Home » Eclipse Projects » Oomph » Import projects from Git repository into the workspace
Import projects from Git repository into the workspace [message #1387026] Mon, 23 June 2014 10:40 Go to next message
Today I wanted to upgrade my Oomph installer and when I try to use my
setup file my projects do not appear in my workspace.
After some checks, the reason is that the item "import into workspace"
(or something like that) is not supported anymore.
I have looked into the Oomph setup file to find an other way to import
my projects into the workspace, but I did not find anything convincing.
So, how can I import my projects into the workspace with Oomhp?
Guillaume Coutable, Obeo
Re: Import projects from Git repository into the workspace [message #1387028 is a reply to message #1387026] Mon, 23 June 2014 10:51 Go to previous messageGo to next message
As far as I know, you should use Targlets and add Source locators inside.
You can check the prvided setup models in the setups project under the Setup working set (if you have a Oomph product deployed).
Re: Import projects from Git repository into the workspace [message #1387038 is a reply to message #1387028] Mon, 23 June 2014 12:17 Go to previous messageGo to next message
Abel,
Yes, generally the targlets task is used to import projects as well as
to populate the target platform with the projects' dependencies. There
is also the Projects Import task. I use this in EMF.setup to import a
feature whose dependencies I don't want to have fully resolved as part
of the target platform. (I.e., there is an emf.all feature that
includes the emf.sdk, oda.sdk, and rap.sdk, but I want each of those to
be handled as a separate subproject.)
Re: Import projects from Git repository into the workspace [message #1387110 is a reply to message #1387038] Tue, 24 June 2014 04:31 Go to previous messageGo to next message
Yes, I can see that there is a Project Imports in the EMF.setup, but it is not in the Create Child menu, so the editor cannot be used to create such an item in a user model. At least, I could not find it and I imagine that Guillaume found the same issue.
[Updated on: Tue, 24 June 2014 04:33] by Moderator
Re: Import projects from Git repository into the workspace [message #1387116 is a reply to message #1387038] Tue, 24 June 2014 05:07 Go to previous messageGo to next message
my problem is solved.
I have looked to EMF setup file and added the item "Import project".
When I added it, this item was not supported, but during the
installation, Oomph installer asked me to restart eclipse and installed
some plugins related to Oomph and then the item is supported now.
Re: Import projects from Git repository into the workspace [message #1387125 is a reply to message #1387116] Tue, 24 June 2014 06:05 Go to previous messageGo to next message
I can see that for example the Oomph Setup Projects feature is not installed in my Oomph development Eclipse.
Can someone explain exactly how to get Oomph to install it?
Re: Import projects from Git repository into the workspace [message #1387130 is a reply to message #1387125] Tue, 24 June 2014 06:15 Go to previous messageGo to next message
Guys,
Please have a look at the following feature request:
437983: Provide discovery of task packages for model authors
https://bugs.eclipse.org/bugs/show_bug.cgi?id=437983
Cheers
/Eike
http://www.esc-net.de
Am 24.06.2014 12:05, schrieb Abel Hegedus:
Re: Import projects from Git repository into the workspace [message #1387141 is a reply to message #1387130] Tue, 24 June 2014 07:45 Go to previous messageGo to next message
Thanks, I installed the additional features from the update site listed on https://wiki.eclipse.org/Eclipse_Oomph_Installer (was http://download.eclipse.org/oomph/updates at the time of this post) and now I can use the additional tasks.
Re: Import projects from Git repository into the workspace [message #1388623 is a reply to message #1387141] Thu, 26 June 2014 14:26 Go to previous messageGo to next message
This is may be the simplest way, but you could also add a p2 task to your user.setup for o.e.oomph.setup.projects and run Perform setup tasks. Just a more "Oomph" way of doing the same thing ;)
It has also the advantage of you not having to do it manually for another installation.
Re: Import projects from Git repository into the workspace [message #1389059 is a reply to message #1388623] Fri, 27 June 2014 05:14 Go to previous message
My problem is now solved.
I don't know how, but when I launched the Oomph installer with my setup
file again, Oomph has downloaded the missing oomph.setup.projects. And
now the setup work well.
I will follow your advice to add a p2 task for oomph.setup.project, to
be sure that work every time.
Thanks for helping,
Previous Topic:"File name too long" in oomph.p2/cache
Next Topic:Could not figure out how to create a mylyn query task
Current Time: Sat Jul 26 00:38:02 EDT 2025
Powered by FUDForum. Page generated in 0.29575 seconds
