Home » Language IDEs » C / C++ IDE (CDT) » Problem with "Automatically refresh registers" option
Problem with "Automatically refresh registers" option [message #138426] Fri, 11 February 2005 07:20 Go to next message
The default settings in "Windows>preferences>C/C++>GDB MI", are:
debugger timeout=10000
launch timeout = 30000
Automatically refresh register=true
Automatically refresh shared libraries=true.
My problem is the following:
When I create a new Managed C Project, then add source files then Build my
project, in "Windows>preferences>C/C++>GDB MI", the General settings for
GDB MI are not consistent:
debugger timeout=0
launch timeout = 0
Automatically refresh register=false
Automatically refresh shared libraries=false
Does someone have any idea of this problem ? Is it a known bug ?
After exiting Eclipse then launch Eclipse again, the GDB MI settings are
OK:
Thanks for advance
Jerome
Re: Problem with "Automatically refresh registers" option [message #138550 is a reply to message #138426] Fri, 11 February 2005 14:35 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
I followed the steps you mentioned but I couldn't reproduce the problem.
Does it happen everytime when you create a new managed project?
"jerome correnoz" <jerome.correnoz@st.com> wrote in message
news:cui7vb$uu2$1@www.eclipse.org...
> Hello,
> The default settings in "Windows>preferences>C/C++>GDB MI", are: debugger
> timeout=10000
> GDB MI are not consistent: debugger timeout=0
> launch timeout = 0
> OK:
> Thanks for advance
> Jerome
Re: Problem with "Automatically refresh registers" option [message #138753 is a reply to message #138550] Mon, 14 February 2005 07:46 Go to previous messageGo to next message
My problem was solved by adding the following lines in my plugin.xml
<extension
point="org.eclipse.core.runtime.preferences">
<initializer
class="org.eclipse.cdt.debug.mi.core.MIPreferenceInitializer "/>
</extension>
Otherwise, it happen everytime I create a new Managed Project from ST type.
>> Hello,
>> timeout=10000
>> launch timeout = 0
>> OK:
>> Thanks for advance
>> Jerome
Re: Problem with "Automatically refresh registers" option [message #138804 is a reply to message #138753] Mon, 14 February 2005 11:37 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
What do you mean by "my plugin.xml"? These lines are in the plugin.xml file
of the "org.eclipse.cdt.debug.mi.core" plugin.
news:cuq6k0$nkj$1@www.eclipse.org...
> <extension
> <initializer
> </extension>
type.
> >> Hello,
debugger
> >> timeout=10000
my
for
> >> launch timeout = 0
are
> >> OK:
> >> Thanks for advance
> >> Jerome
Re: Problem with "Automatically refresh registers" option [message #138876 is a reply to message #138804] Tue, 15 February 2005 04:12 Go to previous message
I've copied these lines in the plugin.xml of my toolchain plugin (ST100
core).
>> <extension
>> <initializer
>> </extension>
> type.
>> >> Hello,
> debugger
>> >> timeout=10000
> my
> for
>> >> launch timeout = 0
> are
>> >> OK:
>> >> Thanks for advance
>> >> Jerome
Previous Topic:C/C++ Indexer Problem: Include path not found (\usr\include) on windows XP with Cygwin
Next Topic:C/C++ Indexer Problem: Invalid arithmetic conversion in file.
Current Time: Fri Nov 07 01:24:30 EST 2025
Powered by FUDForum. Page generated in 0.04516 seconds
