EMF Forms Rules NullpointerException [message #1386966] |
Mon, 23 June 2014 06:09  |
I want to create a view model with EMF Forms as described in the EMF Forms tutorial (http://eclipsesource.com/blogs/tutorials/getting-started-with-emf-forms-1-2-x/).
I am trying to define a simple rule which hides a control based on the setting of another (boolean) control.
I first add a "Show Rule" element to the control to be hidden, than I add a "Leaf Condition" element to the "Show Rule" element.
When I press the button "Select Object" of the "leaf Condition" element I get the following error log:
!ENTRY org.eclipse.ui 4 0 2014-06-23 11:57:54.982
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.emf.ecp.view.editor.controls.ExpectedValueControl$1.widgetSelected(ExpectedValueControl.java:92)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.emf.ecp.application3x.Application.start(Application.java:30)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
I checked out and debugged the sources. The problem is that the field "domainModelReference" of the class "LeafCondition" is never set.
However the button listener directly accesses it without checking for null.
I did set the domain model reference for all controls in the view model so the field should have been set!
I am using eclipse kepler and ECP 1.2.1.
Any help is highly appreciated.
Thx,
chris
[Updated on: Mon, 23 June 2014 06:19] by Moderator
Re: EMF Forms Rules NullpointerException [message #1387015 is a reply to message #1386966] |
Mon, 23 June 2014 09:48   |
Hi Chris,
thank you for reporting this, it is a bug, could you please open a
bugzilla, thanks!
Maximilian
Am 23.06.2014 12:09, schrieb Christian Reuter:
> Forms tutorial
> I first add a "Show Rule" to the control to be hidden, than I add a
> "Leaf Condition" to the "Show Rule" element.
> When I press the button "Select Object" I get the following error log:
> !STACK 0
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> Thx,
> chris
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
FUDForum. Page generated in 0.04207 seconds
