Home » Eclipse Projects » e(fx)clipse » org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error
org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error [message #1391360] Mon, 30 June 2014 16:42 Go to next message
Just followed https://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial4 using the current nightly repo, a Luna RCP IDE, Java 8u5 and selected FX Target / Target Platform Feature unchecking "include required software" but execution in the last step leaves me with
Jun 30, 2014 10:39:49 PM org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error
SCHWERWIEGEND: Initializing from the application definition instance yields no top-level windows! Continuing execution, but the missing windows may cause other initialization failures.
java.lang.Exception
	at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:246)
	at org.eclipse.fx.ui.workbench.base.AbstractE4Application.loadApplicationModel(AbstractE4Application.java:348)
	at org.eclipse.fx.ui.workbench.base.AbstractE4Application.createE4Workbench(AbstractE4Application.java:213)
	at org.eclipse.fx.ui.workbench.fx.E4Application.initE4Workbench(E4Application.java:244)
	at org.eclipse.fx.ui.workbench.fx.E4Application$1.run(E4Application.java:130)
	at org.eclipse.fx.ui.workbench.fx.E4Application.jfxStart(E4Application.java:173)
	at org.eclipse.fx.ui.workbench.fx.DefaultJFXApp.start(DefaultJFXApp.java:57)
	at com.sun.javafx.application.LauncherImpl$8.run(LauncherImpl.java:837)
	at com.sun.javafx.application.PlatformImpl$7.run(PlatformImpl.java:335)
	at com.sun.javafx.application.PlatformImpl$6$1.run(PlatformImpl.java:301)
	at com.sun.javafx.application.PlatformImpl$6$1.run(PlatformImpl.java:298)
	at com.sun.javafx.application.PlatformImpl$6.run(PlatformImpl.java:298)
	at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
Any help on this? THANKS!
Re: org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error [message #1391664 is a reply to message #1391360] Tue, 01 July 2014 04:14 Go to previous messageGo to next message
Hi Marco
I think you need to put at least one window in your application.e4xmi.
Smile
Christoph
Re: org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error [message #1391788 is a reply to message #1391664] Tue, 01 July 2014 08:12 Go to previous messageGo to next message
Right, that did the trick Smile Thanks for the hint!
Re: org.eclipse.fx.ui.workbench.base.internal.LoggerProviderImpl$1 error [message #1573150 is a reply to message #1391788] Mon, 19 January 2015 10:12 Go to previous message
I had the same problem and for me it only helped to update to the newest Egit Team Provider ( I used the standard version 3.4.1 for Luna first)
Previous Topic:Unsatisfied 'org.eclipse.fx.osgi.util' when exporting osgi/javafx app
Next Topic:e(fx)clipse 1.2.0 on January 31th
Current Time: Sun Aug 31 02:28:25 EDT 2025
Powered by FUDForum. Page generated in 0.04309 seconds
