Home » Eclipse Projects » Remote Application Platform (RAP) » Replacement for PhaseListeners in RAP 2.x
Replacement for PhaseListeners in RAP 2.x [message #1064684] Thu, 20 June 2013 10:12 Go to next message
Up to now (RAP 1.x) I used a PhaseListener to be notified of any client action. This was a nice way to implement a session timeout mechanism in my RAP server app. Every time a user loggs in a PhaseListener is started and every client action will trigger an update in my timeout handler. RAP 2.x doesn't provide this feature any more. It's limited to register PhaseListeners at application startup only. Is there any possibility to be notified of any client action within RAP context? Or do I have to broaden the scope and use ServletFilters?
Re: Replacement for PhaseListeners in RAP 2.x [message #1065069 is a reply to message #1064684] Mon, 24 June 2013 04:34 Go to previous messageGo to next message
Hi Thorsten,
Could you explain why you need to implement the session timeout yourself
and how your timeout differs from the servlet container's session timeout?
Why does a static PhaseListener not work in your case?
Not sure if it's related to your problem, but as of 2.1, browser clients
notify the server when they are closed and the UISession is then terminated.
Ralf
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=284273
Ralf Sternberg
Twitter: @EclipseRAP
Re: Replacement for PhaseListeners in RAP 2.x [message #1065274 is a reply to message #1065069] Tue, 25 June 2013 04:23 Go to previous messageGo to next message
Hi Ralf,
I am using a short http timeout and a long application timeout. Advantage: in case of a browser crash it won't allocate resources on the server for too long (because of a short http timeout). But to refresh the application timeout i'll have to be aware of every client action. Using a PhaseListener was a fine solution.
What do you mean by 'static'? I can still continue using the old way of using a PhaseListener (every time a user loggs in a PhaseListener is started) but the api is deprecated. I want to implement a solid solution.
Are there any alternatives?
[Updated on: Tue, 25 June 2013 04:24] by Moderator
Re: Replacement for PhaseListeners in RAP 2.x [message #1065353 is a reply to message #1065274] Tue, 25 June 2013 07:54 Go to previous messageGo to next message
Ok, I think I understand.
You can still use a PhaseListener for that, but instead of one per
UISession, you'd have a single shared PhaseListener for all sessions.
This phase listener must be registered in the ApplicationConfiguration.
Phase listeners are not session-specific, that's why the API for adding
PhaseListeners dynamically is deprecated.
Ralf
Ralf Sternberg
Re: Replacement for PhaseListeners in RAP 2.x [message #1065367 is a reply to message #1065353] Tue, 25 June 2013 09:11 Go to previous messageGo to next message
Hi Ralph,
thx. I will have a try at your solution.
Re: Replacement for PhaseListeners in RAP 2.x [message #1066580 is a reply to message #1065353] Wed, 03 July 2013 05:23 Go to previous messageGo to next message
Ralf Sternberg wrote on Tue, 25 June 2013 07:54
In the meantime I gave it a try... and it is the way to go (syncing from a global PhaseListener to a user specific session is no problem at all). Thx for the hint.
Re: Replacement for PhaseListeners in RAP 2.x [message #1066943 is a reply to message #1066580] Fri, 05 July 2013 04:20 Go to previous messageGo to next message
Thanks for the update! Good to know that this works for you.
Ralf
Ralf Sternberg
Re: Replacement for PhaseListeners in RAP 2.x [message #1386771 is a reply to message #1066943] Fri, 20 June 2014 06:53 Go to previous messageGo to next message
One question: according to my debug session we use org.eclipse.rap.ui.internal.servlet.WorkbenchApplicationConfiguration. How can I add a PhaseListener to this class? Is it possible in any way? I would like to use your PhaseListener example at https://gist.github.com/ralfstx/5791804, but I do not see the way to do so.
I see, that the WorkbenchApplicationConfiguration adds the PhaseListener instances to the Application. Is there any way to retrieve the Application instance I am currently in?
Regards and thanks,
Gábor Lipták
[Updated on: Fri, 20 June 2014 06:59] by Moderator
Re: Replacement for PhaseListeners in RAP 2.x [message #1386775 is a reply to message #1386771] Fri, 20 June 2014 07:14 Go to previous messageGo to next message
Hi Gábor,
PhaseListeners have been deprecated in RAP 2.3 and will be completely
removed in RAP 3.0 (API already removed in master). If you want to
render an HTML attribute for particular widget try this code in RAP 2.3+:
Button pushButton = new Button( parent, SWT.PUSH );
JavaScriptExecutor executor = RWT.getClient().getService(
JavaScriptExecutor.class );
if( executor != null ) {
executor.execute( "rap.getObject(\"" + WidgetUtil.getId( pushButton )
+ "\").$el.attr(\"foo\", \"bar\");" );
HTH,
Ivan
Ivan Furnadjiev
Re: Replacement for PhaseListeners in RAP 2.x [message #1386779 is a reply to message #1386775] Fri, 20 June 2014 07:49 Go to previous messageGo to next message
Hi Ivan,
Thanks for the prompt answer. How could I do such thing in case of a widget created by an Eclipse extension? For example menus? The PhaseListener was a perfect candidate, since it was called "regularly", and I could traverse the widgets. Is there anything similar in 2.3+?
Gábor
Re: Replacement for PhaseListeners in RAP 2.x [message #1386934 is a reply to message #1386779] Mon, 23 June 2014 03:49 Go to previous messageGo to next message
in RAP 2.3 the PhaseListeners are still operational. For 3.0+ - we
implemented MessageFilter (similar to ServletFilter), which is still
internal. Once the implementation is considered stable we will make it API.
Best,
Ivan
Ivan Furnadjiev
Re: Replacement for PhaseListeners in RAP 2.x [message #1386945 is a reply to message #1386934] Mon, 23 June 2014 04:40 Go to previous messageGo to next message
PhaseListener was used as workaround for bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=389040, is it possible to use MessageFilter instead in 3.0+ ?
[Updated on: Mon, 23 June 2014 04:41] by Moderator
Re: Replacement for PhaseListeners in RAP 2.x [message #1386953 is a reply to message #1386945] Mon, 23 June 2014 04:52 Go to previous messageGo to next message
Probably yes.
Ivan Furnadjiev
Re: Replacement for PhaseListeners in RAP 2.x [message #1389068 is a reply to message #1386945] Fri, 27 June 2014 05:27 Go to previous message
Absolutely. I've attached a snippet to this bug.
Regards, Ralf
Ralf Sternberg
Previous Topic:Has ScrollBar different behaviour in SWT and RWT?
Next Topic:ServerPushSessions
Current Time: Sun Jul 27 10:06:52 EDT 2025
Powered by FUDForum. Page generated in 0.06903 seconds
