. I've created a Control array containing each button and used it to call shell.setTabList. For some reason, none of the buttons will receive focus as I attempt to tab between them. I've tried adding a FocusListener and a KeyListener to each one but that didn't help. The code is below. Thanks in advance for any help.
package com.example.swt.widgets;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
public class TabExample {
  public static void main( String[] args ) {
    Display display = Display.getDefault();
    Shell shell = new Shell( display );
    shell.setLayout( new RowLayout() );
    Button b1 = new Button( shell, SWT.PUSH );
    b1.setText( "Button1" );
    Button b2 = new Button( shell, SWT.PUSH );
    b2.setText( "Button2" );
    Button b3 = new Button( shell, SWT.PUSH );
    b3.setText( "Button3" );
    Control[] controls = new Control[] { b2, b1, b3 };
    shell.setTabList( controls );
    shell.pack();
    shell.open();
    while( !shell.isDisposed() ) {
      if ( !display.readAndDispatch() ) {
        display.sleep();
    display.dispose();
[Updated on: Tue, 15 April 2014 13:52] by Moderator
Re: Buttons in setTabList do no accept focus [message #1300331 is a reply to message #1297466] Thu, 17 April 2014 09:55 Go to previous messageGo to next message
Hi Pete,
Tried your code snippet, tab behavior works fine for me with latest SWT4.4M6 build on Windows7.
Re: Buttons in setTabList do no accept focus [message #1302828 is a reply to message #1300331] Fri, 18 April 2014 20:05 Go to previous messageGo to next message
Hi Niraj -
Thanks for your response. This appears to be an issue in OSX. I was also able to run the snippet on Windows using SWT 4.3. No such luck on the Mac though.
Re: Buttons in setTabList do no accept focus [message #1391674 is a reply to message #1302828] Tue, 01 July 2014 04:32 Go to previous message
On the Mac, default setting is that user can use Tab to move keyboard focus between text boxes and lists only. It is system-wide setting and SWT honors it.
To use Tab to move focus between all controls see System Preferences > Keyboard > Keyboard Shortcuts and for Full Keyboard Access select the 'All controls' option.
Alternatively there is a default key-binding for switching this setting: Control+F7.
Your snippet works Wink
[Updated on: Tue, 01 July 2014 04:35] by Moderator
Previous Topic:Developing 32bit SWT application on 64bit Linux
Next Topic:MouseAdapter behaving differently in Mac OS X
Current Time: Sun Jul 20 20:31:50 EDT 2025
Powered by FUDForum. Page generated in 0.04148 seconds
