Import projects from Git repository into the workspace [message #1387026] |
Mon, 23 June 2014 10:40  |
Today I wanted to upgrade my Oomph installer and when I try to use my
setup file my projects do not appear in my workspace.
After some checks, the reason is that the item "import into workspace"
(or something like that) is not supported anymore.
I have looked into the Oomph setup file to find an other way to import
my projects into the workspace, but I did not find anything convincing.
So, how can I import my projects into the workspace with Oomhp?
Guillaume Coutable, Obeo
Re: Import projects from Git repository into the workspace [message #1389059 is a reply to message #1388623] |
Fri, 27 June 2014 05:14  |
Le 26/06/2014 20:26, Julian Enoch a écrit :
> This is may be the simplest way, but you could also add a p2 task to
> your user.setup for o.e.oomph.setup.projects and run Perform setup
> tasks. Just a more "Oomph" way of doing the same thing ;)
> It has also the advantage of you not having to do it manually for
> another installation.
My problem is now solved.
I don't know how, but when I launched the Oomph installer with my setup
file again, Oomph has downloaded the missing oomph.setup.projects. And
now the setup work well.
I will follow your advice to add a p2 task for oomph.setup.project, to
be sure that work every time.
Thanks for helping,
FUDForum. Page generated in 0.04126 seconds
