Home » Archived » Sapphire » build qualifier
build qualifier [message #1386443] Tue, 17 June 2014 11:10 Go to next message
When creating a local build, how can you specify a custom qualifier other than just using the default date? I'd like to add a suffix to the normal yyyyMMddhhmm format.
Re: build qualifier [message #1386453 is a reply to message #1386443] Tue, 17 June 2014 12:13 Go to previous messageGo to next message
There isn't an existing facility to override the qualifier. Search for references to DSTAMP and you can customize the build as appropriate.
Re: build qualifier [message #1386505 is a reply to message #1386453] Tue, 17 June 2014 20:04 Go to previous messageGo to next message
I replaced all of the DSTAMP with a couple of different things:
${DSTAMP}-custom
or just
custom
And both fail with this type of error:
    [unzip] Expanding: /lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build/repository/plugins/org.eclipse.sapphire.workspace_8.0.1.custom.jar into /lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build/temp
     [echo] Mirroring ASM...
     [copy] Copying 1 file to /lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build/repository/plugins
     [echo] Packaging the repository...
     [java] Generating metadata for ..
     [java] Status ERROR: org.eclipse.equinox.p2.artifact.repository code=0  java.lang.IllegalArgumentException
     [java]
     [java] Product publishing ended with the following exception:
     [java] java.lang.IllegalArgumentException
     [java] 	at org.eclipse.equinox.internal.p2.metadata.VersionParser.parse(VersionParser.java:93)
     [java] 	at org.eclipse.equinox.p2.metadata.Version.create(Version.java:79)
     [java] 	at org.eclipse.equinox.internal.p2.updatesite.SiteXMLAction.getFeatureIU(SiteXMLAction.java:214)
     [java] 	at org.eclipse.equinox.internal.p2.updatesite.SiteXMLAction.generateCategories(SiteXMLAction.java:111)
     [java] 	at org.eclipse.equinox.internal.p2.updatesite.SiteXMLAction.perform(SiteXMLAction.java:102)
     [java] 	at org.eclipse.equinox.internal.p2.updatesite.LocalUpdateSiteAction.perform(LocalUpdateSiteAction.java:70)
     [java] 	at org.eclipse.equinox.p2.publisher.Publisher$ArtifactProcess.run(Publisher.java:207)
     [java] 	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.executeBatch(SimpleArtifactRepository.java:1345)
     [java] 	at org.eclipse.equinox.p2.publisher.Publisher.publish(Publisher.java:231)
     [java] 	at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:286)
     [java] 	at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:256)
     [java] 	at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.start(AbstractPublisherApplication.java:320)
     [java] 	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
     [java] 	at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
     [java] 	at java.lang.Thread.run(Thread.java:745)
     [java]
     [java] Product publisher application was executed with the following arguments:
     [java] -metadataRepository
     [java] file:/lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build/repository
     [java] -artifactRepository
     [java] -source
     [java] /lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build/repository
     [java] -compress
     [java] -publishArtifacts
BUILD FAILED
/lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build.xml:67: The following error occurred while executing this line:
/lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/build.xml:224: The following error occurred while executing this line:
/lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/releng/ant-library/library.xml:339: The following error occurred while executing this line:
/lrdev/repos/git.eclipse.org/sapphire/org.eclipse.sapphire/releng/ant-library/library.xml:307: Java returned: 1
Re: build qualifier [message #1386510 is a reply to message #1386505] Tue, 17 June 2014 23:22 Go to previous message
I'd dig through the files left over when it fails to determine the full version that it ends up using in feature.xml and MANIFEST.MF files. That might offer a clue as to what's going wrong.
Previous Topic:Sapphire 8 graphical editor DnD issue
Next Topic:Run Sapphire Project
Current Time: Tue Oct 28 19:20:58 EDT 2025
Powered by FUDForum. Page generated in 0.04993 seconds
