Home » Modeling » TMF (Xtext) » Xtext internal error : error(10)
Xtext internal error : error(10) [message #1298472] Wed, 16 April 2014 05:32 Go to next message
Hello everyone,
when I generate the xtext artefacts I'm getting the following strange exception:
error(10):  internal error: Can't get property indirectDelegates using method get/isIndirectDelegates from org.antlr.tool.Grammar instance : java.lang.NullPointerException
The problem just began after a java-upgrade (to java 8 ) and the intallation of the following kepler patch for java 8 (https://wiki.eclipse.org/JDT/Eclipse_Java_8_Support_For_Kepler). Before the upgrade everything worked fine and ran without a problem.
But the really weird thing about this is, that the generated xtext-code is completely accurate!
Maybe someone has an idea what's wrong here.
~Alex
PS: Here the whole stacktrace:
java.util.Objects.requireNonNull(Unknown Source)
java.util.ArrayList.removeAll(Unknown Source)
org.antlr.tool.CompositeGrammar.getIndirectDelegates(CompositeGrammar.java:222)
org.antlr.tool.Grammar.getIndirectDelegates(Grammar.java:2620)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.antlr.stringtemplate.language.ASTExpr.invokeMethod(ASTExpr.java:564)
org.antlr.stringtemplate.language.ASTExpr.rawGetObjectProperty(ASTExpr.java:515)
org.antlr.stringtemplate.language.ASTExpr.getObjectProperty(ASTExpr.java:417)
org.antlr.stringtemplate.language.ActionEvaluator.attribute(ActionEvaluator.java:351)
org.antlr.stringtemplate.language.ActionEvaluator.expr(ActionEvaluator.java:136)
org.antlr.stringtemplate.language.ActionEvaluator.templateApplication(ActionEvaluator.java:216)
org.antlr.stringtemplate.language.ActionEvaluator.expr(ActionEvaluator.java:126)
org.antlr.stringtemplate.language.ActionEvaluator.action(ActionEvaluator.java:84)
org.antlr.stringtemplate.language.ASTExpr.write(ASTExpr.java:149)
org.antlr.stringtemplate.StringTemplate.write(StringTemplate.java:705)
org.antlr.stringtemplate.language.ASTExpr.writeTemplate(ASTExpr.java:750)
org.antlr.stringtemplate.language.ASTExpr.write(ASTExpr.java:680)
org.antlr.stringtemplate.language.ASTExpr.writeAttribute(ASTExpr.java:660)
org.antlr.stringtemplate.language.ActionEvaluator.action(ActionEvaluator.java:86)
org.antlr.codegen.CodeGenerator.write(CodeGenerator.java:1281)
org.antlr.codegen.Target.genRecognizerFile(Target.java:94)
org.antlr.codegen.CodeGenerator.genRecognizer(CodeGenerator.java:466)
org.antlr.Tool.generateRecognizer(Tool.java:641)
org.antlr.Tool.process(Tool.java:454)
de.itemis.xtext.antlr.toolrunner.AntlrToolRunner.runWithEncodingAndParams(AntlrToolRunner.java:168)
org.eclipse.xtext.generator.parser.antlr.AntlrToolFacade.runWithEncodingAndParams(AntlrToolFacade.java:173)
org.eclipse.xtext.generator.parser.antlr.XtextAntlrGeneratorFragment.generate(XtextAntlrGeneratorFragment.java:47)
org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:92)
org.eclipse.xtext.generator.LanguageConfig.generate(LanguageConfig.java:113)
org.eclipse.xtext.generator.Generator.generate(Generator.java:366)
org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:132)
org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
org.eclipse.xtext.generator.parser.antlr.XtextAntlrUiGeneratorFragment.generate(XtextAntlrUiGeneratorFragment.java:85)
[Updated on: Wed, 16 April 2014 05:33] by Moderator
Re: Xtext internal error : error(10) [message #1385997 is a reply to message #1298472] Thu, 12 June 2014 15:32 Go to previous message
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=437305
and https://bugs.eclipse.org/bugs/show_bug.cgi?id=433176
Previous Topic:Need to change the return type of a Terminal
Next Topic:How to check Custom Validation Errors
Current Time: Sun Jul 27 07:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.03169 seconds
