Home » Archived » Visual Editor (VE) » JRE
JRE [message #139031] Mon, 16 July 2007 07:31 Go to next message
Originally posted by: kristine.johansen.bahn.de
When downloading the latest version of the Visual Editor the following is
stated:
"JRE must be version 1.4.2 or greater for BeanInfo of SWT to work
correctly."
I suppose this applies to the design environment, i.e. the user working
with VE to design an SWT GUI needs to have at least JRE 1.4.2 for VE to
work correctly. Does it also apply to the runtime environment of the SWT
GUI created with VE?
Re: JRE [message #139043 is a reply to message #139031] Mon, 16 July 2007 12:41 Go to previous messageGo to next message
It applies to runtime environment too.
> is stated:
> correctly."
Re: JRE [message #139066 is a reply to message #139043] Tue, 17 July 2007 06:59 Go to previous messageGo to next message
Thanks for your reply!
Do you know under which circumstances BeanInfo is used in the generated
SWT code, so that it will not work with a JRE < 1.4.2?
Re: JRE [message #139105 is a reply to message #139066] Tue, 17 July 2007 11:46 Go to previous message
It is not used in the actual generated code. But it is used by the
remote vm that is used to emulate/execute pieces of your code to display
the results in the VE's editor pane.
Re: JRE [message #616275 is a reply to message #139031] Mon, 16 July 2007 12:41 Go to previous message
> is stated:
> correctly."
Re: JRE [message #616277 is a reply to message #139043] Tue, 17 July 2007 06:59 Go to previous message
Re: JRE [message #616282 is a reply to message #139066] Tue, 17 July 2007 11:46 Go to previous message
Previous Topic:Visual design with eclipse 3.3
Next Topic:Custom property editor for colors
Current Time: Wed Nov 05 04:25:52 EST 2025
Powered by FUDForum. Page generated in 0.04094 seconds
