Home » Eclipse Projects » Sirius » ecore design(How reuse old ecore file for build a diagram)
ecore design [message #1389054] Fri, 27 June 2014 05:07 Go to next message
I have an ecore model with more than 20 packages. I have install Luna 4.4, Sirius today.
I want create a diagram from this ecore file. How can I do. No way to found in the menus of the .ecore file or in the model directory how to do even with the new menu.
Re: ecore design [message #1389241 is a reply to message #1389054] Fri, 27 June 2014 10:31 Go to previous messageGo to next message
> 4.4, Sirius today.
You have at least two solutions after opening the Modeling perspective:
1. Create a new Modeling Project, then move your ecore in it (if it is a
sample) or reference if from the project dependencies item. Then select
right clic the project and use the Viewpoint selection menu to select
the Design Viewpoint.
2. Right clic on your ecore file and select New > Representation file.
Then right clic the created aird file and use the Viewpoint selection
menu to activate the Design Viewpoint.
Then you should be able to create diagrams on your EPackages. (righ-clic
> New Representation > ..)
Kind regards,
Maxime
Re: ecore design [message #1389242 is a reply to message #1389241] Fri, 27 June 2014 10:33 Go to previous messageGo to next message
One forgotten question: did you install Ecore Tools 2 ? It provides the
Design Viewpoint I referenced in my previous message.
Le 27/06/2014 16:31, Maxime Porhel a écrit :
> Hi
>> 4.4, Sirius today.
> Kind regards,
> Maxime
Re: ecore design [message #1389257 is a reply to message #1389242] Fri, 27 June 2014 10:51 Go to previous messageGo to next message
Please have a look on the documentation of EcoreTools :
https://www.eclipse.org/ecoretools/doc/index.html
Re: ecore design [message #1389259 is a reply to message #1389242] Fri, 27 June 2014 10:54 Go to previous messageGo to next message
I am sorry for the three answers (this following text was supposed to be
in the first answer).
Note that you should just have to convert your Plugin project into a
Modeling project, but as mentionned in by Pierre Charles, in the Sirius
1.0.0 release mail, there is a known issue around the detection of
semantic models:
> * #436375: Semantic models not automatically detected when converting
> into a Modeling Project. A workaround is to add them manually to the
> session using the Project Dependencies of the modeling project (see
> [2]).
> [2]
https://www.eclipse.org/sirius/doc/user/general/Modeling%20Project.html#ProjectDependencies
Maxime
>> Hi
>>> 4.4, Sirius today.
>> Kind regards,
>> Maxime
Re: ecore design [message #1389268 is a reply to message #1389259] Fri, 27 June 2014 11:07 Go to previous message
Thanks a lot, it works Razz . But now I have another problem. I have one diagram per package (fine). I want a diagram with all the packages with the links (association, ...) from one class of one package to another class from another package, and I can't build it from my ecore file. It's normal?
Previous Topic:Sirius in Eclipse 4 application
Next Topic:Dynamic creation of layers
Current Time: Sat Jul 26 20:43:44 EDT 2025
Powered by FUDForum. Page generated in 0.07163 seconds
