Home » Eclipse Projects » Oomph » Oomph headless
Oomph headless [message #1387033] |
Mon, 23 June 2014 11:23  |
Is it possible to launch Oomph as a headless application ? If it is, which APIs allow to do that ?
Axel
Re: Oomph headless [message #1387109 is a reply to message #1387105] |
Tue, 24 June 2014 04:22   |
Axel,
I see, so it would be a headless application that includes
org.eclipse.core.resources, i.e., that includes workspace support. I see
no reason, in principle, why this wouldn't work well. Do you want to
help design such an application? Without your help, it will likely be a
few weeks before we'd have time to look at it...
On 24/06/2014 9:25 AM, Axel RICHARD wrote:
> Ed,
> As part of EMF Compare, we want to provide a headless application in
> order to do merge opertions on models with (j)git. For that reason, we
> need a mechanism to provision a worksapce and an eclipse environment,
> and Oomph seems to fit this need.
> Axel
Re: Oomph headless [message #1392463 is a reply to message #1392344] |
Wed, 02 July 2014 07:25   |
Hi Axel,
Comments below...
Cheers
/Eike
http://www.esc-net.de
Am 02.07.2014 09:30, schrieb Axel RICHARD:
> With Oomph, there is bootstrap tasks and startup tasks.
Knitpicking a bit, the list of tasks that you see for the bootstrap trigger and the list of tasks you see for the
startup trigger is not necessarily disjunct; or in other words, a task can be both a bootstrap and a startup task.
> Once bootstrap tasks have been executed, you can launch the provisionned environment. When this environment is
> launched, Oomph is automatically launched to execute startup tasks (e.g. clone a repo, imports projects...).
> I succeed in programmatically provision an eclipse environment with oomph. But I don't find the code that allows to
> execute the startup tasks in this provisionned environment.
That code is in org.eclipse.oomph.setup.ui.SetupUIPlugin.performStartup().
This method should be automatically called when the org.eclipse.oomph.setup.ui plugin is started, which happens early.
So I wonder why that doesn't happen in your case.
Re: Oomph headless [message #1392567 is a reply to message #1392463] |
Wed, 02 July 2014 10:19   |
Guys,
It's important to set properties in the eclipse.ini, in particular
-Doomph.setup=true
On 02/07/2014 1:25 PM, Eike Stepper wrote:
> Hi Axel,
> Comments below...
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi,
> trigger and the list of tasks you see for the startup trigger is not
>> provisionned environment. When this environment is launched, Oomph is
>> oomph. But I don't find the code that allows to execute the startup
> That code is in
> org.eclipse.oomph.setup.ui plugin is started, which happens early. So
Re: Oomph headless [message #1393897 is a reply to message #1392567] |
Fri, 04 July 2014 08:46   |
Hi guys,
Thanks for your prompt answers, still progress on executing oomph headless.
I succeed in execute my startup tasks in this provisionned environment.
Now, I don't understand why the plugin org.eclipse.oomph.setup.ui is included in the feature org.eclipse.oomph.setup-feature ?
In the perform(SetupTaskContext) method of GitCloneTaskImpl, I found this:
// Force start egit to make the clone appears in the repositories view and so projects are connected by the egit team provider.
CommonPlugin.loadClass("org.eclipse.egit.ui", "org.eclipse.egit.ui.Activator");
But, in my case, that is to say a headless context, I don't want org.eclipse.egit.ui.
Do you plan to remove org.eclipse.oomph.setup.ui from the org.eclipse.oomph.setup-feature ? Or do you know a workaround ?
[Updated on: Fri, 04 July 2014 08:47] by Moderator
Re: Oomph headless [message #1394375 is a reply to message #1393897] |
Sat, 05 July 2014 02:51   |
Axel,
Comments below.
On 04/07/2014 2:46 PM, Axel RICHARD wrote:
> Hi guys,
> headless.
> oomph. I succeed in execute my startup tasks in this provisionned
> environment.
That's maybe bogus. Please open a bugzilla and we'll review.
> this:
> org.eclipse.oomph-feature ?
I'm not sure the two things are related. Certainly we should change the
GitCloneTaskImpl so it guards the loadClass call. We only call that
because the EGit UI plugin needs to be enabled for projects to actually
be imported into the workspace and for clones to be added to the clones
view. That plugins where the auto import support comes from. Perhaps
that is a bogus aspect of EGit because, i.e., why shouldn't you be able
to auto import projects headlessly?
Or maybe we shouldn't be relying on auto import in the targlet task...
Will you rely on projects actually ending up in the workspace?
> Best regards,
Re: Oomph headless [message #1413835 is a reply to message #1395664] |
Fri, 29 August 2014 10:44   |
Ed, Eike,
Some news of our need with EMF Compare. We succeed in using Oomph as a headless application, and I would thank you for this great tool you've made.
As a reminder we want to provide a headless application in order to do specific git operations (diff, merge) on models with (j)git. For that reason, we use Oomph to provision an eclipse environment.
When a user wants to compare or merge EMF models from a command line, he needs to do that in an Eclipse environment similar to the one he used to create these models. As such, the environment requires some plugins to be installed but it may also requires some preferences to be set, some perspective to be activated etc... Among these plugins, there are the mandatory ones that will be use to do the git operation.
First, Oomph provision an Eclipse with all appropriate plugins to launch the git operation. These plugins are EGit, EMF Compare and their dependencies. If the user setup model provided as parameter of the git command contains other plugins, they will be provisioned too.
For a given Oomph setup model file, the provisioning operation is executed only once. Indeed, if you launch again a git logical operation with the same Oomph setup model file, then the already provisioned Eclipse IDE corresponding to the setup model will be reused. It avoids to execute this potentially costly task each time.
Then, in this provisioned Eclipse, the list of tasks contained in the user setup model are executed.
Once all Oomph tasks executed, EMF Compare calls the logical git operation with the others parameters provided in the command line interface. Once the git logical operation has been executed, the user can see the results in his command line tool.
Here is a review of our code that use Oomph as a headless application: https://git.eclipse.org/r/#/c/30733/
If you're interested, feel free to give us your opinion about the use of Oomph in this review.
Re: Oomph headless [message #1417424 is a reply to message #1413835] |
Fri, 05 September 2014 07:53   |
Hi Axel,
I've looked at that review briefly and noticed that it includes many many files. I'm sorry but it seems beyond what I
can achieve in a short time frame. If you have specific questions please don't hesitate to ask ;-)
Cheers
/Eike
Am 29.08.2014 um 16:44 schrieb Axel RICHARD:
> Ed, Eike,
> line tool.
> Best regards,
Re: Oomph headless [message #1508207 is a reply to message #1508177] |
Fri, 12 December 2014 02:47   |
Markus,
Comments below.
On 12/12/2014 8:13 AM, Markus Oley wrote:
> Hi Ed,
> thank you for you answer, I had a look at the contribution and as I
> can see from my point of view the emf compare folk have implemented a
> headless application which has some git actions and needs oomph to
> setup the workspace properly. This is not exactly the thing I need,
> but it's a very good example, where I can see how I can implement a
> real headless application. Thank you.
> So I want to try to implement an headless application where I can
> parameterize a folder where to setup the configurations and
> parameterize a bunch of files to get the info what I want to setup. I
> think this is a very general way and you do not have to add additional
> functionality to parameter handling if oomph actions are extended
> theirselfes.
I think I see what you mean. Sort of a
descriptor/template/configuration-file for what needs to be done, rather
than 50 different command line parameters.
> I could imagine to contribute this, so can you give me a hint, if I
> should implement in oomph git and contribute it as pull request?
If you provision an IDE with the Oomph.setup itself, and you choose
Gerrit for the repository URI, you will be able to commit to Gerrit
where we can do an interactive reviews; of course you'll need a Gerrit
account, but that's trivial.
> Or should I go another way? I'm new in the whole process of contributing.
That's one of the goals of Oomph: to make it easy to contribute to
projects. I.e., instead of forcing contributors to spend hours or a
full day setting up an environment, this aspect is automated so
contributors can focus on contribution, not administration.
> Thanks in advance
> Cheers
> Markus
Re: Oomph headless [message #1508543 is a reply to message #1508207] |
Fri, 12 December 2014 08:58  |
-> Yes, that's the point.
-> OK, thank you, I will give it a try and 'll be back if I have something to see.
Have a nice weekend,
Cheers
Markus
Current Time: Fri Jul 25 16:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.07513 seconds
