Home » Eclipse Projects » Eclipse 4 » LinkageError?(org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities)
LinkageError? [message #1259376] Fri, 28 February 2014 05:08 Go to next message
i launch my Application as a Plug-In based Product. (launching works without any problems)
as i want to use the self update feature i need to turn it into a feature based product.
i added all features and plugins which i need to get it started.
but while launching i get the exception listed below
any ideas where this is coming from?
Thanks in advance
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2014-03-04 13:46:19.252
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/ui/internal/registry/ViewDescriptor, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/workbench/swt/util/ISWTResourceUtilities, have different Class objects for the type org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object; used in the signature
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:84)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
	at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1396)
	at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1369)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1056)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1081)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1066)
	at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1667)
	at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2151)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4608)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2075)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4977)
	at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
	at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
	at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:767)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:649)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1038)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at my.app.application.Application.start(Application.java:47)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.LinkageError: loader constraint violation: when resolving interface method "org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object;" the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current class, org/eclipse/ui/internal/registry/ViewDescriptor, and the class loader (instance of org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) for resolved class, org/eclipse/e4/ui/workbench/swt/util/ISWTResourceUtilities, have different Class objects for the type org.eclipse.e4.ui.workbench.swt.util.ISWTResourceUtilities.imageDescriptorFromURI(Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object; used in the signature
	at org.eclipse.ui.internal.registry.ViewDescriptor.getImageDescriptor(ViewDescriptor.java:109)
	at org.eclipse.ui.internal.ViewReference.<init>(ViewReference.java:46)
	at org.eclipse.ui.internal.WorkbenchPage.createViewReferenceForPart(WorkbenchPage.java:1912)
	at org.eclipse.ui.internal.e4.compatibility.ModeledPageLayout.createViewModel(ModeledPageLayout.java:376)
	at org.eclipse.ui.internal.e4.compatibility.ModeledPageLayout.insertView(ModeledPageLayout.java:398)
	at org.eclipse.ui.internal.e4.compatibility.ModeledPageLayout.addView(ModeledPageLayout.java:236)
	at my.app.application.Perspective.createInitialLayout(Perspective.java:14)
	at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3914)
	at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:675)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 53 more
[Updated on: Tue, 04 March 2014 08:42] by Moderator
Re: LinkageError? [message #1263401 is a reply to message #1259376] Tue, 04 March 2014 07:53 Go to previous messageGo to next message
sounds to me as eclipse is trying to load two different versions of a class from swt...
[Updated on: Tue, 04 March 2014 07:53] by Moderator
Re: LinkageError? [message #1264583 is a reply to message #1263401] Wed, 05 March 2014 05:37 Go to previous messageGo to next message
Are there two plugins with the same class (different version) in your run config?
Re: LinkageError? [message #1264591 is a reply to message #1264583] Wed, 05 March 2014 05:43 Go to previous messageGo to next message
thats what i thought too.
was not able to find one yet.
i'll remove ALL required plugins from all of my bundles and start all over including them. this will take some hours!
[Updated on: Wed, 05 March 2014 05:44] by Moderator
Re: LinkageError? [message #1265462 is a reply to message #1264591] Thu, 06 March 2014 00:59 Go to previous messageGo to next message
so finally after removing everything, and adding the required stuff again.
same problem!
i noticed its not an old libaray (what i expected, as my plugins are build on e3x basis and now moved to e4.
so i removed all required bundles which refer to an e4 gui element.
then added the e4 platform feature and voilà the linkage error is gone!
seems there were two conflicting e4 ui classes/bundles/features
thanks!
Re: LinkageError? [message #1386915 is a reply to message #1265462] Mon, 23 June 2014 01:53 Go to previous message
in the meantime this error is coming back from time to time and i found an easy fix (though i do not know what causes this error to come up)
i simply need to clean the run configuration, and create a new one with the .product
everything works fine then! hope this helps some other folks too
Previous Topic:MinMaxAddon and Buttons
Next Topic:Perspective Editors only!
Current Time: Wed Jul 23 19:58:54 EDT 2025
Powered by FUDForum. Page generated in 0.04944 seconds
