Home » Language IDEs » C / C++ IDE (CDT) » Black screen
Black screen [message #139133] Sat, 19 February 2005 17:17 Go to next message
Originally posted by: rob.nw2.info
Just started programming in C using Eclipse
Prog =
#include <stdio.h>
int main(void)
int magic =123 ;
int guess;
printf("Enter your guess: ");
scanf("%d", &guess);
if(guess == magic) printf("** Right **");
return 0;
When I run it - I get a black screen and nothing else;
Press Ctrl+C and get returned to eclipse with
Enter your guess : in the console screen but progeam has terminated.
Anyone have any ideas?
Rob.
Re: Black screen [message #139146 is a reply to message #139133] Sat, 19 February 2005 19:22 Go to previous messageGo to next message
Hi Rob,
> Prog =
> #include <stdio.h>
> int main(void)
> int magic =123 ;
> int guess;
> return 0;
Either add fflush(stdout) after each printf or have them print a
newline. Stdout is usually line buffered; you can also change the
buffering strategy to "unbuffered" but it would nonsensically complicate
your simple application. Anyway, check function setvbuf if you're curious.
Re: Black screen [message #139169 is a reply to message #139146] Sun, 20 February 2005 15:34 Go to previous message
Tried your solution Javier but no luck.
It's to do with the way my machine invokes .exe files.
instead of running them in a window - I'm getting a full screen,
but my system creates a screen to large for my monitor settings.
I navigated to my compiled program, created a shortcut for it and set the
option to run it within a window ... then it runs fine.
This is going to be a bit of a chore though if I have to do this for every
program!
Rob.
Previous Topic:Eclipse remote debugging
Next Topic:why I can not debug helloworld
Current Time: Thu Oct 16 01:04:09 EDT 2025
Powered by FUDForum. Page generated in 0.04585 seconds
