Home » Modeling » Compare » Manipulating the EMF Compare Editor
Manipulating the EMF Compare Editor [message #1386379] Tue, 17 June 2014 04:48 Go to next message
We are looking into the possibilities of customizing the CompareUI editor.
CompareUI.openCompareEditor(input);
Q1:
Is it possible to inject the names of the files/models that we compare, so that they can be displayed in the two bottom windows?
Else it can be quite confusing to keep focus on which model is the changed one.
index.php/fa/18302/0/
Q2:
Can we make a filter that also affects the two bottom windows?
It would be nice to be able to see the differences side by side without having to view the full model.
Q3:
Can we remove/disable buttons in the tool bar e.g the merge icons.
We want to do this to ensure that our users don't use them by accident.
Q4:
Can we make the currently selected difference clearer by changing the color of the selection or by getting a thick line displayed between the changes.
The thick line is nicely displayed when comparing individual values, but not when displaying differences in the model.
index.php/fa/18303/0/
index.php/fa/18304/0/
It would be really nice if you added a description to the developers guide that describes which data elements/structures are used where in the UI.
A description on how to interpret the Comparison result will also be helpful IMO.
Re: Manipulating the EMF Compare Editor [message #1386407 is a reply to message #1386379] Tue, 17 June 2014 07:14 Go to previous messageGo to next message
I found the answer to Q3 on how to hide the merge buttons.
Call setLeft/RightEditable(false) on the configuration before it is passed to the editor input.
//Build the editor input
EMFCompareConfiguration configuration = new EMFCompareConfiguration(new CompareConfiguration());
configuration.setLeftEditable(false); //Disable merge buttons
configuration.setRightEditable(false);
ICompareEditingDomain editingDomain = EMFCompareEditingDomain.create(modelsToCompare.getChangedModel(), modelsToCompare.getReferenceModel(), null);
ComposedAdapterFactory adapterFactory = new ComposedAdapterFactory(ComposedAdapterFactory.Descriptor.Registry.INSTANCE);
CompareEditorInput compareEditorInput = new ComparisonEditorInput(configuration, result, editingDomain, adapterFactory);
Re: Manipulating the EMF Compare Editor [message #1386964 is a reply to message #1386407] Mon, 23 June 2014 05:48 Go to previous messageGo to next message
Hi Anja,
Q1 : This has been recently fixed and the names are now displayed where you have orange text on your screenshot. IIRC, you can still alter them through the compareConfiguration (setLeftLabel, setRightLabel).
Q2 : No. We use the in-memory models loaded by EMF Compare and display them in a tree viewer, using the generated "edit" item and label providers for them.
Q3 : The merge buttons are only visible if the CompareConfiguration tells us that the models are editable. They won't be displayed if you call compareConfiguration.setLeftEditable(false) and compareConfiguration.setRightEditable(false). The other buttons of our toolbar are always displayed.
Q4 : You'll find some of our colors in General > Appearance > Colors and Fonts (EMF Compare category), but I don't think the colors you seek are available in there. You might want to look at CompareColorImpl, where all five colors IDs are defined (though these are intenal and subject to change), and manually change them to something of your liking. If that works, please raise an enhancement request on the bugzilla so that we can look at how to open an API or add these colors to the preferences. Something like this might do the trick :
IThemeManager themeManager = PlatformUI.getWorkbench().getThemeManager();
final ITheme currentTheme;
if (themeManager != null) {
	currentTheme = themeManager.getCurrentTheme();
	currentTheme.getColorRegistry().put(CompareColorImpl.INCOMING_CHANGE_COLOR_THEME_KEY, <RGB of your choice>);
Laurent Goubet
Obeo
Re: Manipulating the EMF Compare Editor [message #1707748 is a reply to message #1386964] Wed, 09 September 2015 02:14 Go to previous messageGo to next message
With respect to the Q2, is it possible to provide our own implementation for the item and label providers? We have a standard set of icons for our model elements throughout our application. So we want to customize the tree to show our icons instead of the default icons
Re: Manipulating the EMF Compare Editor [message #1708392 is a reply to message #1707748] Wed, 16 September 2015 04:22 Go to previous message
Hi Vikhyat,
Yes, you can use the extension point org.eclipse.emf.compare.edit.adapterFactory, which allows you to register custom providers. But the EMF Compare UI will automatically respect the providers that are registered through org.eclipse.emf.edit.itemProviderAdapterFactories, so it shouldn't be necessary in most of the scenarios . Maybe this thread will help too: https://www.eclipse.org/forums/index.php/t/681285/.
Best wishes,
Philip
Previous Topic:Support for Containment Proxies
Next Topic:Attribute changes in containment object result in ReferenceChange, but sometimes in AttributeChange
Current Time: Sat Jul 26 21:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.04133 seconds
