Home » Eclipse Projects » Remote Application Platform (RAP) » Password text field without synchronization with Java client
Password text field without synchronization with Java client [message #1386795] Fri, 20 June 2014 09:53 Go to next message
Hello!
We would like to have some password fields in our RAP application. We used SWT.PASSWORD and created the text fields just as usual, but we are a little bit concerned about the transfer of the clear text password from the JS to the Java client via JSON. We know TLS would fix this, but anyway:
We would feel better, if it was possible to hash the password, before it leaves the browser of the user. This seemed straight forward with ClientScripting:
- create a ClientListener with JS to hash password
- write password hash into hidden field in the respective dialog
- set text of original password text field to empty string (setText(""))
- make sure no listeners trigger a transfer of the password (i.e. SWT.Modify on the text field)
- read password hash from hidden field in Java
I implemented this and it seems to work - the only problem is, that the value of the text field still shows up in the JSON. Does the json always incorporate a complete history of the value changes of a control? Is it possible to do what I described?
I hope I did not miss something trivial here.
Greetings,
Tibu
Edit: We use latest RAP 2.3 (I think RC3)
[Updated on: Fri, 20 June 2014 10:04] by Moderator
Re: Password text field without synchronization with Java client [message #1387007 is a reply to message #1386795] Mon, 23 June 2014 09:16 Go to previous messageGo to next message
I would recommend using an HTTPS connection or some other security technology (perhaps TLS as you mentioned) to secure the password (credentials, challenge response, etc.) from the client to the server.
If you hash the password on the client and send the hashed version, now an attacker just needs the hashed password instead of the clear text password to compromise security with the slight added bonus they may be able to reverse engineer your hashing algorithm parameters.
Another option could be to perform the authentication on the client itself using JS client-side cryptography, but that would likely be difficult to implement and slow in computation compared to server-side crypto.
--Paul Bilnoski
Re: Password text field without synchronization with Java client [message #1387165 is a reply to message #1387007] Tue, 24 June 2014 10:34 Go to previous messageGo to next message
Thanks for your suggestion and explanation Mr.Bilnoski. The considerations you mention are valid and I agree with you completely.
It would still be nice to know though, if it is possible, to keep the value of a text field from being send in the JSON traffic somehow. I guess one workaround would be to use a custom HTML Form and embedding it using the Browser widget, but I was hoping for an easier way using only RWT Text.
Greetings
Tibu
Re: Text field without synchronization with Java client [message #1389026 is a reply to message #1386795] Fri, 27 June 2014 04:19 Go to previous messageGo to next message
Hi.
It's a question of what happens in what order. The text is written into
the message as soon as there is any event that is added to the message.
So if you have a Modify, Verify or Selection listener, just typing might
do that. Any other widget triggering an event might also do that.
Looking into the message might tell you what event that is.
But I have to agree with the other post, this is not a good idea. And
even if you want stick to the general approach (not sending the plain
password to the server), do NOT rely on how RAP internals synchronize
properties, create your own custom widget to do this.
Greetings,
Tim
Am 20.06.2014 15:53, schrieb Tiburon T:
> Hello!
> anyway: We would feel better, if it was possible to hash the password,
> Greetings,
> Tibu
Tim Buschtöns
Twitter: @EclipseRAP
Re: Password text field without synchronization with Java client [message #1389180 is a reply to message #1386795] Fri, 27 June 2014 08:51 Go to previous message
Thanks for your answer, Mr. Buschtöns. I see how relying on the internals would be very bad indeed. I will look into realizing this with a custom widget, that is the cleanest way to do it.
Greetings,
Tibu
Previous Topic:Using Google Visualization on RAP 2.2
Next Topic:[ANN] RAP 2.3 released
Current Time: Mon Jul 21 06:05:39 EDT 2025
Powered by FUDForum. Page generated in 0.07085 seconds
