Home » Modeling » TMF (Xtext) » [Xbase] How to provide scope for a XBlockExpression
[Xbase] How to provide scope for a XBlockExpression [message #1385303] |
Thu, 05 June 2014 09:37  |
I am developing a DSL with Xtext 2.6 which is based on Xbase and I would like to do something like:
Concept Airport {
Attributes {
Text(9) name {
Validate {//XBlockExpression}
Text(19) code {}
Number(5) someNumber {}
I have the grammar and the JvmModelInferrer and now I want to write some Xbase expressions inside the "Validate" block, basically all I want to have is access to the attributes defined within this Airport.
When I use the Content Assist inside the Validate body I only see keywords and that seems to be due to the fact that no types have been computed.
I have found lots of different Xbase classes (IFeatureScopeSession, FeatureScopes, IBatchTypeResolver, etc.) and no good guidance to how these interact and where I would have to implement my custom logic.
So, please, where should I start?
Thanks, Jan
[Updated on: Thu, 05 June 2014 09:38] by Moderator
Re: [Xbase] How to provide scope for a XBlockExpression [message #1385311 is a reply to message #1385303] |
Thu, 05 June 2014 10:20   |
On 05/06/2014 15:37, Jan Rosczak wrote:
> Concept Airport {
> Attributes {
> Text(9) name {
> Text(19) code {}
> computed.
> this interact and where I would have to implement my custom logic.
You should implement the JvmModelInferrer and map the concepts of your
DSL to the Jvm type model (e.g., fields, methods)... with that in place
scoping will work automatically once you set your XBlockExpression as
the "body" of a mapped method...
Have you looked at the domain model example?
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: [Xbase] How to provide scope for a XBlockExpression [message #1386878 is a reply to message #1385386] |
Sun, 22 June 2014 04:24  |
On 06/06/2014 07:11, Jan Rosczak wrote:
> thanks for that tip. I already had the JvmModelInferrer implemented, but
> missed the assignment to the "body" of a mapped method.
> Do you know how I can adapt the scoping for my XBlockExpression, add
> something, remove somethings, etc. in Xbase 2.6, because it changed from
> 2.5?
> Regards
> Jan
Hi Jan
sorry for the late response.
I did something similar in this project:
https://github.com/LorenzoBettini/xtraitj/blob/master/xtraitj/src/xtraitj/scoping/XtraitjScopeProviderUtil.xtend
Xtext Book:
Current Time: Fri Jul 25 11:16:16 EDT 2025
Powered by FUDForum. Page generated in 0.03671 seconds
