reusing setups/tasks [message #1385974] |
Thu, 12 June 2014 10:31  |
is there a recommended way for reusing/aggregating setups, tasks, etc. The simple scenario would be as follows. You want to keep p2-tasks and properties for various features in separate models, e.g. p2-task for the Xtext update site, plugins as well as builder and highlighting properties in X.setup, checkstyle plugins and properties in Y.setup.
For project P1 you only need Xtext, so you would want to include X.setup in its project description, for project P2 you need Xtext as well as checkstyle sou you would want to include X.setup and Y.setup.
Alex
Re: reusing setups/tasks [message #1386034 is a reply to message #1385974] |
Fri, 13 June 2014 02:53  |
Alexander,
Comments below.
On 12/06/2014 4:31 PM, Alexander Nittka wrote:
The only mechanism is subproject nesting..
> properties
You mean variables?
> X.setup,
Sounds like preferences then?
Certainly with regard to p2 task, it's just an issue of the IU being
specified and the p2 site to get it from. The p2 site could be shared
up in a root project and in a subproject you could specify to actually
install an IU from it, i.e., p2 tasks typically merge into a single task
for the stream in the leaf project.
So you could nest all the projects that need checkstyle under a project
that specifies the checkstyle stuff. Only projects with streams can
actually be directly provisioned, so the container projects are just
places to keep common tasks.
> Alex
FUDForum. Page generated in 0.03503 seconds
