Home » Modeling » TMF (Xtext) » Reference does not work
Reference does not work [message #1386469] Tue, 17 June 2014 14:03 Go to next message
I have a parseRule named ElementSyntax which can provide this form of element : {e1}, {e2,e12,e9}.
What I want is to get the reference of ElementSyntax. Below, you will see how I wrote my grammar but it's not working.
ElementSyntax :
	'{'	elt=ElementID (',' eltIDs+=ElementID)* '}' ;
ElementID:
	name=ID ;
ExcludeDecision:
	'and' 'exclude' rule=[Rule] 'for' elementID=[ElementSyntax] ;
Any help is greatly appreciated.
Best Regards,
Felix
Re: Reference does not work [message #1386470 is a reply to message #1386469] Tue, 17 June 2014 14:05 Go to previous messageGo to next message
if you dont have an attribute named 'name' you have to adapt IQualifiedNameProvider(subclassing DefaultDeclarativeQualifiedNameProvider)
what shall be the ElementSyntax name? it has multiple ElementIDs in your case.
can you share a complete reproducable example?
[Updated on: Tue, 17 June 2014 14:07] by Moderator
Re: Reference does not work [message #1386476 is a reply to message #1386470] Tue, 17 June 2014 14:26 Go to previous messageGo to next message
Here is the complete reproducable example:
http://tinypic.com/view.php?pic=2hhf9md&s=8#.U6CIFPl_tyU
The complete grammar
/********************** Alternative *************************/
Alternative:
'Alternative' id=INT ':'
for='for' name=ElementSyntax select='select' ':'
rule=Rule (params+=RuleList)* ';' ;
RuleList:
'or' rule=Rule ;
/********************** End Alternative **********************/
/********************** Decision *************************/
Decision:
'Decision' id=Entier ':' select=Select ';'
'consequences' ':' consequenceDecl=ConsequencesDeclaration ;
ConsequencesDeclaration:
NoneDecision | (subDecisions+=SubDecision)+ | SelectDecision
NoneDecision:
name='none' ';' ;
SubDecision:
'decision' i=[Entier]'.'j=Entier ':' select=Select (excludes+=ExcludeDecision)+ ';' ;
SelectDecision:
ExcludeDecision:
'and' 'exclude' rule=[Rule] 'for' elementID=ElementSyntax ; //[ElementSyntax]
Select:
'select' rule=[Rule] 'for' elementID=ElementSyntax ; //[ElementSyntax]
Entier :
id=INT ;
/********************** End Decision **********************/
ElementSyntax :
Re: Reference does not work [message #1386477 is a reply to message #1386476] Tue, 17 June 2014 14:28 Go to previous messageGo to next message
Here is the complete example:
http://i57.tinypic.com/2hhf9md.jpg
Re: Reference does not work [message #1386478 is a reply to message #1386477] Tue, 17 June 2014 14:32 Go to previous messageGo to next message
Still the question,
what is the semantic meaning of
ElementSyntax :
and that is the name of an ElementSyntax
the grammar says:
a ElementSyntax has a elt of type ElementID and a list of ElementID named eltIDs
so why not
ElementSyntax :
'{'	name=ID (',' eltIDs+=ElementID)* '}' ;
or as i said adapt IQualifiedNameProvider
Re: Reference does not work [message #1386480 is a reply to message #1386478] Tue, 17 June 2014 14:43 Go to previous messageGo to next message
http://christiandietrich.wordpress.com/2011/07/16/iqualifiednameproviders-in-xtext-2-0/
Re: Reference does not work [message #1386492 is a reply to message #1386480] Tue, 17 June 2014 16:28 Go to previous messageGo to next message
Hi Christian,
I did what you said but from
ElementSyntax :
I can retreive elt and not all ElementSyntax (elt + eltIDs + identifier).
I am saying that because as you can see in the snapshot, {E1,E2, E112} isn't {E1,E2,E3} so I should have get an error.
http://i59.tinypic.com/drxo2.jpg
How to make a reference to the exact object ElementSyntax ({E1} or {E1,E2,E3} in my example).
Thank,
Felix
Re: Reference does not work [message #1386493 is a reply to message #1386492] Tue, 17 June 2014 16:36 Go to previous messageGo to next message
i still do no get your semantics. to you say the ElementSyntax
has the the names E1 E2 and E3????
if so you have to adapt the IDefaultResourceDescriptionStrategy or rethink your grammar to
ElementSyntaxContainer :
'{'	syntaxes+=ElementSyntax* (',' syntaxes+=ElementSyntax)* '}' ;
ElementSyntax: name=ID;
... 'for' elementID=ElementSyntaxContainer ; /
Re: Reference does not work [message #1386495 is a reply to message #1386493] Tue, 17 June 2014 16:46 Go to previous messageGo to next message
and you may have to adapt scoping as well,
but i still do not understand your semantics so it is hard to tell
Re: Reference does not work [message #1386498 is a reply to message #1386495] Tue, 17 June 2014 16:59 Go to previous messageGo to next message
P.S: which Element Syntaxes shall be visible in a Select?
only the ones from the rule? if you you definitively have to adapt scoping
Select:
'select' rule=[Rule] 'for' elementID=[ElementSyntax]  ; //
@Inject IQualifiedNameProvider nameProvider
IScope scope_Select_elementID(Select ctx, EReference r) {
ruleElements = ctx.getRule().getAllElements() //your logic, with partial grammar not to tell.
Scopes.scopeFor(ruleElments,nameProvider,IScope.NULLSCOPE)
Re: Reference does not work [message #1386591 is a reply to message #1386493] Wed, 18 June 2014 09:35 Go to previous messageGo to next message
What I am calling the ElementSyntax is what you actually called ElementSyntaxContainer.
I do not want a reference to a an ID but to an object who will have this form {ID, ID2, ..., IDn}.
Root:
    root+=RootElement+;
RootElement:
    ElementIwantAReference | GetReference;
GetReference:
    retreiveReference = [ElementIwantAReference];
ElementIwantAReference:
    '{' elt=Element (elts+=Element)* '}';
Element: name=ID;
Re: Reference does not work [message #1386592 is a reply to message #1386591] Wed, 18 June 2014 09:41 Go to previous messageGo to next message
ElementSyntax is for an and element (parseRule) like STRING.
In Select Rule and ElementSystax shoul be both visible.
Re: Reference does not work [message #1386597 is a reply to message #1386592] Wed, 18 June 2014 10:10 Go to previous messageGo to next message
you what you actually want to have is:
the name of an ElementSyntax is the whole thing???? {E1,E2,E3}
ElementSyntax:
	name=ElementSyntaxName
ElementSyntaxName: '{' ID (',' ID)* '}';
.... 'for' element=[ElementSyntax|ElementSyntaxName];
[ElementSyntax|ElementSyntaxName] means ElementSyntax by ElementSyntaxName
Re: Reference does not work [message #1386603 is a reply to message #1386597] Wed, 18 June 2014 10:52 Go to previous message
Yes it works,
thank you Christian.
Previous Topic:Integrate and validate OCL grammer in XText
Next Topic:Adding function calls to DSL syntax
Current Time: Sun Jul 27 11:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.06979 seconds
