Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to alignment for label text
How to alignment for label text [message #1386138] Fri, 13 June 2014 11:02 Go to next message
One label was added: org.eclipse.swt.widgets.Label
When plan to do alignment for the text on the label to right,or , center, top, bottom, I am unable to do it. Any idea about it. Or if I can do add some left padding (space), top padding, ...
My code:
public void createPartControl(Composite arg0) {
Label lblNewLabel = new Label(arg0, SWT.NONE);
lblNewLabel.setBounds(25, 99, 400, 26);
lblNewLabel.setText("this is test");
lblNewLabel.setBackground(org.eclipse.wb.swt.SWTResourceManager.getColor(SWT.COLOR_DARK_GRAY));
lblNewLabel.setFont(org.eclipse.wb.swt.SWTResourceManager.getFont("Tahoma", 6, SWT.TOP));
How to alignment label text "this is test" to the Right ? In default, it is in left and top alignment when I had big bounds.
Appreciate it.Gary
Re: How to alignment for label text [message #1386501 is a reply to message #1386138] Tue, 17 June 2014 19:12 Go to previous message
Probably you should do the following lblNewLabel.setAlignment(SWT.RIGHT);
Previous Topic:SIGSEV crash JVM under Ubuntu 12.04 when scrolling in Canvas
Next Topic:Mozilla SWT Browser / Java Native Interface
Current Time: Sun Nov 02 03:16:44 EST 2025
Powered by FUDForum. Page generated in 0.04126 seconds
