Home » Language IDEs » C / C++ IDE (CDT) » SQLite library for C++(How link sqlite3 in eclipse?)
SQLite library for C++ [message #1390010] Sat, 28 June 2014 15:11 Go to next message
Hi guys,
I am new to c++ and eclipse and I have come to this problem. I dont know how corectly link sqlite3 api to my c++ project in eclipse.
I am trying to compile and execute simple example of connecting to database (from tutorial), but it ends with these errors:
undefined reference to `sqlite3_open'
undefined reference to `sqlite3_errmsg'
undefined reference to `sqlite3_close'
I am using ubuntu and I already installed libsqlite3-dev. I am able to create and manage db in command line, so I know it is working.
I also know that most probably I have to change theese settings:
Properties>>C/C++ Build>>Settings>>GCC C++ Compiler >> Includes
Properties>>C/C++ Build>>Settings>>GCC C++ Linker >> Libraries
but I dont know how exactly. Could anyone help me please?
Re: SQLite library for C++ [message #1390516 is a reply to message #1390010] Sun, 29 June 2014 11:28 Go to previous messageGo to next message
http://wiki.eclipse.org/CDT/User/FAQ#Adding_C.2FC.2B.2B_External_Libraries
Re: SQLite library for C++ [message #1394563 is a reply to message #1390516] Sat, 05 July 2014 10:02 Go to previous messageGo to next message
I have followed instructions for linux and got rid off errors I had, but
now I have this one:
make all
Building target: SQLiteTest
Invoking: GCC C Linker
gcc -L/usr/include/ -o "SQLiteTest"  ./hello.o   -lsqlite3.h
/usr/bin/ld: cannot find -lsqlite3.h
collect2: error: ld returned 1 exit status
make: *** [SQLiteTest] Error 1
I checked /usr/include/ and there really is sqlite3.h file.
Could you help me with that please?
Thank you.
Re: SQLite library for C++ [message #1394691 is a reply to message #1394563] Sat, 05 July 2014 14:56 Go to previous messageGo to next message
> make all Building target: SQLiteTest
> Thank you.
You are confusing a header file with a library. You don't pass header
files to the linker. Go back to the Libraries settings for the linker
and give the library name (most likely sqlite3) instead of the header
file name.
Re: SQLite library for C++ [message #1394942 is a reply to message #1394691] Sun, 06 July 2014 01:00 Go to previous messageGo to next message
Solved, thank You very much.
Re: SQLite library for C++ [message #1394945 is a reply to message #1394691] Sun, 06 July 2014 01:01 Go to previous message
Solved. Thank you very much.
Previous Topic:Cygwin error parser - no mapping for cygdrive
Next Topic:C11 _Static_assert flagged as syntax error in file scope
Current Time: Sun Nov 09 20:09:15 EST 2025
Powered by FUDForum. Page generated in 0.04052 seconds
