Home » Eclipse Projects » NatTable » Buttons not rendering
Buttons not rendering [message #1385929] Thu, 12 June 2014 06:06 Go to next message
In my CreateControl class
 DefaultGridLayer gridLayer = new DefaultGridLayer (bodyDataProvider,columnHeaderDataProvider,rowHeaderDataProvider);
		DefaultBodyLayerStack bodyLayer = gridLayer.getBodyLayer();
	    // Grid
	    RiskReportCustomLabel cellLabelAccumulator = new RiskReportCustomLabel(bodyLayer);
	    bodyLayer.setConfigLabelAccumulator(cellLabelAccumulator);
		NatTable natTable = new NatTable(parent, gridLayer, false);
cellLabelAccumulator assigns RiskEditable.REFRESH to a particular cell. Then I add the config
natTable.addConfiguration(natTableConfiguration);
natTable.addConfiguration(rowStyleConfiguration);
natTable.addConfiguration(selectionStyle);
natTable.addConfiguration(new CopyPasteBindings());
natTable.addConfiguration(new RiskEditorConfiguration());
natTable.configure();
RiskEditorConfiguration calls this method
private void registerRefresh(IConfigRegistry configRegistry) {
Style style = new Style();
style.setAttributeValue(CellStyleAttributes.BACKGROUND_COLOR, GUIHelper.COLOR_WHITE);
		configRegistry.registerConfigAttribute(CellConfigAttributes.CELL_STYLE,	style, DisplayMode.NORMAL, RiskEditable.REFRESH);
		configRegistry.registerConfigAttribute(CellConfigAttributes.CELL_STYLE,	style, DisplayMode.SELECT, RiskEditable.REFRESH);
		configRegistry.registerConfigAttribute(CellConfigAttributes.CELL_PAINTER,new ButtonCellPainter(new CellPainterDecorator(new TextPainter(), CellEdgeEnum.RIGHT, new ImagePainter(GUIHelper.getImage("preferences")))),RiskEditable.REFRESH);
Now the particular cell doesn't render the button at all. However, the architecture is correct (changing it to GUIHelper.COLOR_BLACK makes the cell black).
Any help on this? I've spent a lot of time trying this out.
Re: Buttons not rendering [message #1385932 is a reply to message #1385929] Thu, 12 June 2014 06:25 Go to previous messageGo to next message
Are you sure the label is added to your label stack? You can add a debug configuration which allows you to inspect a cell via right click.
natTable.addConfiguration(new DebugMenuConfiguration(natTable));
Re: Buttons not rendering [message #1385936 is a reply to message #1385932] Thu, 12 June 2014 07:14 Go to previous messageGo to next message
Yes it is, just checked.
Re: Buttons not rendering [message #1385937 is a reply to message #1385936] Thu, 12 June 2014 07:17 Go to previous messageGo to next message
Is it the first label in the stack or is there a label on top of it to which another painter is registered?
Is your code compiling? When specifying a label to which a configuration attribute is registered, you typically need to specify the DisplayMode to which it should be registered. I don't see that in your snippet.
Re: Buttons not rendering [message #1386243 is a reply to message #1385937] Mon, 16 June 2014 02:26 Go to previous message
Yup that was it. Renders fine now. Thanks a lot!
Previous Topic:Auto resize columns by double clicking on column boundry is not working some time
Next Topic:Programmatic Column Freezing
Current Time: Sat Jul 26 03:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.26253 seconds
