Home » Modeling » TMF (Xtext) » Import and use Ecore model using importURI
Import and use Ecore model using importURI [message #1386881] Sun, 22 June 2014 06:01 Go to next message
some things changed since my last topic and now I need a little help again.
I want to be able to import some Ecore files in my DSL and use classes of these specified files.
Example DSL:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "ht tp://www.xtext.org/example/mydsl/MyDsl"
import "ht tp://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
	imports+=Import*
	selection=Selection;
Import: 'import' importURI=STRING;
Selection:
	'selection' name=ID '{'
		selected+=Select*
Select:
	'select' classref=[ecore::EClass] name=ID;
It should look like this:
import "org/test/MyEcoreModel.ecore"
selection test {
	select MyClass mc // MyClass is an EClass in MyEcoreModel.ecore
But this does not seem to work. The classref=[ecore::EClass] part does not find the classes in the ecore model file. I guess this is a problem of the ScopeProvider, but how do I get into the importURI in the ScopeProvider? Or is there another problem?
Thanks for any suggestions,
Florian
Re: Import and use Ecore model using importURI [message #1386884 is a reply to message #1386881] Sun, 22 June 2014 07:43 Go to previous messageGo to next message
aaa=[BBB] is short for aaa=[BBB|ID] => an ID Will be parsed. the eclass name is packagename.classname.
a . is not allowed in ID
Select:
	'select' classref=[ecore::EClass|FQN] name=ID;
FQN: ID ("." ID)*;
Re: Import and use Ecore model using importURI [message #1386886 is a reply to message #1386884] Sun, 22 June 2014 09:25 Go to previous messageGo to next message
Oh I am so dumb.. you already told me this in that other topic..
Ok but this does only half the trick, as I can select all models in my project now. But I only want to select those from my import section. How can I apply a filter like this?
Re: Import and use Ecore model using importURI [message #1386890 is a reply to message #1386886] Sun, 22 June 2014 11:25 Go to previous messageGo to next message
Sure you did the workflow config right?
Re: Import and use Ecore model using importURI [message #1386910 is a reply to message #1386890] Mon, 23 June 2014 00:56 Go to previous messageGo to next message
Here is an example how to restrict the scope, perhaps it works for your situation as well.
reducing cross reference to current DSL file [message #1229358] at
https://www.eclipse.org/forums/index.php/t/635607/
Re: Import and use Ecore model using importURI [message #1389056 is a reply to message #1386910] Fri, 27 June 2014 05:10 Go to previous messageGo to next message
I checked the workflow over and over again, but I can not find anything that causes this.. What am I looking for?
@Uli: Yes I was trying to restrict the scope, but I can not find a way to refer and read the imported files. I want only the EClasses in the files listed in the import section to show up.
My Workflow looks like this:
module org.xtext.example.mydsl.GenerateMyDsl
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/example/mydsl/MyDsl.xtext"
var fileExtensions = "mydsl"
var projectName = "org.xtext.example.mydsl"
var runtimeProject = "../${projectName}"
var generateXtendStub = true
var encoding = "UTF-8"
Workflow {
    bean = StandaloneSetup {
    	scanClassPath = true
    	platformUri = "${runtimeProject}/.."
    	// The following two lines can be removed, if Xbase is not used.
    	registerGeneratedEPackage = "org.eclipse.xtext.xbase.XbasePackage"
    	registerGenModelFile = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
    	// Ecore
    	registerGeneratedEPackage = "org.eclipse.emf.ecore.EcorePackage"
    	registerGenModelFile = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
    component = DirectoryCleaner {
    	directory = "${runtimeProject}/src-gen"
    	directory = "${runtimeProject}/model"
    	directory = "${runtimeProject}.ui/src-gen"
    	directory = "${runtimeProject}.tests/src-gen"
    component = Generator {
    	pathRtProject = runtimeProject
    	pathUiProject = "${runtimeProject}.ui"
    	pathTestProject = "${runtimeProject}.tests"
    	projectNameRt = projectName
    	projectNameUi = "${projectName}.ui"
    	encoding = encoding
    	language = auto-inject {
    		uri = grammarURI
    		// Java API to access grammar elements (required by several other fragments)
    		fragment = grammarAccess.GrammarAccessFragment auto-inject {}
    		// generates Java API for the generated EPackages
    		fragment = ecore.EMFGeneratorFragment auto-inject {}
    		// the old serialization component
    		// fragment = parseTreeConstructor.ParseTreeConstructorFragment auto-inject {}
    		// serializer 2.0
    		fragment = serializer.SerializerFragment auto-inject {
    			generateStub = false
    		// a custom ResourceFactory for use with EMF
    		fragment = resourceFactory.ResourceFactoryFragment auto-inject {}
    		// The antlr parser generator fragment.
    		fragment = parser.antlr.XtextAntlrGeneratorFragment auto-inject {
    		//  options = {
    		//      backtrack = true
    		// Xtend-based API for validation
    		fragment = validation.ValidatorFragment auto-inject {
    		    composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
    		    composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
    		// old scoping and exporting API
    		// fragment = scoping.ImportURIScopingFragment auto-inject {}
    		// fragment = exporting.SimpleNamesFragment auto-inject {}
    		// scoping and exporting API
    		fragment = scoping.ImportNamespacesScopingFragment auto-inject {}
    		fragment = exporting.QualifiedNamesFragment auto-inject {}
    		fragment = builder.BuilderIntegrationFragment auto-inject {}
    		// generator API
    		fragment = generator.GeneratorFragment auto-inject {}
    		// formatter API
    		fragment = formatting.FormatterFragment auto-inject {}
    		// labeling API
    		fragment = labeling.LabelProviderFragment auto-inject {}
    		// outline API
    		fragment = outline.OutlineTreeProviderFragment auto-inject {}
    		fragment = outline.QuickOutlineFragment auto-inject {}
    		// quickfix API
    		fragment = quickfix.QuickfixProviderFragment auto-inject {}
    		// content assist API
    		fragment = contentAssist.ContentAssistFragment auto-inject {}
    		// generates a more lightweight Antlr parser and lexer tailored for content assist
    		fragment = parser.antlr.XtextAntlrUiGeneratorFragment auto-inject {}
    		// generates junit test support classes into Generator#pathTestProject
    		fragment = junit.Junit4Fragment auto-inject {}
    		// rename refactoring
    		fragment = refactoring.RefactorElementNameFragment auto-inject {}
    		// provides the necessary bindings for java types integration
    		fragment = types.TypesGeneratorFragment auto-inject {}
    		// generates the required bindings only if the grammar inherits from Xbase
    		fragment = xbase.XbaseGeneratorFragment auto-inject {}
    		// provides a preference page for template proposals
    		fragment = templates.CodetemplatesGeneratorFragment auto-inject {}
    		// provides a compare view
    		fragment = compare.CompareFragment auto-inject {}
Re: Import and use Ecore model using importURI [message #1393903 is a reply to message #1389056] Fri, 04 July 2014 08:58 Go to previous messageGo to next message
Any other suggestions? Sad
Re: Import and use Ecore model using importURI [message #1393980 is a reply to message #1393903] Fri, 04 July 2014 11:27 Go to previous message
your workflow is not configured to support import uri
    		// fragment = scoping.ImportURIScopingFragment auto-inject {} //Bad
    		// fragment = exporting.SimpleNamesFragment auto-inject {} //Bad
    		fragment = scoping.ImportNamespacesScopingFragment auto-inject {} //Bad
    		fragment = exporting.QualifiedNamesFragment auto-inject {} //Bad
fragment = types.TypesGeneratorFragment auto-inject {} //Bad
    		fragment = xbase.XbaseGeneratorFragment auto-inject {} //Bad
Previous Topic:XCore 1.1.2 not any more on updatesite
Next Topic:Mac OS X very slow
Current Time: Fri Jul 18 17:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.04971 seconds
