Home » Modeling » TMF (Xtext) » Best way of traversing a model: bottom up
Best way of traversing a model: bottom up [message #1389132] Fri, 27 June 2014 07:37 Go to next message
Hello everyone,
I've implemented a search algorithm, that finds a specific root-element from a start-element in my model. But I'm not really sure if this function is safe enough or not.
Is there maybe a better algorithms in the API who manages the same job?
Here my algorithme:
	 * Finds the specific root element or a superClass of the specific root
	 * element. The startingpoint is the startElement.
	 * @param startElement
	 *            : an EObject as a startElement
	 * @param specificRootElement
	 *            : The root element you are searching or one of its
	 *            superclasses.
	 * @return EObject: A specific root element
	 * @throws ClassNotFoundException
	public static <T> EObject findSpecificParentElement(EObject startElement, EClass specificRootElement)
			throws ClassNotFoundException {
		EObject parent = startElement.eContainer();
		EClass parentClass = parent.eClass();
		// if the searched class is the parentclass or if the searched class is
		// one of the superClasses
		if ((parent != null && !(parentClass == specificRootElement || EcoreUtil2.getAllSuperTypes(parentClass).contains(
				specificRootElement)))) {
			return findSpecificParentElement(parent, specificRootElement);
		} else {
			return parent;
regards,
Alex
[Updated on: Fri, 27 June 2014 07:43] by Moderator
Re: Best way of traversing a model [message #1389164 is a reply to message #1389132] Fri, 27 June 2014 08:22 Go to previous messageGo to next message
On 27/06/2014 13:37, Alexander R wrote:
> Hello everyone,
- Be careful whether you want to test the start element itself too.
- Don't throw a ClassNotFoundException there. Not unless you want to
torture callers.
- EcoreUtil2 is provided by?
Maybe you could use EClassifier.isInstance() to save a penny.
Btw, ask such general EMF questions better on the EMF forum.
Felix
Re: Best way of traversing a model: bottom up [message #1389169 is a reply to message #1389132] Fri, 27 June 2014 08:30 Go to previous messageGo to next message
Hi Alexander,
I had a similar question on:
https://www.eclipse.org/forums/index.php/t/781743/
Looks like the answer from Christian Dietrich is the best for your scenario:
EcoreUtil2.getContainerOfType(ctx, Model.class)
to access the root type (i asume it is Model) from any eObject ctx
Greetings from Frankfurt/Germany, Uli
P.S. Just saw that Christian has replied as well
[Updated on: Fri, 27 June 2014 08:32] by Moderator
Re: Best way of traversing a model [message #1389170 is a reply to message #1389164] Fri, 27 June 2014 08:30 Go to previous messageGo to next message
Hmmm,
why not using EcoreUtil2.getContainerOfType?
Re: Best way of traversing a model [message #1389177 is a reply to message #1389170] Fri, 27 June 2014 08:45 Go to previous messageGo to next message
On 27/06/2014 14:30, Christian Dietrich wrote:
> Hmmm,
Don't know which EcoreUtil2 you're all talking about :)
Felix
Re: Best way of traversing a model [message #1389186 is a reply to message #1389177] Fri, 27 June 2014 09:04 Go to previous messageGo to next message
>> Hmmm,
Ok, now I'm propertly informed. I didn't know TMF is a synonym for
Xtext. I thought there was more...
Felix
Re: Best way of traversing a model [message #1389193 is a reply to message #1389170] Fri, 27 June 2014 09:10 Go to previous message
Thanks alot for the hints!
I will try out EcoreUtil2.getContainerOfType().
Previous Topic:Could not serialize EObject via backtracking
Next Topic:Using ANTLR or Xtext for YAML editor
Current Time: Sun Jul 27 16:21:46 EDT 2025
Powered by FUDForum. Page generated in 0.05187 seconds
