Home » Eclipse Projects » NatTable » first column not showing correct values after ColumnReorder
first column not showing correct values after ColumnReorder [message #1386642] Wed, 18 June 2014 22:40 Go to next message
I am moving a column from 4th position to first position ( 0 )- by position I mean physical location in my nattable. The values that are in the column when it was in 4th position change to the object representations ( not the actual values that the cellpainter renders ). Also the images disappear.
Can somebody tell me how to fix this? I hope I am not sounding vague.
Re: first column not showing correct values after ColumnReorder [message #1386649 is a reply to message #1386642] Thu, 19 June 2014 02:30 Go to previous message
You are sounding vague.
I assume you are using a custom label accumulator? Maybe you are setting the labels for the position rather than the index? That is typically the issue in such cases that the labels used for registering painters and styles are registered for the wrong parameters.
Previous Topic:Finding row index in TreeLayer
Next Topic:row auto resizing
Current Time: Sun Jul 27 22:24:38 EDT 2025
Powered by FUDForum. Page generated in 0.38738 seconds
