Home » Language IDEs » Java Development Tools (JDT) » The selection can not be run on any server(Tomcat doesn't want to run (maven) dynamic website)
The selection can not be run on any server [message #1385933] Thu, 12 June 2014 06:27 Go to next message
Hey all,
I have this Dynamic Webpage Project which I have converted to a Maven project.
It was set to use the Tomcat 7 server which I have installed locally.
All worked fine until, without changing anything other than a jsp file, I got the following message when trying to run the file.
"Server Error"
The selection cannot be run on any server.
I didn't change anything to the server nor the configurations between the time when it worked and when it gave this error.
I have tried the following already, without avail:
  1. Restarting Eclipse
  2. Removed and re-added the tomcat server
  3. Checked if the correct project facets were still selected (they are)
  4. Check whether tomcat 7 starts without errors (it does)
  5. Check if the maven build completes without errors (it does)
  6. Re-installed and re-added the tomcat server
  7. Re-installed Eclipse
  8. Blame windows
I haven encountered this problem before, but then eventually I abandoned the project and started a new one recycling as many files as possible.
Hence I would really like to figure out what is causing this.
I'm using Eclipse Kepler for Java EE Development
And I probably should mention that my project is set up to work with the Hibernate JPA.
Many thanks in advance,
Re: The selection can not be run on any server [message #1385967 is a reply to message #1385933] Thu, 12 June 2014 10:03 Go to previous messageGo to next message
For questions relating to web development, you'll get better results asking in the "Web Tools Project (WTP)" forum
Re: The selection can not be run on any server [message #1385970 is a reply to message #1385967] Thu, 12 June 2014 10:07 Go to previous message
I'm sorry, I was a bit confused as to where to ask this.
Any chance a moderator can move this thread then?
Previous Topic:Eclipse Nullness warning (after Java8)
Next Topic:Java8 Nullness type qualifiers and Maps
Current Time: Fri Jul 18 10:13:14 EDT 2025
Powered by FUDForum. Page generated in 0.05594 seconds
