Home » Modeling » EMF » [XCore] org.eclipse.emf.ecore.xcore.lib cannot be resolved(Problem with tutorial https://wiki.eclipse.org/Xcore#Modeling_for_Programmers_and_Programming_for_Modelers)
[XCore] org.eclipse.emf.ecore.xcore.lib cannot be resolved [message #1388210] |
Thu, 26 June 2014 02:03  |
Hy there,
I tried your tutorial both with Kepler and now with Luna. I installed the EMF - Eclipse Modeling Framework Xcore SDK, created an XCore Project and it works fine.
However, on every Project/clean or rebuild in Kepler the following bundles get added to the Manifest, which I can not resolve:
org.eclipse.xtext.xbase.lib;visibility:=reexport,
org.eclipse.emf.ecore.xcore.lib;visibility:=reexport,
on Luna, the same as befor, but just the following
Funny thing is, I don't seem to need them, as just removing the requirement removes all build problems. I also tried to find the required libraries. I do not seem to find an update site to install this feature, however.
Whats the matter with this? Thanks for your help, as it is really annoying to have to manually remove the dependency after each compile run.
Re: [XCore] org.eclipse.emf.ecore.xcore.lib cannot be resolved [message #1388264 is a reply to message #1388210] |
Thu, 26 June 2014 03:31   |
Marco,
Comments below.
On 26/06/2014 8:03 AM, Marco Descher wrote:
> Hy there,
Are these bundles not in your target platform?
They generally are only needed if you have block expressions in your model?
> I also tried to
> https://github.com/eclipse/emf/blob/master/features/org.eclipse.emf.ecore.xcore.lib-feature/feature.properties
It sounds like you don't really have a target platform but rather are
using the installed IDE as the target platform. Is that right? Do you
have the Xcore SDK and Xtext SDK installed?
> run.
Note that you can set the GenModel property "Update Classpath" to false
to turn this merging behavior off as a workaround, but I suspect the
problem is more a deficiency in your target platform. You really should
have one and it should have the SDKs in it...
Re: [XCore] org.eclipse.emf.ecore.xcore.lib cannot be resolved [message #1388295 is a reply to message #1388264] |
Thu, 26 June 2014 04:24   |
On 26.06.14 09:31, Ed Merks wrote:
> Marco,
> Comments below.
>> Hy there,
I've updated https://bugs.eclipse.org/bugs/show_bug.cgi?id=437093 maybe
you should mark them optional?
>> I also tried to
>> run.
That's a nice trick - didn't know about that.
Tom
Re: [XCore] org.eclipse.emf.ecore.xcore.lib cannot be resolved [message #1388300 is a reply to message #1388264] |
Thu, 26 June 2014 04:30   |
I currently simply installed the required SDK. I am working with a target platform in another workspace, can't however figure out which feature to select, to satisfy these dependencies!
Thats when I came to the link, but the feature (EMF - Eclipse Modeling Framework Xcore Library Runtime Library) mentioned there seems not to be part of the EMF Update site http://download.eclipse.org/modeling/emf/emf/updates/releases/.
Uhm, sorry, don't know 'bout block expressions! Eclipse is forcing the requirement each compile, and as mentioned, I don't really need it - removal works good!
> I also tried to
I have no problem using a target platform, but what feature to install there?? The only thing is the XCore SDK, is there a XCore runtime or something?
> run.
have one and it should have the SDKs in it...[/quote]
Thanks for the info, will try!
Current Time: Fri Jul 18 00:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.13424 seconds
