Home » Language IDEs » Java Development Tools (JDT) » unable to assign a @NonNull value to @Nullable value for arrays
unable to assign a @NonNull value to @Nullable value for arrays [message #1386818] Fri, 20 June 2014 15:29 Go to next message
eclipse 4.4rc4,
consider this example:
public class Test001 {
    void test()  {
        @NonNull Object b = new Object();
        Object @NonNull[] c = { new Object() };
        test2( b );
        test3( c );
    void test2(@Nullable Object z)  {  }
    void test3(Object @Nullable[] z)  {  }
calling test3 (c) gives the error:
Null type mismatch (type annotations): required 'Object @Nullable[]' but this expression has type 'Object @NonNull[]'
but test2(b) work fine
I suppose there are problems with array assignment
Re: unable to assign a @NonNull value to @Nullable value for arrays [message #1386825 is a reply to message #1386818] Fri, 20 June 2014 19:00 Go to previous message
Probably related to https://bugs.eclipse.org/437270
I've added your example to the bug.
Previous Topic:Eclipse JUnit Pluin Code
Next Topic:Can't create new Java Project
Current Time: Mon Jul 21 00:15:03 EDT 2025
Powered by FUDForum. Page generated in 0.06169 seconds
